faster Samba Member
Posted: Wed Jun 03, 2009 4:02 pm Post subject: Making my own valve covers |
I thought I`d just start my own thread on how to make 36hp valve covers. The first thing and the hardest part is coming up with a pattern you can`t just have an old valve cover recasted because aluminum will shrink just under a 1/4" per foot. So what i did was dig out the old wood working tools and build one from scratch. The trick is making everything bigger to make up for the shrink. And if you plan on make alot you have to make a double shrink pattern to ended up with aluminum pattern that will last. So heres the pictures.
The wood pattern.
The first casting.
After alittle polishing.
This one isn`t just right so it will become and ash tray. The holes are off alittle and it`s a bit tight on the sheet metal no room for the engine seal. Anyway I know what I need now and hope the next one will be right on. _________________ My 59 panel plus 36hp valve covers http://s122.photobucket.com/albums/o265/faster50/59%20panel/ |
splitvws Samba Member
Posted: Wed Jun 03, 2009 4:08 pm Post subject: |
Nice work! and I like the looks of the cover |
faster Samba Member
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Wed Jun 03, 2009 5:27 pm Post subject: |
Looks pretty sweet! How do you plan to true the seal area?
FWIW, they'll cool best if left rough, but then they wouldn't look as spiffy.
- Scott _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Boonies Samba Member
Joined: November 30, 2005 Posts: 816 Location: Chicago
Posted: Wed Jun 03, 2009 5:34 pm Post subject: |
Looking good. _________________ The Old Speed Shack |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Wed Jun 03, 2009 5:53 pm Post subject: |
Nice, are going to be selling the final versions when done? _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
faster Samba Member
Posted: Wed Jun 03, 2009 5:54 pm Post subject: |
I think I`m going to make a new pattern and use most of the parts on the old one. I`ll lower the top to match the bottom for the seal fit and also adjust the top so the holes match better. This happens all the time with the first pattern and changes have to be made when its the first pattern you`ve ever made. If I would have test fitted the wood one to the motor I would have found it was tight but I didn`t want to remove the rockers and adjust the valves again so now I have to pay. _________________ My 59 panel plus 36hp valve covers http://s122.photobucket.com/albums/o265/faster50/59%20panel/ |
faster Samba Member
Posted: Wed Jun 03, 2009 6:00 pm Post subject: |
splitpile wrote: |
Nice, are going to be selling the final versions when done? |
If I can get them poured for a good price I will. Right now it`s one at a time and done by hand. I thing the owner of the foundry is just having fun with me thinking I`m crazy but when I showed up with a pattern that I made he had a funny look in his eyes. _________________ My 59 panel plus 36hp valve covers http://s122.photobucket.com/albums/o265/faster50/59%20panel/ |
36hplandspeedracer Samba Member
Joined: January 30, 2006 Posts: 847 Location: Ivins, Utah
Posted: Wed Jun 03, 2009 7:59 pm Post subject: |
Looks like they are going to be real nice, as well as updated. Good luck on introducing a NEW 36hp product. We can always use more of that!
Burly |
69 Jim Samba Member
Joined: September 27, 2004 Posts: 6265 Location: Chickengeorge's Neighbor
Posted: Mon Jun 08, 2009 7:04 pm Post subject: |
You sir, are a craftsman. Nice work. |
faster Samba Member
Posted: Tue Jun 09, 2009 6:13 pm Post subject: |
69 Jim wrote: |
Thanks,
But its not as hard as it looks. I was hoping to make up a new one last weekend but got side tracked with other things the wife needed. Anyway I did pickup the needed wood and should have the new and approved model made soon. If I get everything right and can get them poured it`s looking like about $150.00 a set for now(thats one at a time ). But my goal is to have 3 to 4 poured at the same time lowering the price but not polished. Anyway the cost has been all on me so far and when I finish with my maddest it souldbe as good if not better then the older vintage covers. Give me a week and I should have a new pour. _________________ My 59 panel plus 36hp valve covers http://s122.photobucket.com/albums/o265/faster50/59%20panel/ |
faster Samba Member
Posted: Fri Jun 19, 2009 8:28 pm Post subject: |
Update. Well I just finish the new pattern and resized and made all the adjustments to fix the problems with the first one. The first of next week I`ll have it poured and hope it will be right on. This one is thinner and alittle lower to give room for the engine seal and should also be lighter as far as weight. The old one was very heavy.
Have a look and I will get it right .
a-train Samba Member
Joined: October 11, 2003 Posts: 702 Location: Issaquah via Parkland, WA
Posted: Sat Jun 20, 2009 3:02 am Post subject: |
very nice, excellent craftsmanship. _________________ I like VWs |
chivoragtop1959 Samba Member
Posted: Sat Jun 20, 2009 9:11 am Post subject: |
ALUMINUM AS 3 PERCENT SHRINKAGE
MOLD MAKER
TOOL AND DIE
GLENDALE CALI |
engineerscott Samba Member
Posted: Sun Jun 21, 2009 8:03 pm Post subject: |
Are you planning on doing some machining of the surface where the valve cover interfaces with the gasket? I'm afraid that without a flat, smooth surface you are going to have issues with oil leakage around the valve cover gasket. If you have access to the facilities I'd make a jig to hold the cover and then use a CNC endmill to machine that surface.
Don't take this a criticism BTW - You've done some remarkable craftsmanship that most people only think about. Excellent work. |
faster Samba Member
Posted: Wed Jun 24, 2009 2:18 pm Post subject: |
Update, Got the new and improved casting of the second pattern back today. Yesterday they poured one but it came out bad so today they repoured it hotter and it came out good but rougher from the heat. It needs alot of cleanup where some of the corners broke off from hand packing the sand and not using a air ram on it. The wood pattern is somewhat fragile and care has to be taken or it could break. Anyway the shrink came out just right very pleased and after fully polishing this one inside and out it will be the main pattern for making many more. I`ll post more pictures after I get it polished up.
Louis Samba Member
Joined: September 26, 2007 Posts: 423 Location: canada BC
Posted: Wed Jun 24, 2009 2:20 pm Post subject: |
wow impressive work with out cnc!! old school, pure essence of vintage speed...
cheers |
faster Samba Member
faster Samba Member
Posted: Wed Jun 24, 2009 5:33 pm Post subject: |
Well I had to see how it fit so after alittle polishing on it went. Very pleased the seal has plenty of room it looks like its touching in the picture but its not. Now I have to finish polishing the rest of it and back to the foundry.
Posted: Mon Jul 06, 2009 11:12 pm Post subject: |
faster wrote: |
Any more progress? _________________ Stocking distributor of "The Funky Green Panels"
