Perfect Tow Bar for Early Type 3 and Dimentions
pedro sainz
pedro sainz is offline
PostPosted: Tue Jun 23, 2009 11:11 pm    Post subject: Perfect Tow Bar for Early Type 3 and Dimentions Reply with quote
I had to built my own tow bar a month before the Classic 09
to pack my truck with roof racks and also tow my Notch
i only had the time to powder coated one half
this is what I came up
6' feet long
2 piece tow bar for easy storage inside of my truck
I bought a bug tow bar for $10
bugs tow bars are 30 inches wide
Type 3 only needs 24 inches wide so I cut
ALL the welding area
and made it 24 inches wide and weld it again
and you can see I ADD the other half 2X2 square for easy slide
in the round tubing
needs to be exact 5 1/2 inches tall brackets support
smaller or longer would NOT WORK
and 3 1/4 apart inside dimentions
from San Diego to Irvine Ca. 65 to 70 mph
Ibjack on the T34 just checking few times on the freeway
ALL GOOD
We meet Rob Kings half way he saw it and like it too
90 degress turn on the gas station with the tail gate down and
a 9 feet 5 inches in my 6 foot bed bus roof rack hanging out and was far to touch the Notch
Jason saw me at the arrived at the Crown Plaza Hotel
No problems at ALL on or way back Jack make me buy a thick chain
and a bolt at Home Depot
68 T34 1600 Automatic
62 T34 Cabriolet Prototype
N.O.N.A member #3
The Truth is Out There
peaceful warrior
peaceful warrior is offline
PostPosted: Wed Jun 24, 2009 6:49 am    Post subject: Reply with quote
Pedro, are you going to begin making these on a one time basis? If so, I want one and I will send you a bug tow bar to start with. I don't have your welding skills.
LMK!
"Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian
Critter1
Critter1 is offline
PostPosted: Wed Jun 24, 2009 7:17 am    Post subject: Reply with quote
Very nice Pedro! What are the small round bar pieces for that are sticking out (3-4") on each side from the square tubing?
I went a different route for my tow bar set up. I did a super beetle style set up with tabs welded to the beam.
I really like what you've done here. You're a hell of a fabricator!!
Justin
Russ Wolfe
Russ Wolfe is offline
PostPosted: Wed Jun 24, 2009 7:29 am    Post subject: Reply with quote
Will it work with the Fuel Injected cars, since they have the fuel pump mounted to the backside of the beam to one side??
Nice work....
Gary: OK. Ima poop.
Notchback65
Notchback65 is offline
PostPosted: Wed Jun 24, 2009 8:48 am    Post subject: Reply with quote
Looks Great,I may have to build one of those..
pedro sainz
PostPosted: Wed Jun 24, 2009 5:28 pm    Post subject: Reply with quote
LMK!
Fabricate this by ORDER maybe
I'm sure there's someone near you can weld to SAVE
all the shipping cost if NOT
Yes i can built yours but NOT NOW
I'm a little behind with others projects
if you can wait
let me finish mine first completly
because I need TESTED I little more
and change the bolts for Quick Release Set Up
adding wheels and more
thanks for your patience
N.O.N.A member #3
pedro sainz
PostPosted: Wed Jun 24, 2009 5:33 pm    Post subject: Reply with quote
you have a GOOD EYE
since is NOT DONE yet
those two tubing sticking out from the sides
I going to slide TWO rubber wheels 2 1/2 big so
I can roll it under the Notch Cool
N.O.N.A member #3
pedro sainz
PostPosted: Wed Jun 24, 2009 5:40 pm    Post subject: Reply with quote
Nice work....
since I have NOT seen one where is mounted
i need to ask are they mounted left or right
upper beam or lower beam
the bracket is 3 inches wide and is mount lower beam
at the far end of the TWO sides
N.O.N.A member #3
pedro sainz
PostPosted: Wed Jun 24, 2009 5:43 pm    Post subject: Reply with quote
Real Easy
Go for it
I got ALL the numbers for you Cool
any questions just ASK
N.O.N.A member #3
chrisvuc
chrisvuc is offline
PostPosted: Wed Jun 24, 2009 8:39 pm    Post subject: Reply with quote
LMK!
x2
redbug74
redbug74 is offline
PostPosted: Thu Jun 25, 2009 2:19 pm    Post subject: Reply with quote
X3
Different Strokes for Different Volks
74 Standard Type 1
69 Squareback Type 3
55 Oval Type 1
gixxer 711
gixxer 711 is offline
PostPosted: Fri Jul 03, 2009 11:18 am    Post subject: Reply with quote
the one thing i wonder about is the pivoting action. a bug beam is round tubing where the bar mounts, however the type 3 beam is not. i wonder over the long term of going in and out of driveways and elevation changes, will it tear of the tow bar or the beam.
Danny
pedro sainz
PostPosted: Fri Jul 03, 2009 9:46 pm    Post subject: Reply with quote
Before I hook it to my truck I raised the towbar
just to see how high can I lift
before HITS the Bottom of the Notch
I was Very Happy
Good question Question
type 3 Beam is 3X3 square
NOT including top and bottom lip
ONLY where the towbar pivots
Idea that's why the TWO plates are 3 1/4 space in between
the is a 1/4 spacing to allow that
NOW this is ME
I just wanted to hook it up and hit the FREEWAY
get to the VW SHOW and park on the street remove the towbar and drive the Notch IN
you should have ALL pack with food and gas
READY to GO
there's NO need to go to the wal-mart store or 7-11 etc.
JUST HOOK AND GO
again this is ME
AVOID driveways as many you can
Gizbob will TEST my towbar SOON
he already came to pick it up
I will know his opinion
N.O.N.A member #3
Russ Wolfe
PostPosted: Fri Jul 03, 2009 10:13 pm    Post subject: Reply with quote
pedro sainz wrote:
Nice work....
If you mount in the 2 openings at the far end of the beam, then it will not work for FI cars. The fuel pump and filter are mounted to a plate on the right side opening.
Gary: OK. Ima poop.
pedro sainz
PostPosted: Fri Jul 03, 2009 10:56 pm    Post subject: Reply with quote
Russ Wolfe wrote:
pedro sainz wrote:
Nice work....
YES I search a 72 type 3 beam there's a plate welded on the right side
I already change the name of the topic
N.O.N.A member #3
