Lindoom Samba Member
RIOMX Samba Member
Joined: September 30, 2005 Posts: 1234 Location: La Crosse, WI
Posted: Tue Jul 07, 2009 10:04 am Post subject: |
Once I have the engine out, how difficult is it to swap the shroud? |
VWDruid Samba Member
Joined: June 14, 2008 Posts: 1192 Location: Boca de Ratones FL
Posted: Tue Jul 07, 2009 10:24 am Post subject: |
cumbersome with the generator hanging of it. 1 screw by the intake manifolds =2, Vbelt and gen strap.
if you have: hoover bit thermostat and flaps, you'll need to take the thermostat off take the one clip off the flap cross bar so it wont snag the hoover bit or oil cooler and the one bolt on the hoover bit holding it to the doghouse.
when you do get a new used doghouse make sure the fan sits right and you have the hoover bit foam around the cooler so it seals well in the doghouse.
edit: you have to detach the wire to the carb and pull out that little tube or it will hang on something and bend. _________________ 70 Westy, 2027cc "dual DRLA 40 m140 i55 wjdoc a165 p33 v30 "w100 straight cut 040 polished heads 1.25 rockers 1.5 A1sidewinder supertrapp muffler trans 091 coil SUM-850500 CDI universal svda Pertronix
http://www.storyofstuff.com/
It's not the straight cut gears It's the T.A.R.D.I.S. engine.
wanted Chameleon Circuit |
RIOMX Samba Member
Posted: Tue Jul 07, 2009 10:47 am Post subject: |
Just talked with a guy at CCC and ordered my tin. Also asked him about the shroud - he didn't sound too concerned and said that as long as it has an oil cooler in the back I should be fine. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jul 07, 2009 10:54 am Post subject: |
Maybe in a bug, but a bus is on the ragged edge of enough cooling most of the time, those heapo shrouds lack the internal vanes to smooth and direct the airflow to where it does the most good and most is wasted.
The new surround tin will be a big help but do find another shroud as soon as you can. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
RIOMX Samba Member
Posted: Tue Jul 07, 2009 11:41 am Post subject: |
Just what I needed. Thanks! |
