Bleyseng Samba Member
Posted: Mon Jul 20, 2009 7:12 pm Post subject: Have some pics and questions.... |
Where does the 4mm gas tank venting hose plug into????
What goes into the 2 holes here on the side?
Whats this black box for?
I have figured out the venting in the engine compartment finally.......
Thanks for the help.. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Ghiaddict Samba Member
Joined: November 20, 2002 Posts: 2632 Location: Now in Honea Path, SC
Posted: Mon Jul 20, 2009 7:24 pm Post subject: |
The hose should connect to a fitting on
the driver's side of your fuel tank. If you find
no fitting, you may have a replacement tank.
The 2 holes are for routing a fuel vapor vent hose
from the same area of the tank, but only on early Ghias.
It went directly to outside/atmosphere!
VW kept the same metal stamping there, even after
they no longer vented in that way. Hello EPA.
Black box is your flasher relay unit. _________________ ****************************
Karmann Ghia & Beetle parts available.
Convertible tops installed. |
