satchmo Samba Member
Joined: November 23, 2003 Posts: 285 Location: Crosby, MN
Posted: Tue Jul 21, 2009 7:15 pm Post subject: Wider tires with Manual Steering |
Hi All -
I have an 87 Weekender with the stock tires (185R14) and rims. It also has NO power steering. How will bigger rims and tires (like the Rhein rims and 205/65/15 Nokians) affect the steering? Will I be cursing as I try to pull into the grocery store parking space?
Thanks in advance, Tim |
SteveVanB Samba Member
Joined: June 01, 2008 Posts: 1645 Location: This side of Daytona
Posted: Tue Jul 21, 2009 7:34 pm Post subject: |
If you have a non p.s. steering wheel it's not so bad.....the p.s. wheel makes it a little easier to curse _________________ 91 CARAT |
Posted: Tue Jul 21, 2009 8:27 pm Post subject: |
I have run 215/70R14's for years and have never had a complaint. |
wbx Samba Member
Joined: April 11, 2005 Posts: 1254 Location: Monterey, CA
Posted: Tue Jul 21, 2009 8:46 pm Post subject: |
I've found that appropriately stiff sidewalls help make turning the wheel while stopped easier (you are not fighting the sponginess of the tire). Once you are rolling at all, it is all about the same. _________________ '84 Westy (first owner).......but my daily driver has pedals
My "perspective" mantra:
A Volkswagen Vanagon is just a material thing,
As such, it is of the earth,
And if i need to, I can let my Van go. |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Wed Jul 22, 2009 3:19 am Post subject: |
wbx wrote: |
.... Once you are rolling at all, it is all about the same. |
That's it right there.
I had an 86 without power steering, and I put on the smaller diameter rabbit wheel, AND I put on 225 section tires.
As long as it was moving at all I actually preferred it to power, especially on the highway. The only time I wasn't crazy about it was parallel parking. Bit of a bear. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Posted: Wed Jul 22, 2009 6:35 am Post subject: |
levi wrote: |
wbx wrote: |
The only time I wasn't crazy about it was parallel parking. Bit of a bear. |
That's what I figured and why I asked. I actually prefer the manual steering on the hiway. It's the pulling on the steering wheel while parking or stationary with bigger tires that I don't relish since I do a fair amount of that.
Thanks, Tim |
vwjoel Samba Member
Joined: April 14, 2006 Posts: 205 Location: Seattle WA
Posted: Wed Jul 22, 2009 7:00 am Post subject: |
I've got LT215/75R15 light ruck tires on my 84 with manual steering and It's got the Ronal 9 spoke wheels off a Passat. I also instsalled a later dash with and the smaller steering wheel intended for power steering. To top that off I changed the front uprights to the later type for the Audi brake conversion. The Ackerman arms look shorter on the uprights I installed. Of course when it's moving it is fine but parallel parking is a bit of work. My wife is the only one that complains but she can parallel park it down town on a hill if she needs to. |
MSwart Samba Member
Joined: February 13, 2009 Posts: 49 Location: South Africa
Posted: Wed Jul 22, 2009 11:50 am Post subject: Tyres |
I have 205's on my van. When going very slowly you sometimes have to put in a bit of extra effort to turn the wheel. My wife drives to the shops and back during the day while I am at work and she hasn't complained about the steering at all, so I do not think the steering wheel is to difficult to turn. _________________ '89 2.1 |
