VisPacem Samba Member
Joined: July 15, 2007 Posts: 1143 Location: Las Vegas
Posted: Thu Jul 23, 2009 11:38 pm Post subject: Fuel level sending unit, aftermarket |
Howdy
I have (installed) a VDO 52mm black Cockpit series fuel level gauge on the van.
I need the sending unit for this gauge.
So I email EGauges and ask which of the several items they offer should I order:
0-30 ohms
0-90 ohms
10-180 ohms
240-33 "classic"
240-33 ( i guess not "classic")
90-0 Ohm Tube Type Senders for Adjustable Gauges - VDO
240 - 33 Ohm Tube Type Senders - ISSPRO
I get an answer telling:
Measure the ohms at empty ( ok no prob here)
and
when full (sic)
Now how do I measure ohms:
1- on a full tank that is not yet installed as I would obviously prefer to install said sending unit before mounting the tank
2- without a sending unit to activate the gauge as I am trying to acquire said sending unit.
My logic has failed me here. Perhaps one of you wizards can translate for me.
Now as a preventive measure for my sanity and not wanting to incur the blazes that another member received (inlcuding mine ) I shall explain
I want and have an auxiliary aftermarket 52" VDO black cockpit series fuel level gauge because:
1- I am mounting an auxiliary tank
2- Because for safety, speed of reading I do not want the OEM gauge to read both
3- Because I had the gauge
4- I like the look on my dash instead of an empty hole
I shall be delighted upon request to explain:
why I want an auxiliary tank
why I want a gauge for it
Why I chose a VDO black Cockpit series (I would have preferred a Smith but harder to locate)
why my auxiliary tank is round
For most anything else, I shall only speak in front of my attorney
Thanks _________________ LG aka VisPacemPB, *The* party Pooper
No Regrets (Nothing to do with Vanagons) |
Posted: Sat Jul 25, 2009 2:15 pm Post subject: Re: Fuel level sending unit, aftermarket |
VisPacem wrote: |
Howdy
Well I guess this Gordian Knot like question has also successfully defied the logic and expertise of the customary friendly experts here and no one can make sense of it.
I cannot make sense of it either
I just thought I would ask and would like to thank all who read my post
Cheerio aka VisPacemPB _________________ LG aka VisPacemPB, *The* party Pooper
ProvoCyclist Samba Member
Joined: December 07, 2004 Posts: 593 Location: Murray, Utah
Posted: Sat Jul 25, 2009 2:32 pm Post subject: |
Explain to me why you have "no regrets".
Id think you could get the ohm reading from the appropriate connectors at the instrument panel, but i could be wrong.
oh, uh, i just re-read your post. yeah, nevermind on my suggestion. _________________ Clark
Current: 1986 Tintop GL 2wd, stock 2.1L, manual trans, Flash Silver LP7Y.
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A |
motelvw Samba Member
Posted: Sat Jul 25, 2009 4:46 pm Post subject: |
Are there any indications with the gauge that indicate what range it operates at? Can you get specs online? I don't know why but your post made sense to me. |
