What did you do for your Bus today?
Page: Previous  1, 2, 3 ... 217, 218, 219 ... 638, 639, 640  Next
swervyjoe
swervyjoe is offline
PostPosted: Sun Jul 26, 2009 1:33 pm    Post subject: Reply with quote
Got back from picking it up from Lakeland, FL. Nick and I left DC Wednesday night and pulled into Denver yesterday morning. Thanks, Nick!
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Sun Jul 26, 2009 3:06 pm    Post subject: Reply with quote
Test fit front floor
Went in pretty easy, a couple little tweeks and it will get welding in. Getting close.
"no more hacking my sig line"
spiderjames
spiderjames is offline
PostPosted: Sun Jul 26, 2009 3:15 pm    Post subject: Reply with quote
New wheel cylinder, flex hoses and metal lines in the rear. Now all four wheels stop at the same time.
"A cranky transporter's a mighty finicky piece of machinery to be gambling your life on, Sir"
onebadoval56
onebadoval56 is offline
PostPosted: Sun Jul 26, 2009 3:29 pm    Post subject: Reply with quote
finally got done stripping the paint
what do you guyss think?
1955 oval
1956 oval
1960 euro bug
1962 15 window delux
1963 double cab
mannys66
mannys66 is offline
PostPosted: Sun Jul 26, 2009 5:20 pm    Post subject: Reply with quote
replaced the broken generator pulley
dieselnut
dieselnut is offline
PostPosted: Sun Jul 26, 2009 5:52 pm    Post subject: Reply with quote
Polished the turd...
Slowlow Premium Member
Slowlow is offline
PostPosted: Sun Jul 26, 2009 6:14 pm    Post subject: Reply with quote
Took mine to a show over the weekend. Swapped parts with it, Slept in it. Spent some time under it adding gear oil, but still crapped out a tranny on the way home.
BUT I made it home, so the bus did me well, exceptionally well for how gnarly that tranny was growling! Laughing
Metal Fab & Quality Suspensions, Type I-II-III. Since 2004
ekimikem
ekimikem is offline
PostPosted: Sun Jul 26, 2009 7:15 pm    Post subject: Reply with quote
I'd be happy to wipe that turd off your hands.
ScottMcW
ScottMcW is offline
PostPosted: Sun Jul 26, 2009 7:43 pm    Post subject: Reply with quote
Any guesses as to what I did today? Smile
It's all better now. Yay gears!
Read the story of Vern as it unfolds
scvw
scvw is offline
PostPosted: Sun Jul 26, 2009 7:48 pm    Post subject: Reply with quote
I've see that before the first time I tried backing my bus out of my driveway.
58 Coral Red ragtop(Diana's car)
57 PG/SG standard
SOUTHERN INTEGRITY AIRCOOLERS
WTB - Sigla popout glass like in my ad.
http://www.thesamba.com/vw/classifieds/detail.php?id=1667775
fizzbang
fizzbang is offline
PostPosted: Sun Jul 26, 2009 10:02 pm    Post subject: Reply with quote
- New brakes
- couple brake lines,
- cleaned 20 years of barn dust off
- new 6v battery
- drained 6 gallons of turpentine from the gas tank (thanks for the help Jadd...)
- flushed gas system
- Random parts to get the motor to run
- Drove it!!!!
blackdog1999 Premium Member
blackdog1999 is offline
PostPosted: Sun Jul 26, 2009 10:27 pm    Post subject: Reply with quote
Very nice singlecab.
I finished up my 65 DD Panel today. Changed the forward cargo door on the driver's side from a blue/white window door to an OG paint Velvet Green panel door with a EZ camper window cut in.
Home of the one true split Bus Motorhome
crofty
Judas of the North
crofty is offline
PostPosted: Mon Jul 27, 2009 9:46 am    Post subject: Reply with quote
obus wrote:
is that those hi miler ones?
Yep.
When in doubt, logo it out!!
HamburgerBrad wrote:
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Mon Jul 27, 2009 9:58 am    Post subject: Reply with quote
Pulled the beam out of the 67 and spent one solid day scraping/picking 42 years of petrified grease and goo off of it prior to tossing it in the back of the truck for a trip to the local self-serve carwash. Wife and two little daughters suited up and helped to pick and scrape. Tossed nine pounds of krud into the trash when all was said and done. My back is sore.
Center pin, original to the bus, is still completely without discernable play, and super smooth. Amazing. Scratch that off the list of things to do.
Brake cylinders, marked Varga, were 50% ok. One left and one right were seized, and pistons could not be dislodged with either 120 psi compressed air or a C-clamp, or both. Others were ok after a hone, as they had not been leaking. I will reuse the cups. Could not get the left side hard line out of the cylinder, even after using heat and a vise, but that cylinder was wasted anyway. Hope to be painting and reassembling with rebuilt Rizzag spindles by next weekend.
I'll be spending some QT with the wire brush on the buffer this evening, cleaning up all the hardware as well as the two rusty wheel cylinders that I am going to reuse.
edit to fix typo
Getting closer!
crukab
Samba Chef
crukab is offline
PostPosted: Mon Jul 27, 2009 10:27 am    Post subject: Reply with quote
Got a '56 Dove Blue type 2 running, been off the road snce '99 or so, ran great, brakes clutch ect. Drove it around the property, what a trip. Laughing
Welcome to the world Fenner Voss H. our 1st Grandchild 4-9-19 !!
Tom
My Pops:
In the yard right now:
'65 Bus/Panel/camper W/T
'65 Bug
'66 Singlecab
'79 Westy
'86 Doublecab W/T
crusty67t2
Trailer Park King
crusty67t2 is offline
PostPosted: Mon Jul 27, 2009 10:36 am    Post subject: Reply with quote
glad to see it didn't get cut up!! Very Happy
62 original paint Turkis double cab
59' rag top
thom
thom is offline
PostPosted: Mon Jul 27, 2009 7:49 pm    Post subject: Reply with quote
Installed an exhaust tip and splash pans on the '56 single cab
-Thom
1956 Single Cab
1957 BMW Isetta
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1957 Westfalia single cab
1963 Type 3 Karmann Ghia
1963 Unimog 404
thom
thom is offline
PostPosted: Mon Jul 27, 2009 7:52 pm    Post subject: Reply with quote
I've been fighting with the nose pieces still. Trim, fit, cuss; lather, rinse repeat. I think I'm going to have to make major mods to the V skin piece - the lower flange isn't 90 to the face and the curvature is off, so I'll have to make a bunch of relief cuts and re-bend the flange. Although I haven't tried to fit it in place yet, it doesn't look like the V shape will match the nose, so that will need some massaging as well.
-Thom
1956 Single Cab
1957 BMW Isetta
1963 Unimog 404
campingbox
campingbox is offline
PostPosted: Mon Jul 27, 2009 8:26 pm    Post subject: Reply with quote
fizzbang wrote:
That metal brakepipe is installed wrong, although its hard to tell if it will foul anything.
hugheseum
hugheseum is offline
PostPosted: Mon Jul 27, 2009 9:33 pm    Post subject: Reply with quote
that single cab is awesome!
Have a great day!
Page 218 of 640
