Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Thu Aug 13, 2009 6:30 pm Post subject: Voltage regulator differences between 55 & 70? |
I checked my Bentley and found nothing. Is there just one VR for the charging system or is there a specific VR depending on the alternator (55A or 70A) being used? _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51124 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Aug 13, 2009 6:54 pm Post subject: |
Just one, works for both outputs. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Aug 13, 2009 7:57 pm Post subject: |
busdaddy wrote: |
Just one, works for both outputs. |
Short, sweet, & to the point. Thanks! _________________ Toby http://www.aircoolednut.com/
Mr. Loaf Samba Member
Joined: March 30, 2005 Posts: 2098 Location: Okra, Oklahoma
Posted: Thu Aug 13, 2009 11:31 pm Post subject: |
Yep, And if you do not need an original the electronic one at your local FLAPS will work great! _________________ Never drive faster than your Angel can fly
$24,100 was too hard to resist................. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Fri May 06, 2016 9:41 am Post subject: Voltage regulator ID |
This is and old thread that I will ad to rather than starting a new one.
These are a date sequenced collection of 6v voltage regulators Made in Germany:
from bottom to top with changes
2K February 1954 round housing all screw terminals 160 watt
4L April 1955
5L May 1955
2P February 1958 square housing painted black all screw terminals slotted screw for cover 160 watt
7Q July 1959 riveted cover 180 watt
1S January 1961 slotted screw with white putty on cover spade terminal for +61
3U March 1963 Phillips screw on cover had white putty
407 July 1964 all screw terminal (dealership replacemtn?) Unpaiinted white putty on cover screw
Garbe Lahmeyer make- Two of them on the left of the row. No date stamp but known to have been used during this time period. Aluminum "VW" cover spade terminal for # +61 VW# 111 905 801 C
124 April 1971 Black putty on cover screw 190 watt
627 July 1976 not supposed to be painted black 190 watt
244 April 1982 slotted cover screw black putty
350 October 1983 not supposed to be painted black
367 July 1993 Still "Made in Germany"
The regulator resting on the license plate has no date stamping. _________________ Roads Scholar &
Posted: Fri May 06, 2016 1:45 pm Post subject: Re: Voltage regulator differences between 55 & 70? |
Here is an example of the regulator that preceeded the ones shown above. It is known as the "D" regulator due to its shape.
1961 (October)Single Cab- Road Trip Workhorse |
glutamodo The Android
Joined: July 13, 2004 Posts: 26309 Location: Douglas, WY
Posted: Fri May 06, 2016 2:02 pm Post subject: Re: Voltage regulator differences between 55 & 70? |
Tasb, the original post was regarding 55 amp and 70 amp alternators and their voltage regulators... which are Type 4 Bus alternators. _________________ Andy T.
Posted: Sat May 07, 2016 8:19 pm Post subject: Re: Voltage regulator differences between 55 & 70? |
Yep, thanks Andy, I did a search and this is the thread with the title that matched best I'll see if there is a way to move the information to a better posting. _________________ Roads Scholar &
Posted: Sat May 07, 2016 8:27 pm Post subject: Re: Voltage regulator differences between 55 & 70? |
Great stuff, thanks for posting, I know that takes time. I can't be the only one with a box-O-regulators who wonders what they fit.
Perhaps a link in the FAQ's of the other applicable forums that jumps to your post on opening would be the best option? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
