Broken Steering Shaft Coupler
Page: 1, 2, 3, 4, 5  Next
BuggyMeister
BuggyMeister is offline
PostPosted: Sun Aug 16, 2009 8:18 am    Post subject: Broken Steering Shaft Coupler Reply with quote
I was driving my son to a boyscout BBQ fund raiser yesterday when I noticed the steering feeling a little sloppy as I turned into the parking lot. It wasn't too bad, it felt like it maybe was coming loose from the steering box. So I pull in to a parking spot and peered under the left front fender. Shocked
BuggyMeister.com
Es ist eine luft abgekühlte sache... das sie nicht verstehen würden!
Translation: It's an air cooled thing... you wouldn't understand!
sturgeongeneral
sturgeongeneral is offline
PostPosted: Sun Aug 16, 2009 8:26 am    Post subject: Reply with quote
At least it was an easy fix. And things really could have gotten hairy on the freeway! Glad you are ok!
Street legal fiberglass rocket ship
2005 Lotus Elise supercharged
1974 Chevy Corvette
My fiberglass car collection!
In honor of bowtie56jw:Another victim of the nasty "C" Praying for ya Jeff!
My exwife said if I towed home one more bug she would leave me. You know, every once in a while I miss her
BL3Manx
BL3Manx is offline
PostPosted: Sun Aug 16, 2009 8:33 am    Post subject: Reply with quote
The OE couplings were fabric reinforced.
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D111%2D415%2D417%2DMX
Dale M.
Dale M. is online now
PostPosted: Sun Aug 16, 2009 9:21 am    Post subject: Reply with quote
Another application where using urethane products is very questionable......
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
drclock
drclock is offline
PostPosted: Sun Aug 16, 2009 9:27 am    Post subject: Reply with quote
Go OE and be safe ~
didget69
didget69 is offline
PostPosted: Sun Aug 16, 2009 9:45 am    Post subject: Reply with quote
Glad to see that no one got hurt & you proved out your forum name... Shocked
Bryan
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
BuggyMeister
PostPosted: Sun Aug 16, 2009 9:58 am    Post subject: Reply with quote
It was a real easy fix, my brother did it while I was serving brats and pulled pork. He replaced it with a genuine VW steering coupler.
I was thankful that it happened in a parking lot. At this point I still was able to steer but it was REAL loose so traveling at a higher speed it could easily have drifted in any direction.
BuggyMeister.com
dirtbugger
dirtbugger is offline
PostPosted: Sun Aug 16, 2009 2:49 pm    Post subject: Reply with quote
One of my buggy buddies over here in Oz had the same thing happened to one he had after only being on for a few months. I had a reasonably new one I got from the same shop so I ducked under my buggy to see how it was going.
Sure enough, it had a dirty big crack in it.
OEM if possible for me from now on and I'd seriously urge anyone who has bought a so called urethane couple for under 10 bucks to grab a torch and jack and have a real close look at it.
MURZI
MURZI is offline
PostPosted: Sun Aug 16, 2009 3:17 pm    Post subject: Reply with quote
I have seen tranny mounts do the same thing. I try to use RUBBER on everything. That red stuff is junk....on just about everything. I don't even use the trailing arm bushings....
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
mwcopi
mwcopi is offline
PostPosted: Sun Aug 16, 2009 6:02 pm    Post subject: Reply with quote
You made me a believer. Im going back to oem.
vincent9993
vincent9993 is offline
PostPosted: Sun Aug 16, 2009 6:10 pm    Post subject: Reply with quote
It would be nice to hear about the circumstances. I've also heard bad things about urethane but I run that coupler and have not seen any evidance of fatigue. And you all know that I drive my buggy!
Is the steering shaft at a sharp angle? Does the buggy see a lot of off-roading? Just curious.
MURZI
MURZI is offline
PostPosted: Sun Aug 16, 2009 9:23 pm    Post subject: Reply with quote
No....they are just junk
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
Dale M.
PostPosted: Sun Aug 16, 2009 9:32 pm    Post subject: Reply with quote
Urethane may make great bushing for torsion bars but makes lousy shift couplers and steering couplers.......
When I was rebuilding my buggy from ground up everybody I came into contact with said stay away from urethane products.... I'm glad I did...
Dale
BuggyMeister
PostPosted: Mon Aug 17, 2009 5:34 pm    Post subject: Reply with quote
This coupler began its life on my buggy in spring of '06. The steering shaft is straight with no angle at all, and the buggy has never been off road.
BuggyMeister.com
vincent9993
PostPosted: Mon Aug 17, 2009 5:45 pm    Post subject: Reply with quote
Wow, very disturbing... One would think they should outlaw this product... I probably threw away the warning that said this was for off-road use only, who knows.
You made me a believer and I've got my next week-end mini project cut out for me.
If only I had the time to work on the buggy, seems we're always out driving it! I supose our Canadian winter will be here soon enough.
How about sending a copy of this thread to all our sponsors on this forum that carry this product. I mean, most of them carry the OEM one anyways, no?
lostinbaja
lostinbaja is offline
PostPosted: Tue Aug 18, 2009 5:03 am    Post subject: Reply with quote
I would be sure to take it back for a refund. The money isn't the point the point is that there needs to be some documentation on the books that they are actually failing.
Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92
66 Shorty
66 Shorty is offline
PostPosted: Tue Aug 18, 2009 5:32 am    Post subject: Reply with quote
That's not the first time I've neard of or seen this happen! As mensioned earlier, the shift couplers fail as well! I also try to use OE RUBBER on EVERYTHING! Urethane squeaks like a bitch too, if it's not greased enough with enough of the proper grease too! Rolling Eyes
Glad you are OK! That would REALLY be bad if you were on the freeway!
~X-Man~
'60's Spatz Buggy body on '74 Chassis (Budget Build)
'69 Bug (Baja-to-be partial daily)
'10 Silverado (My daily)
dirtbugger
PostPosted: Tue Aug 18, 2009 1:53 pm    Post subject: Reply with quote
I managed to find that Pic of the coupler on my mates buggy.
It was only months old and as you can see from the condition of all the surrounding hardware, the buggy had never rolled a tyre in the dirt.
NatedoggAZ
NatedoggAZ is offline
PostPosted: Wed Aug 19, 2009 1:00 pm    Post subject: Reply with quote
Wow - that is just not right...and it just plain sux!
Before I placed my mini-order with CIP1 a few months ago I spoke to the CIP1 sales guy. I bought both a red urathane steering and shift coupler - EMPI brand.
I asked him about the urathane performance and he had "sold" me on the fact that the are supposed to last longer...
...after seeing that - how could urathane be trusted at all?
Yes, I am sure that there are some people out there that never have problems with it - but when could they be due...
It doesnt look like urathane gives any warning as to when it is going to give up. At least with rubber it could still show signs of wear...
...just my .02
ND
**Save our Mother Earth!
**Dispose of used motor oil properly!
++ One gallon of used motor oil can contaminate up to 1 MILLION gallons of fresh clean drinking water !! ++
chris_parks
chris_parks is offline
PostPosted: Wed Aug 19, 2009 1:27 pm    Post subject: Reply with quote
Wow.
Shocked
That has me worried in several ways.
I am going to tear back in to the buggy again.
Thanks for the early warning, and I am glad you and yours are safe.
Question
This really drives home the value of this forum to me.
Page 1 of 5
