Herrbern Samba Member
Joined: May 04, 2008 Posts: 349 Location: Luxembourg, Europe
Posted: Mon Aug 17, 2009 12:48 pm Post subject: |
Well, let me tell you that the guy who changed your fuel lines hasn't done a good job. I am not in favour of putting those cheap plastic fuel filters in the engine compartiment and without clamps....
Too me, it's fire guarantee. It's very stupid. Put the fuel filter under the tank if you want one. Or replace the metal fuel filter in the tank if rusted. Note that the fuel pump also has a standard fuel filter, so there is no need to put those cheap plastic onces if the filter in the tank is in good condition....
What do other members think ? |
airkooledchris Samba Member
Posted: Mon Aug 17, 2009 1:07 pm Post subject: |
Is there a metal fuel filter inside the tank?
I tried scouring the fuel section in the Bentley just now but didn't see any mention of fuel filters at all. (and certainly no mention of those cheap plastic ones.)
ive got some nice clamps, just get some new hose and do away with the filters then? |
arthurnugen Samba Member
Joined: January 11, 2005 Posts: 3081 Location: The PNW, where "going green" means rolling with moss.
Posted: Mon Aug 17, 2009 1:15 pm Post subject: |
There should be a brass screen in the tank as I recall. It may not be there now, after 40+ years and who knows how many owners. It's ok to have a plastic filter in there, but don't put it directly above the distributor, like it was in the first pics. How it is now is fine, as long as it is not rubbing. If they replaced the lines, then slap some clamps on there. Two filters is overkill, though.
Arthur _________________
cdennisg wrote: |
Lawyers don't deserve buses. |
zozo wrote: |
Don't worry too much. You can always trust a lawyer. |
ALWAYS WEAR STEEL-TOE BOOTS IN THE GARAGE!
1965 Bus (Riviera camper)
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
1957 DKW 3=6: 3 cylinder 2 stroke! |
Posted: Mon Aug 17, 2009 1:19 pm Post subject: |
arthurnugen wrote: |
Arthur |
so which is the overkill filter then? the one coming from the tank to the pump or from the pump to the carb?
thanks for the great helpful info!
edited to add: Note I do now see the 'strainer' in the picture at the bottom of the tank. in the graph in bentley it almost looks like a screw coming up into the tank from the bottom where the hose connects. |
Posted: Mon Aug 17, 2009 1:28 pm Post subject: |
The one coming from the pump to the carb. _________________
cdennisg wrote: |
zozo wrote: |
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
Posted: Mon Aug 17, 2009 2:02 pm Post subject: |
thanks again...
back onto the bug, a few more pics..
6Kabrio7 Samba Member
Joined: July 22, 2006 Posts: 2387 Location: California
Posted: Mon Aug 17, 2009 10:56 pm Post subject: |
wow that one cleaned up nice _________________ 67 Convertible July 67 Yukon Yellow
67 Sedan May 67 Zenith blue |
KTPhil Samba Member
Posted: Mon Aug 17, 2009 10:59 pm Post subject: |
Get rid of both fuel filters or your polished turn will become a well-roasted turd. Plastic filters do not belong in a hot engine compartment. Put a metal one on the line coming out of the tunnel to the left of the tranny under the car. |
