can an 82 cali westi fi be converted to carburetor
sac1579
sac1579 is offline
PostPosted: Thu Aug 20, 2009 2:21 pm    Post subject: can an 82 cali westi fi be converted to carburetor Reply with quote
hello all,
my fi sucks and tired of fixin it. Can i put a carb kit on it
mightyart
mightyart is offline
PostPosted: Thu Aug 20, 2009 2:36 pm    Post subject: Reply with quote
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-5504
Randy in Maine
Randy in Maine is offline
PostPosted: Thu Aug 20, 2009 2:58 pm    Post subject: Reply with quote
Well if you are going to do that, install dual carbs not a weber progressive. That would be the worst possible set up. Ideally dual 2 barrel carbs would be best. Get them pre-set up for your application as they are not correctly set up out of the box. I would suggest buying them from aricooled.net or the type4 store.
You will also need a new rotary fuel pump like this 3.5psi one....
http://www.cbperformance.com/catalog.asp?ProductID=577
A good linkage will pay off big time.
Usually it is just more cost effective to fix what you have. What is the problem?
sonk
sonk is offline
PostPosted: Fri Aug 21, 2009 2:21 pm    Post subject: Reply with quote
Hello,
I have the same westy, but I think it might be illegal to put a crab on since your 82 westy needs to be smogged. A car has to be at least 30 years old before it does not need to be smogged. That means in 2012 you will be able to put a carb if im not mistaken..
Just my 2 Cents,
Sonk
simd0ggie
simd0ggie is offline
PostPosted: Fri Aug 21, 2009 2:29 pm    Post subject: Reply with quote
How does a crab work? Can I add one to my fuel injected van?
Crab-van, Crab-van, Tastes like crab, Drives like Van...
-Matt
'85 Westfalia w/EJ25, '14 Tiguan R-Line 4 Motion
"There are two possible outcomes: if the result confirms the hypothesis, then you've made a measurement. If the result is contrary to the hypothesis, then you've made a discovery.”
Randy in Maine
PostPosted: Fri Aug 21, 2009 5:50 pm    Post subject: Reply with quote
NH has no laws on anything. Literally nothing.
perrib
perrib is offline
PostPosted: Fri Aug 21, 2009 6:39 pm    Post subject: Reply with quote
Most FI problems are dirty connections changing the input values the ECM should see. If your good with electronics converting to mega squirt FI might be better than installing carbs. A set of dual 40s work well. The fuel pump needs to be controled by an early rabbit fuel pump relay that will turn off the pump if the engine is not running.
sonk
sonk is offline
PostPosted: Sat Aug 22, 2009 10:58 am    Post subject: Reply with quote
Thanks,,,
Thats Carb.. my bad.. hehee, maybe I should go back to school..
SoNK
?Waldo?
?Waldo? is offline
PostPosted: Sat Aug 22, 2009 11:06 am    Post subject: Reply with quote
Live free or die, mofo...
