oldskoolbug Samba Member
Joined: December 07, 2008 Posts: 434 Location: Toronto, Canada
Posted: Fri Aug 21, 2009 8:55 am Post subject: Where can I buy these? |
My new coil did not come with the electrical connectors, and I don't have any spares. Nor do I happen to have another coil. Does anyone know where I could get these? Aside from buying a used coil from someone, that is! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Fri Aug 21, 2009 8:56 am Post subject: |
You can use "piggyback" connectors on the single tabs.
silver billy Samba Member
Joined: November 23, 2008 Posts: 120 Location: Tempe AZ
Posted: Fri Aug 21, 2009 9:41 am Post subject: |
You have the wrong coil. |
Posted: Fri Aug 21, 2009 10:23 am Post subject: |
silver billy wrote: |
I purchased a Pertronix Flamethrower II coil, and as mentioned it did not come with the required connectors. Manufacturer must of assumed I was replacing an already existing coil, thus I could easily transfer the connectors over! Unfortunately, I don't have another coil kicking around.
Even in the manufacturer's photo, the connectors are not clearly not included. Does anyone have an old, used coil, they want to get rid of cheap? |
Michael Fischer Samba Member
Joined: April 20, 2004 Posts: 1585 Location: Salem, OR
Posted: Fri Aug 21, 2009 12:45 pm Post subject: |
Where you at? US?? I got some you can have. |
Mitey62 Samba Member
Joined: August 01, 2008 Posts: 537 Location: Everett, WA
Posted: Fri Aug 21, 2009 2:29 pm Post subject: |
Why don't you just use ring terminals? That's how it's supposed to work. |
KTPhil Samba Member
Posted: Fri Aug 21, 2009 3:00 pm Post subject: |
Mitey62 wrote: |
X2. Problem solved. |
lucille66 Samba Member
Joined: June 29, 2008 Posts: 633 Location: ORANGE COUNTY
Posted: Fri Aug 21, 2009 4:06 pm Post subject: |
Mitey62 wrote: |
Why don't you just fly out to where he's at and GIVE him some? Oh, that's right - probably because you don't have a plane ticket just like he doesn't have ring terminals. Use your head. Don't you think if he had these he would use them? |
azaircooled Samba Member
Posted: Fri Aug 21, 2009 4:44 pm Post subject: |
ring terminals are very cheap.
expense wise... |
Posted: Fri Aug 21, 2009 9:56 pm Post subject: |
lucille66 wrote: |
Mitey62 wrote: |
I was enjoying my "beverage" until it came squirting out of my nose, due to sudden and uncontrolable laughter! THAT was funny.
But seriously guys, this is a full restoration project that I'm undertaking. Its near completion, and the wire harness is new and beautiful, along with everything else on that car. To go and cut the connectors, only to have them replaced with ring terminals is a little "butcher" if you ask me, not to mention an impatient move. It would loose quite messy once installed on the coil. I would rather wait, and do it right. But thank you for the input, I do apreciate the suggestion. |
Posted: Sat Aug 22, 2009 4:47 pm Post subject: |
I think ring terminals would look MUCH cleaner than those giant things. Ring terminals you can tuck together, those things throw the wires in all directions. Do whatever, but I'd be looking at what they're obviously implying you should be using. |
sixty9fasty Samba Member
Joined: April 12, 2004 Posts: 1066 Location: crockett, ca
Posted: Sat Aug 22, 2009 5:21 pm Post subject: |
oldskoolbug wrote: |
lucille66 wrote: |
Mitey62 wrote: |
Doesn't sound like a "full restoration" if your using a flamethrower II Coil |
sickbug19 Samba Member
Posted: Sat Aug 22, 2009 7:04 pm Post subject: |
You should be able to find em at an auto parts store, you have the right coil. I had to do the same to mine, but I had several coils laying around and raided them off the spares. _________________ In loving memory of Mark Herbert 1959-2006 |
Sid Vicious Samba Member
Joined: February 03, 2008 Posts: 512 Location: Queen Creek, AZ
Posted: Sat Aug 22, 2009 7:17 pm Post subject: |
Local hardware store should have 'em, too. My local TruValue carries them. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Sat Aug 22, 2009 7:18 pm Post subject: |
You could convert to ring connectors. _________________ Glenn
Member #1009
#BlueSquare |
hkoch Samba Member
Posted: Sat Aug 22, 2009 7:20 pm Post subject: |
sixty9fasty wrote: |
Exactly! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32597 Location: Reading Pennsylvania
Posted: Sun Aug 23, 2009 5:37 am Post subject: |
djkeev wrote: |
hkoch wrote: |
Exactly! |
There is a big difference between a REBUILD and a RESTORATION. Some use the term RESTORE to mean REBUILD.
Restore is to put the car back as it was when it left the dealers showroom in 1967.
Rebuild is to make it road worthy using parts from any and all sources that work, not period correct but functionally usable.
I suspect this is a REBUILD.
Dave |
Perhaps I should use ring terminals! After all, ring terminals would make it "road worthy using parts from any and all sources that work", so I think I'll cut the wiring harness, and throw them on. After all, whats a REBUILD, without some non correct, but functionally usable parts?
Thanks for the comments guys, keep 'em coming. I find this highly amusing this far. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Sun Aug 23, 2009 8:48 am Post subject: |
Try your local wrecking yard. Take your coil and explain what you need. More than likely they will have a pile of old coils somewhere or at least one with those fittings in one of the automobiles in the yard. _________________ In Stereo, Where Available! |
Posted: Sun Aug 23, 2009 2:27 pm Post subject: |
Eric&Barb wrote: |
Try your local wrecking yard. Take your coil and explain what you need. More than likely they will have a pile of old coils somewhere or at least one with those fittings in one of the automobiles in the yard. |
Actually, thanks to a member of this forum, I will be receiving my much needed terminals in the mail. He was very generous, and mailed them to me early this morning. Just goes to show that there are some good people left in this world!
So once I receive them, I can continue with my rebuild! |
