Posted: Wed Apr 02, 2003 10:28 am Post subject: 69 brake help |
Just replaced cylinder that was bad. Bled brakes. There is stioll no pressure to brake pedal. She stops after a few pumps, but I thought the cylinder was the problem.
Any ideas???
Maggie |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Wed Apr 02, 2003 11:42 am Post subject: 69 brake help |
Shoes adjusted up? someone needs to adjust the shoes by turning the adjusting stars till the shoes just "scrape the drum". if they are not adjusted it takes several pumps to get the shoes out far enough to contact the drums, many people mistake this for air in the system.
It's a good place to start, but you could still have other issues... good luck |
Posted: Wed Apr 02, 2003 5:21 pm Post subject: 69 brake help |
keifer-
the dude at the local shop suggested replacing the 'adjusters.'
Any thoughts? |
glandnut 40 horses of Fury
Joined: February 26, 2003 Posts: 1432 Location: J-ville, FL
Posted: Thu Apr 03, 2003 7:54 am Post subject: 69 brake help |
Sometimes the adjusting stars will be rusted frozen, making adjustment impossible. Sometimes you can free them with a blunt punch and hammer, being careful not to shear off the adjuster tips. Sometimes you can even pull the drum off, pull the shoes and hardware, using the same punch and hammer pop the adjusters sideways out of the bores and clean em up. Lightly, and I mean very lightly grease the bores and slide the adjusters back in. If the threads are stinky, wire brush them up until the adjuster is free. Do it your self, it's a no brainer. |
Posted: Thu Apr 03, 2003 8:27 am Post subject: 69 brake help |
You are the best!
I guess I know what I'm doing this weekend.... |
Posted: Thu Apr 03, 2003 2:25 pm Post subject: 69 brake help |
Maggie- the "Idiot's guide" by John Muir is a great book for illustrations and general directions, especially for tune-ups, brakes, and suspension. Don't forget that when you go to pull the front drums off, the left front left drum will have reverse thread on the spindle. Instead of lefty loosey, righty tighty, it'll be opposite. Have fun, use brake cleaner, don't drop the bearings in the dirt. |
Posted: Thu Apr 03, 2003 4:43 pm Post subject: 69 brake help |
Thanks, glandnut I was too busy to follow up.
Maggie, good luck with it and do buy some new stars for the worst ones they are not that expensive and it may save you some aggravation... |
Posted: Thu Apr 03, 2003 6:54 pm Post subject: 69 brake help |
You guys are SOOOO good to me!
Thank you!!!
MAg |
Posted: Thu Apr 03, 2003 6:57 pm Post subject: 69 brake help |
oh... by the way. Where can I get this book? |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Thu Apr 03, 2003 7:55 pm Post subject: 69 brake help |
Chirco has them. There is usually a few on e-bay as well. Good luck. |
