hansie Samba Member
Joined: August 29, 2007 Posts: 476 Location: Beach Lake, PA
Posted: Tue Aug 25, 2009 5:34 pm Post subject: Oil coming out of overflow tube on fuel pump |
I have oil coming out of the over flow hose on my 1800 fuel pump. I am not useing the pump ,I have an electrial pump hooked up. A friend said just to leave the old pump hang there. We took it out for a run the other night and I didn't think I was going to make it back home. It is a used motor in the bus,it has a weber carb on it. I thought the carb needs to be rebuilt. Put the bus back in the garage . Went down tonight to pull the carb and there was about 2 quarts of oil on the floor. Can any one help.
Thanks Karl _________________ Karl Bower |
busdaddy Samba Member
hansie Samba Member
Posted: Tue Aug 25, 2009 6:08 pm Post subject: |
Thanks Busdaddy
I read two of the posts there. I hope I am right !! I guess I have a bad diaphagm in my fuel pump ,that is why I am loseing oil like I am. I guess I can take off the fuel and pull the rod and put on a cover plate and run like that -right ?
Thanks for any help !!
Posted: Tue Aug 25, 2009 7:02 pm Post subject: |
If you don't have an oil pressure gauge you may want to choose the shortened rod option, without a way to tell you'll never know the pressure has dropped until it's too late. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
hansie Samba Member
Posted: Fri Aug 28, 2009 12:54 pm Post subject: |
Well I guess I will shorten the rod,and make a cover plate. My big question now is why did my oil drain out of the little hose. I mean it draned all of it , with the motor shut off .
