RHD Notch Samba Member
Joined: April 06, 2007 Posts: 1412 Location: Joshua Tree, CA
Posted: Sun Aug 30, 2009 9:07 pm Post subject: Type 3 Headlamp Adjusters? |
I have a pair of NOS Headlamp Adjusters part no. 311.941.035A? They also have Hella and SB12 markings on them. My two T3 parts catalogs do not list list part number anywhere that I can find...Can anyone here narrow down what their actual application is? Thank you... _________________
Lind wrote: |
I am at the point where I hardly want to own anything that isn't original paint. |
campingbox wrote: |
I have some other projects I'd like to finish first and I want to drive this bus while I'm working on those to help stay motivated. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Aug 30, 2009 9:21 pm Post subject: |
My parts book does not list it either. That does not seem to be a good number. 311 941 039E is Bosch for RH traffic, and F is Hella.
312 941 039E is Bosch for LH traffic, and D is Hella.
But then mine is a USA version only, and does not show the European NON sealed beams.
Have you run the part number through Google? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
thenastyfasty Samba Member
Posted: Mon Aug 31, 2009 6:36 am Post subject: |
I bet you entered it into google the Euro style. 311.941.035A
I used the USA style 311-941-035A and 311 941 035A. I will have to remember that the next time I am searching.
Thank you. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Fri Sep 11, 2009 10:00 pm Post subject: |
Hey Russ & nasty...thanks for the help. nasty the link you provided was actually a BIG help. Thinking back, I aquired these when buying a lot of 70's Beetle parts, but the 311 part number through me for a loop...mystery solved. _________________
Lind wrote: |
campingbox wrote: |
