ratpanel61 Samba Member
Joined: November 04, 2003 Posts: 345 Location: Va Beach, VA
Posted: Thu Mar 04, 2004 12:48 pm Post subject: Ambulance Fan Switch Help |
I was just wondering if anyone can tell me how to determine if my ambulance fan switch is good or bad? The fans work fine one at a time hardwired to the test battery, but with the switch neither one works. is there a way to read it out with a meter? There's 6 posts on it for the wiring, but I can't figure out if it's good or not. I don't want to have to spend $100 for a new switch if I don't have to. Also where do the jumper wires come from and go to on the switch? Any help will be greatly appreciated. _________________ - '57 Sunroof Beetle (project)
- '73 THING |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Thu Mar 04, 2004 7:55 pm Post subject: |
Vintagebus has a copy of the '58 tech bulletin on how to install ambulance fans (Electric Ventilator Set) -- here's page 2 that has a picture & wiring diagram.
_________________ ~~~~~~~~
Radio Questions R Us - what'cha need to know?
"Out! Out! You demons of stupidity!"
Remember - You are required to get older but you are not required to grow up!
62 SC & 66 Bus |
bmx2c4me Samba Member
Joined: February 09, 2003 Posts: 642 Location: Maryland
Posted: Thu Mar 04, 2004 9:27 pm Post subject: wiring detail |
Make sure your ground contact is good or connect the neg to the battery directly. Make sure there is good contact (with continuity tester) at the screw terminals (so when you crimp a wire down it contacts well)
Basically the switch is a voltage drop with 2 settings full voltage or half voltage....One at least should work (switch position 1) which gives 6 volts to one (or both fans)
testing should be obvious based on the wiring diagrams. when the switch is on you should have continuity between all positive and negative terminals, just limited voltage at switch position 2. (see below)
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Tue Sep 22, 2009 9:08 am Post subject: |
Okay, I want to understand the operational theory of 6 volt fans. I have two sets of fans that will eventually be restored and installed into my '59 Double-Cab and '59 Double-Door Panel.
When the switch is turned to the low speed position, do both fans operate at a lower speed or does only one of the two fans operate? Mine aren't installed or ready to test yet, so looking for someone who has experienced this already.
Also, has anyone successfully reproduced the black knob (I have white knobs).
Last question, I've seen folks talk about blue and red lenses in the switch. What color would have been correct back in the day???
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Tue Sep 22, 2009 10:30 am Post subject: |
BulliBill wrote: |
Bill Bowman |
i had a problem with finding black knobs for my panel
i end up sandingthe ones i had down and painting them
rustolem satin black is a close match to the orig color _________________ '60 15 window walkthrough
why is there no sarcasism button on here? |
Posted: Tue Sep 22, 2009 11:08 am Post subject: |
I hadn't even thought of that! That could work too. I just figured that someone out there had probably cast them in black plastic by now... Thanks for the suggestion!
Bill _________________ I'm looking for these license plate frames for my fleet:
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
Posted: Tue Sep 22, 2009 11:30 am Post subject: |
BulliBill wrote: |
When the switch is turned to the low speed position, do both fans operate at a lower speed or does only one of the two fans operate? |
Both fans operate at a lower speed.
BulliBill wrote: |
Last question, I've seen folks talk about blue and red lenses in the switch. What color would have been correct back in the day? |
All of mine have red lenses in the knob. _________________ How to Post Photos
Transporter Samba Member
Posted: Tue Sep 22, 2009 9:52 pm Post subject: |
Bill, A couple years ago, I picked up a few german switches that had black knobs that were exactly the same as the white ones. I'll see if I can dig up any info from the seller. |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Wed Sep 23, 2009 9:46 am Post subject: |
I have a original sealing wax red set that has black switch _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
Posted: Fri Apr 18, 2014 6:11 am Post subject: |
This is copied from a post in the build thread from my '59 DC restoration, as it is great info for this thread too:
By the way, good news to report! I'm going to assist "ezcamper" and loan him a nice condition used black ambulance fan spacer ring which he will use to mold a reproduction ring for anyone in need of them to replace those cracked, broken or completely missing spacer rings on your ambulance fan switches. So in the near future you can contact him if you need a spacer ring for your ambo switch...
Stocknazi Samba Member
Posted: Fri Apr 18, 2014 7:09 am Post subject: |
BulliBill wrote: |
Bill |
Nice.
Any plans to make some black switch knobs? _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Sat Apr 19, 2014 7:08 pm Post subject: |
We talked this morning, and I don't think that Chad is planning to repro the knob in black, or ivory. He is borrowing my spacer ring to reproduce it. That is all that is planned... for now.
ezcamper Samba Member
Joined: January 10, 2001 Posts: 897 Location: Atlantic Beach, FL
Posted: Thu Apr 24, 2014 4:59 pm Post subject: |
Fresh out of the mold. Reproduction on the right.
_________________ I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
instagram is http://instagram.com/bullidriversteelworks |
Posted: Thu Apr 24, 2014 7:25 pm Post subject: |
Holy Crap! That is awesome, so mine is on the left? Hard to tell any difference!
Posted: Thu Apr 24, 2014 7:31 pm Post subject: |
Your original is on the left. It is shinier. The mold release dulls the copy. (normally I would not use mold release but I didn't want to break your original!!!)
I just made 2 more. Bill, I'll ship them to you on Saturday. You wanted 3 repops right?
Thanks again for letting me borrow it. _________________ I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
Posted: Thu Apr 24, 2014 7:53 pm Post subject: |
Chad,
Those look great.
Thanks for taking the time to make these. much appreciated. _________________ WANTED:
Thomas Jefferson |
Posted: Thu Apr 24, 2014 7:55 pm Post subject: |
No sweat, and no rush. Very impressive what some folks can do to help the rest of us out! Nice job, looks good. I guess the happy new owners of your rings can do what I did to the repro black ambulance switch knob. I used a Dremel drill with a small buffing wheel and plastic polish to easily shine up the matte-finish to a high luster.
Yeah, three would be awesome, then all of my "used" ambulances switches will have a nice condition spacer ring.
You need to set up an ad once you produce a few more of them and make some more ambulance fan switch owner very happy! Maybe your next goal ought to be "black" ambulance switch knobs?
I'm happy to have helped by loaning you the original spacer ring! Thanks for undertaking the reproduction of these! They look great!
Posted: Thu Apr 24, 2014 8:01 pm Post subject: |
ad placed. _________________ I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
