jdbs3 Samba Member
Posted: Mon Sep 28, 2009 11:55 am Post subject: Winter storage and resulting tire flat spots |
1990 Vanagon GL
Since purchasing the van second-hand, it has never seen winter. I park it in the garage for 6 months, inflate the tires to 50 PSI, put some gas stabilizer in, and remove the battery (else it drains within a few weeks).
I recently rotated the tires and am now getting a fair amount of uneven riding (shaking) at speeds greater than 40 mph. I was also getting a shake in the steering wheel from around 50 - 60 mph.
I took it to my mechanic who knows vanagons. He test drove it with me and then balanced the front tires; they were off a bit. He noted that the wheel balance might help, but based on the ride and when the shaking occurs, he expects I have a flat spot on the tires, most likely from letting the van sit for 6 months. Yes, the shake at 40 mph + is still there, though the steering wheel no longer shakes.
He also noted the shake will probably go away if I re-rotate the tires with the flat spot to the rear of the van. I will do this later this week.
The question is, when storing the van for a long period of time, how do I avoid this problem in the future?
thanks |
wasserbox Samba Member
Joined: April 08, 2008 Posts: 533 Location: Durango, CO
Posted: Mon Sep 28, 2009 12:03 pm Post subject: |
Put the van up on blocks. |
dubstar Samba Member
Joined: January 17, 2009 Posts: 1437 Location: New York
iceracer Samba Member
Joined: February 28, 2006 Posts: 949 Location: Milwaukee, Wisconsin
Posted: Mon Sep 28, 2009 12:46 pm Post subject: |
I have stored Vw's for years and never have had a flat spot yet. I do inflate the tires to the max though and when I think of it from time to time push the van/vw to a new spot even if it is 6 inches or so. Sounds like you may have other suspension issues. Try rotating tires and see what happens. You could also jack up each tire and spin it to see if you can visually see a flat spot. _________________ 86 Syncro Wolfsburg edition
63 Beetle (The Iceracer) |
