Progressive Weber 32/36 Intakes -Anyone know the difference?
risk
risk is offline
PostPosted: Sat May 19, 2007 8:02 pm    Post subject: Progressive Weber 32/36 Intakes -Anyone know the difference? Reply with quote
Putting a centermount progressive setup on my baja and have some questions....please don't offer chitty advice like "trash that pos weber" or "go for duals" or "good luck tuning that one". Thanks in advance!
Top intake & carb is about 10 years old, off a 1600cc dual port, empi brand I think. The other intake is a bit different. Notice the lower intake has longer runner tube. Any ideas on which one is better or what brand they are? Also, the weber has the port for vacuum and I can blow air thru it so I'm guessing that it works with a vacuum advance dizzy. I have three dizzys to choose from --009, 034 svda, and type k vacuum only--which one works best with this carb?
rterfert
rterfert is offline
PostPosted: Sat May 19, 2007 8:16 pm    Post subject: Reply with quote
Someone may have shortened the runners on the black intake??....I have run Many of the bottom style manifolds
(I bought a 20+ lot of new ones years back and finally used/sold the last one)
IMO As long as the runners under the carb have two seperate holes rather than an open plentum......they all work the same....
The open plentum seams to loose a little on the lower end and has more of a stumble.
again, IMO I think becuase the air velosity is slower?
Josh_crosson
Josh_crosson is offline
PostPosted: Sat May 19, 2007 11:41 pm    Post subject: Reply with quote
i think the one the carb is already hooked to is a holley intake for the bugapray. only thinkg i can come up with.
sammyphsyco
sammyphsyco is offline
PostPosted: Sun May 20, 2007 12:21 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=202712
http://www.thesamba.com/vw/forum/viewtopic.php?t=232158
I think you will find both of these links very helpfull with your choice of carb.
sammyphsyco wrote:
Your just jealous the voices are talking to me
risk
risk is offline
PostPosted: Sun May 20, 2007 11:46 am    Post subject: Reply with quote
Yeah, I read those threads when I did the search. I'm gonna pull the carb to see if the intake is open plenum or not. Still trying to figure out which dizzy to use.....
risk
risk is offline
PostPosted: Tue May 22, 2007 6:42 pm    Post subject: Reply with quote
Pulled the carb and noticed that the guy I got this from had used a time sheet to make a carb gasket. Nice, very nice....
Intake on the right is cast that way, not ported out. Anyone had experience using either of these intakes?
rterfert
rterfert is offline
PostPosted: Wed May 23, 2007 9:37 pm    Post subject: Reply with quote
As long as you have seperate throats for each barrel till it hits the cross section they should be/act like the same manifold.
As for the gasket (his rebuild kit) must have been a little vauge where it said paper gasket Laughing
risk
risk is offline
PostPosted: Thu May 24, 2007 8:59 am    Post subject: Reply with quote
the carb has a vacuum port .... can I use vacuum advance dizzy?? or am i stuck with 009?
grimace007
grimace007 is offline
PostPosted: Sun Oct 04, 2009 5:35 pm    Post subject: Reply with quote
i searched a buncha and instead of starting a new thread ill resurrect this one...
is the vacuum signal from a weber 32/36 string enough for a german 034 svda?
id like to ditch my utoh nine
and am about to send my 034 to be redone ( finally )
and dont have the cash to go back to dual carbs yet.
Brian
68 sedan
Dallas Air Coolers
perrib wrote:
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. Smile
cr@M wrote:
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory.
mharney
mharney is offline
PostPosted: Sun Oct 04, 2009 6:08 pm    Post subject: Reply with quote
Yeah, it has plenty of vacuum for an SVDA.
grimace007
PostPosted: Mon Oct 05, 2009 5:22 am    Post subject: Reply with quote
THANKS MARK.
Brian
68 sedan
Dallas Air Coolers
