andylocious Samba Member
Posted: Tue Apr 08, 2003 8:13 am Post subject: I think my transmission is out? Can anyone help? |
I was driving back home from work when all of a sudden the gears would kick back out into neutral. Worst of all I was going uphill on a brige! I had to shift in reverse and move about a foot or so, then i would throw it back into first. Even then the bus wouldnt give that much of a push. I noticed that the engine was really accelerated. Another thing i also noticed was that on my way to work my 3rd gear was overaccelerating the engine without much push. Could that have been the sign of what I experienced later that afternnon? Im guessing it could be the linkage or the clutch? Any help would be greatly appreciated. I have a 1600cc on a 70 bay.
-Andy |
koho60 Samba Member
Joined: February 21, 2003 Posts: 133 Location: Southern Utah
Posted: Tue Apr 08, 2003 1:01 pm Post subject: I think my transmission is out? Can anyone help? |
I have a 72 and I had the same (sort of) problem. Under the front of the transmission there is a hanger with two bolts. If the bolts are loose the trans gets out of alignment and your bus can and most likely pop out of gear.
JEFFRO |
Posted: Tue Apr 08, 2003 1:32 pm Post subject: I think my transmission is out? Can anyone help? |
Hey jeffro thanks for the tip! I will check that out after I get home.Hopefully it's that and not something major. I just got my bus 2 months ago from the shop with a new engine and brake job. I called the mechanic yesterday so ill check this out before i decide to take it to him. If you have any other tips please post them. I greatly appreciate your help.
-Andy |
Posted: Wed Apr 09, 2003 8:47 am Post subject: I think my transmission is out? Can anyone help? |
No luck, I tightened that screw that jeffro told me about but it just made my clutch pedal a little stiffer( which I actually like). But other than that the car wont move forward in any gear, It'll move in reverse only. Please Help!!! |
vwsrus Samba Member
Posted: Wed Apr 09, 2003 9:37 am Post subject: I think my transmission is out? Can anyone help? |
Andy, Your transmission is mounted differently than Jeffros. In his 72, it stays mounted to the trans mounts. In yours, there is a rear mount on the motor that holds everything up. Often when your motor is taken out, the trans isn't supported at level. This puts stress on the nose and through the shifter linkage.
Try this. Look under the bus where the shifter linkage would start. It has a plate to the front that sticks straight down (vertical). At the botom is a small rod or guide pin going horizonatl. This pin is welded to the plate and helps guide the shifter inside to the shifter linkage underneath. It acts as an elbow. This pin MUST be straight/horizontal. If it's not straight, it will shift real funky. I experenced that with my 71. Good luck |
