Sunroof53 Samba Member
Posted: Thu Mar 20, 2008 4:38 pm Post subject: Which air cleaner for July, 1953? |
Unfortunatley the previous owner of my car changed the original engine due to a broken crank.The car ,(i was building another engine for him ,which is how i came to end up owning it myself)came with a mid sixties 1200 with most of the original ancillarys on it .it seems though the car always had the air filter shown in the pic below ,but i am sure this is wrong .i think it should have the horizontal cylinder type ,but none of my books gives any accurate engine info.
oh, i now have a 30hp (couldnt find a 25hp)so it at least looks about right ,i just hope it doesnt need the really hard to find /expensive cylinder one.Car was built on 9th july 53
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Thu Mar 20, 2008 4:43 pm Post subject: |
I'm guessing your car is a '53? If it is, you'll want a single strap air cleaner. The air filter you currently have installed is a 1956-59 type.
While you're at it, change the rear apron |
Posted: Thu Mar 20, 2008 4:54 pm Post subject: |
RareAir wrote: |
i have considered using the repros made by auto craft ,unless you happen to have one for sale of course.
thanks for reply i will but both on my wish list. |
Freeform Metal Samba Member
Posted: Fri Nov 06, 2009 1:05 pm Post subject: |
Can someone help me with current price on this air cleaner. I have a chance to buy one, but not much in the classifieds to compair.
Thanks for the help.
Rob |
Posted: Fri Nov 06, 2009 3:01 pm Post subject: |
Never thought i would see this thread again.in fact i have a diifferent engine in the car now to the one posted above.After i posted this i had an email from someone offering to sell me one at 150 euros and decided it was way too much for what looked like a rusty example .The cylinder type is also correct for an early 53 and actually seem more common in the forsale area.
I still havnt got one ! Its really down to what you think its worth and how badly you want it .I still enjoy my car even with the wrong bits but if i stumble across the right stuff at sensible prices i would buy it of course.
I recently bought the correct pulley and for 20 pounds i dont begrudge the expense.
Posted: Fri Nov 06, 2009 3:37 pm Post subject: |
Thanks for the reply. It's just not cheap and I don't want to over pay. I don't really need it but you don't see them too often so I thought I would pick it up.
Any other opinions?
Any help is appreciated. |
Volumex Samba Member
Joined: October 11, 2007 Posts: 532 Location: Sarnia, ON
Posted: Fri Nov 06, 2009 9:46 pm Post subject: |
The 54/55 ones range from $200-300, depending on condition. A 53 one will obviously be a bit higher. |
Posted: Sun Nov 08, 2009 2:44 pm Post subject: Irony |
Fate it seems ,is not without a twist of irony as today i went to the Slough swapmeet here in the UK .Would you believe i found the filter for my car .It was missing part of the strap but it should be an easy fix .Of course its going to be a lot easier if one of you fine people post a nice close up pic of the strap so i can reproduce it
I,ll post a pic of it later tonight.Not bad for me to find a part in 1 year 8 months .53 only small arrow MPH speedo next!!! |
valentinesr Samba Member
Joined: June 30, 2008 Posts: 749 Location: Ontario, California
Posted: Sun Nov 08, 2009 8:13 pm Post subject: |
Not sure if anyone mentioned it or not, but there are two different styles of Single Strap Air Cleaners..There right, theres 54/55, then 53 has a style all of its own..Im sure if you check out Erics 53 Oval..youd see exactly what you need..something with the bottom lip of the Air Cleaner on a 53, I think....  _________________ Valentine, Ray J Sr.
Ontario, California
thebucket wrote: |
I gave my oval a nasty look. Money hungry bitch.... |
(Delilah) http://www.thesamba.com/vw/forum/viewtopic.php?t=319235
1954 Parts Book (CD PDF) PM TO INQUIRE |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71477 Location: Phoenix 602
Posted: Mon Nov 09, 2009 4:37 am Post subject: Right one |
This is the picture of the one i bought .I had done some research before from your pictures Everett so i knew i was on to a winner .The picture shows i have the buckle side of the strap and with Everetts pics i should easily be able make the other side.The overall length may be trial and error though . My only concern is the state of the filter material .Should i try and clean this with white spirit ? or leave alone ?
Atfer a clean
It cost me £120 .I felt pretty sick afterwoods but felt slightly better when i saw the later filter with the flange at £300!!!.In fact i only stayed an hour after and went home with a mild case of depression.
bwaz Samba Member
Posted: Mon Nov 09, 2009 9:47 am Post subject: |
thanks for the photos Everett... nice to see details! |
Posted: Mon Nov 09, 2009 11:37 pm Post subject: |
I made the strap today (one in picture was the first one,i have made them again since as i wasnt happy) but still need to spot weld the ends .I also took out the dents with a 10mm allen key ground to fit between the filter mesh and the top.Also removed paint.I am quietly pleased with the results:Big thanks to Everett for the pics and research into this.This site is unbeatable for this kind of inforamation.
Second strap made and filter stripped
Painted
On the car
Posted: Mon Nov 09, 2009 11:45 pm Post subject: |
Just for comparison here is another pic i found .Does anyone sell that sticker in english?
Posted: Tue Nov 10, 2009 8:13 am Post subject: |
The sticker in the ad looks like the one for the later filter.I will do a bit more searching.I am sure i have seen them on here as there was a debate on the position of it. |
bluethunder-1835 Samba Member
splitjunkie Samba Member
Posted: Tue Nov 10, 2009 1:36 pm Post subject: |
there were three styles of that air cleaner. The first had no strap, but had a wing screw in the center.
The second style was what you have. They changed from the wing screw to the strap
The third style added a metal lip around the edge of the filter element so it covered the gap between the element and the housing to prevent water from getting in.
_________________ Chris
