'64 vert, Java Green
Stanagon
Stanagon is offline
PostPosted: Thu Nov 12, 2009 7:14 pm    Post subject: '64 vert, Java Green Reply with quote
Recently acquired this '62 vert and have been looking for original paint. Front hood and front fenders are not original, engine lid may also have been replaced.
Front hinge reinforcment area sure looks like Java Green to me. The paint can shows some Java Green I squirted onto a '65 Bug earlier this year. I thought Java Green was a later color though. Anybody know if a '62 vert could be ordered in Java Green?
Also needs a new top, but it's been a driver and still is.
Stan's Classic Service, specializing in air-cooled VWs:
http://www.thesamba.com/vw/classifieds/detail.php?id=614073
www.stanagon.com
My '61 Mango bus thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=110367
My '64 vert thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=386344
My '71 squareback thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=637709
6Kabrio7
6Kabrio7 is offline
PostPosted: Thu Nov 12, 2009 7:46 pm    Post subject: Reply with quote
Nice looking vert..How much rust does it have underneath?
67 Convertible July 67 Yukon Yellow
67 Sedan May 67 Zenith blue
EMPIImp69
EMPIImp69 is offline
PostPosted: Thu Nov 12, 2009 8:00 pm    Post subject: Reply with quote
Hi Stan, I've seen you at Atco and Flanders..that vert is cool, it looks like Java Green started in '64 according to the archives. My '67 Vert was originally Java Green. You got any pics of the interior?
1969 Empi Imp #1325
1963 Ragtop Bug
Use this to balance your wide 5 steelies -->
http://www.thesamba.com/vw/classifieds/detail.php?id=1830990
Agave58
Agave58 is offline
PostPosted: Thu Nov 12, 2009 8:02 pm    Post subject: Reply with quote
Java green was only available from 64 to 67. Turquoise L380, and Beryl green L478 were offered in 62, but yet that looks Java green to me too?
1958 Agave Beetle (0\_!_/0)
Stateside Motors Inc
501 Foote Ave
Jamestown, New York 14701
Stateside Imported Cars/Motors Items Wanted
Sunland Motors
2030 Fremont St Las Vegas, Nevada
Sunland Motors Items Wanted
hitest
hitest is offline
PostPosted: Thu Nov 12, 2009 8:37 pm    Post subject: Reply with quote
Time to crack open the books. That body sure appears later to me. There are '64 and up clues all over- signals, license light (why is the brake res. there? I need photos inside to be sure. check other fittings like the rear view mirror, seats, etc. The dash says alot. I am not researching this much further- but didn't '65s have a flasher? All in all- the amount of Java alone departs it enough from my gulf blue '62 vert to call this a body swap.
FU#5
6Kabrio7
6Kabrio7 is offline
PostPosted: Thu Nov 12, 2009 10:38 pm    Post subject: Reply with quote
i didn't notice the license light..it looks swapped and is a different shade of blue. you can see where the bigger one was mounted that was taken off.
Stanagon
Stanagon is offline
PostPosted: Thu Nov 12, 2009 10:58 pm    Post subject: Reply with quote
Dash
Behind dash. Speedo might be stamped 2.64. I'll check tomorrow.
Rear seat has only upholstery that might be original.
Spare tire well with non-functional brake reservoir. Has been upgraded to dual circuit master with relocated dual circuit reservoir.
VIN# seemed to match title, but it's hard to read. Will need to look at it more carefully.
This convert has been modified and patched up in numerous places. But it's pretty solid and very driveable. Body swap is possible, perhaps also is an error in the year indicated on the title.
I have received a recent MA title from the previous owner who owned it since 2004. He installed a B-case motor from a '65 bus he had (not original to bus) that is still running good. Paint and modifications were done previous to his ownership.
www.stanagon.com
Stanagon
Stanagon is offline
PostPosted: Thu Nov 12, 2009 11:03 pm    Post subject: Reply with quote
The PO mounted the license plate light cover. It had a later one on it. I haven't checked the paint color on the inside of the lid yet.
www.stanagon.com
MANNAXMAN
MANNAXMAN is offline
PostPosted: Thu Nov 12, 2009 11:55 pm    Post subject: Reply with quote
The straight edge of the steering box access hole is vertical and on the left. On a '62 it should be horizontal and on the bottom. I believe they changed the orientation in '64, which would explain the Java Green paint.
It looks like the first three digits of the VIN on the tunnel are 337, which would make it Sept. '60 chassis ('61 model year).
Sounds/looks like a body swap to me.
Michael Fischer
Michael Fischer is offline
PostPosted: Fri Nov 13, 2009 12:06 am    Post subject: Reply with quote
The back seat cover is 64 only.
Stanagon
Stanagon is offline
PostPosted: Fri Nov 13, 2009 12:59 am    Post subject: Reply with quote
I'm starting to believe it's a '64 body. Any other things I could look at or take pix of to determine the age of the pan?
I still need to check and see if there are original seat covers or door panels under the current ones.
The VIN on the title is 4337104.
The VIN on the tunnel looks like 337??4.
The character to the left of the "33" in the tunnel VIN looks like it could be a VW symbol.
Thanks for all the help. I'm more of bus guy and haven't owned a Beetle in years, and this is the first convertible I've ever owned.
www.stanagon.com
fluxcap
fluxcap is offline
PostPosted: Fri Nov 13, 2009 3:08 am    Post subject: Reply with quote
Looks like it could be a 6 to me. Which would make the vin 633xxxx, which would be a May 1964 build date.
Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black."
DrDarby
DrDarby is offline
PostPosted: Fri Nov 13, 2009 7:36 am    Post subject: Reply with quote
I agree, Java Green with that upholstery, that is a 1964 convertible.
Midwest Autosavers, Inc. Cary, IL
6Kabrio7
6Kabrio7 is offline
PostPosted: Fri Nov 13, 2009 11:02 pm    Post subject: Reply with quote
It looks like someone really messed with the VIN..I hope it's not stolen. Probably just because of the body swap.
Teeroy Premium Member
Teeroy is offline
PostPosted: Sat Nov 14, 2009 1:04 am    Post subject: '62 vert, Java Green? Reply with quote
What number is on the body VIN plate?
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
hitest
hitest is offline
PostPosted: Sat Nov 14, 2009 9:39 pm    Post subject: Reply with quote
Ding ding- we have a winner! Spotted that upholstery right away- other clue: steering wheel and horn bar. Good spot Mannaxman on the cover plates.
FU#5
1-4-3-2
1-4-3-2 is offline
PostPosted: Tue Nov 17, 2009 7:22 pm    Post subject: Reply with quote
The rear seat material is specific to 64 beetles only and is not reproduced as of today. So java green, small windshield and that cloth should make it a 1964. My guess is that the year was typed wrong on the reg. at some point. I had a hell of a time earlier this year trying to explain to the RI DMV that my 68 beetle vin# was the engine #. A 40 year old DMV error. Good luck with it Stan.
1967 Sunroof Deluxe, L633 VW Blue
1979 'Vert, 97A Diamond Silver Metallic
1974 Standard, 31A Senegal Red
yachtybugger
yachtybugger is offline
PostPosted: Wed Dec 16, 2009 1:50 am    Post subject: Reply with quote
Also, the centre pressing on the decklid finishes early next to the light housing. That together with a t-handle indicates a 64 decklid as well.
Stanagon
Stanagon is offline
PostPosted: Sun Dec 13, 2015 9:10 pm    Post subject: Re: '62 vert, Java Green? Reply with quote
I recently fixed an oil leak on my '64 vert and was able to drive it again, after a year-plus slumber.
Oil cooler bracket broke away and caused a steady oil leak.
Motor back in and not leaking!
Took it for a cruise to see my buddy Cisco at his bike shop in Framingham, MA. That's his '66 bug.
Washed the vinyl top I installed a few years ago.
Took it to lunch at my favorite Mexican eatery in Framingham.
www.stanagon.com
Stanagon
Stanagon is offline
PostPosted: Sat Dec 19, 2015 2:06 pm    Post subject: Re: '64 vert, Java Green Reply with quote
I replaced the old, stiff steering box in the '64 vert this week.
Here is the old steering box in place. It was hard to turn and forget about wheel return after turning.
I first removed the tie rods to confirm the problem was with the steering box, it was.
New TRW steering box.
These mount studs need to be transferred from the old box to the new one. Mine came out with no problems after some cleaning and lube.
My old steering box was from a '55-'61 bug, which has a larger output shaft and different pitman arm.
Bug City in Berlin, CT supplied me with the used '62-'65 pitman arm, shown installed on the new TRW steering box.
'55-'61 pitman arm in foreground wouldn't work with new steering box.
New steering box installed. Also replaced the right side tie rod ends and greased the left side ones.
Much nicer steering now. Next step is an alignment.
www.stanagon.com
