scottf3334 Samba Member
Joined: May 26, 2006 Posts: 205 Location: Davenport, FL
Posted: Wed Nov 18, 2009 10:12 am Post subject: PO glued in my tranny main seal |
I've used the search feature, but can't seem to figure this one out.
I pulled the engine to fix what I thought was a leaky rear main seal. The engine main seal wasn't leaking, it was the tranny mainshaft seal. A search of thesamba and a vist to my local VW parts store got me a new seal.
Here is the part I need help with. I've tried everything to get the seal out in one piece. From wood screws to a tiny thin knife. I think gasket sealer was used instead of just pressing it in. Anyone have this problem before?
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Wed Nov 18, 2009 10:42 am Post subject: |
You will need to make a gasket puller out of a piece of 1/8" X 1" mild steel flat bar. You are going to shape it into a bit of a hook which you can insert alongside the input shaft between the shaft and the seal. Force it in there, turn it 45 degrees to engage the hook with the hard rubber back side of the seal, clamp a big set of vice grips or even a slide hammer to it, and start reefing on it. You may also be able to lever against the hook by prying against the trans housing itself, but be careful not to apply too much force in any one area or you can crack the alloy.
DON'T try to dig the seal out around the outer edge; you will score the trans case.
Don't pry against the input shaft, but also don't fret too much about your hook tool damaging it. It is hardened. Just smooth off the surface of your hook tool where it can touch the input shaft and you should be ok.
Reinstall the seal with a mallet and a piece of pipe to seat it evenly. |
Nor_AL_67 Samba Member
Joined: December 18, 2007 Posts: 663 Location: Huntsville,Alabama
Posted: Wed Nov 18, 2009 11:42 am Post subject: |
Major Woody wrote: |
Force it in there, turn it 45 degrees to engage the hook with the hard rubber back side of the seal, clamp a big set of vice grips or even a slide hammer to it, and start reefing on it. |
I learnt me a new word today _________________ 63 Sedan
61 Rag
67 Type 1 Sedan
63 Type 2 Standard Walk-thru
69 Ghia
68 912
Amateur Versus Rusty Bus! |
busdaddy Samba Member
Posted: Wed Nov 18, 2009 12:01 pm Post subject: |
Or just buy the tool from any FLAPS.
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Ian Samba Moderator
Posted: Wed Nov 18, 2009 12:02 pm Post subject: |
busdaddy wrote: |
Thats what you need. I need one too. _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
**ACHTUNG DO NOT USE AA BRAND PRODUCTS OR BUY ANYTHING FROM PACIFIC PARTS INTERNATIONAL IN CALIFORNIA** |
Daddybus Samba Member
Posted: Wed Nov 18, 2009 12:35 pm Post subject: |
Why buy when you can make your own. www.vintagebus.com has the local manufature VW workbook downloaded and it has the designs for "factory" tools that you can make at home. The seal puller is one of them. Item 270 or 273 or something like that. |
Posted: Wed Nov 18, 2009 1:30 pm Post subject: |
Daddybus wrote: |
Why buy when you can make your own. |
Because it's $10 or less and some people are handier with thier checkbook than files and saws _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Nov 18, 2009 1:36 pm Post subject: |
After lots of reefing and a little cussing, it is out. Thanks Everyone.
BTW I used small allen wrenches, vice grips and a crow bar. I hate having to take a shower and go to the store in the middle of a project.
Posted: Wed Nov 18, 2009 2:29 pm Post subject: |
Way to go, man. Whatever it takes! |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Wed Nov 18, 2009 2:33 pm Post subject: |
For future reference, the thin little bar with the flat rounded end that comes in some Toyota spare tool kits to remove the wheel covers also works well for removing that seal. _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
type1232000 Samba Member
Joined: February 19, 2006 Posts: 105 Location: Salt Lake City, Utah
Posted: Wed Nov 18, 2009 4:35 pm Post subject: |
"I hate having to take a shower and go to the store in the middle of a project."
My parts store guys would'nt recognize me without bleeding knuckles, filthy jeans and gear oil in my hair. _________________ 58 Panel, "The General Repairs Bus"
66 Kombi, "The Abominable Rust Bucket"
73 Riviera camper, Kasan Red
75 Riviera camper, Neptune blue
72 Sportsmobile camper, Sierra Yellow |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Wed Nov 18, 2009 7:19 pm Post subject: |
The new seal may not have a stop-lip on it so just stop flush with the case. A 1 1/2 pipe nipple works good as a putter inner tool. |
my65vert Samba Member
Joined: November 09, 2003 Posts: 6186 Location: Middleburg, Florida
Posted: Wed Nov 18, 2009 7:23 pm Post subject: |
Mmmmmmmm, nipple. _________________ OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Wed Nov 18, 2009 9:36 pm Post subject: |
79SuperVert wrote: |
For future reference, the thin little bar with the flat rounded end that comes in some Toyota spare tool kits to remove the wheel covers also works well for removing that seal. |
Photo please?
I can go trunk rummaging at my local junkyard, they have a billion old Toyotas in there. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Wed Nov 18, 2009 10:54 pm Post subject: |
BarryL wrote: |
putter inner tool. That is just awesome.
I too have used the small allen wrenches, but the FLAPS hook and the homemade version are likely a better choice. _________________ nothing |
Posted: Thu Nov 19, 2009 8:17 am Post subject: |
j.pickens wrote: |
Photo please?
I can go trunk rummaging at my local junkyard, they have a billion old Toyotas in there. |
I'll take a picture of the tool and post it here.
Picture posted below. _________________ Central Jersey VW Society
Stocknazi Samba Member
Posted: Thu Nov 19, 2009 5:28 pm Post subject: |
i always dab a little permetex gasket sealer on the outside of the seal.
vintagebus.com has the workshop tools for local manufacture book. it has the bluprints for the hook tool. easy to make and works awesome every time. i can have that seal out in 10 seconds _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Thu Nov 19, 2009 5:30 pm Post subject: |
This tool is from a Toyota Corolla tool roll and is for prying the wheel cover off. But it also works well for removing the input shaft seal from my Beetle. It's thin enough to fit past the input shaft, and the round spoon-like end is tilted just right to enable gently prying the seal out of the hole by working it around the circumference. It takes a while but it comes off without damaging the metal.
