kayakwesty Samba Member
Joined: February 15, 2007 Posts: 687 Location: East Tennessee
Posted: Mon Nov 23, 2009 5:56 am Post subject: Front Blower Resistor pack? |
I searched the archives and maybe I missed ...but I couldn't find it
for months my front blower motor would only blow on one speed which was high
now it doesn't blow at all.
I was was wondering where the resistor pack is located.
I would like to change it out first if its easy to get to, to see if that fixes it first.
Does anyone have the part number also?
Thank you in advance.
Mark _________________ 1984 Westy 2.0 Jetta ABA Motor/1.8 head converted to auto tranny, with 180,000 on body, 55K on engine and transmission
B.5.5 Passat Wagen with 30v V6-67000 Miles
DAS AUTO
CHANGE YOUR FUEL LINES!
A post without pictures is useless
http://www.kayakwesty.com
http://www.waldensridgewhitewater.com/ |
Zero419 Samba Member
Posted: Mon Nov 23, 2009 6:27 am Post subject: |
If you are talking about the rad fan. The resistor is begind the drivers side head light. _________________ 1987 Westy Auto Bostig 2.0 Ztec |
Posted: Mon Nov 23, 2009 6:42 am Post subject: |
No worse...I'm talking the front heater blower motor...the one that keeps you warm in the van _________________ 1984 Westy 2.0 Jetta ABA Motor/1.8 head converted to auto tranny, with 180,000 on body, 55K on engine and transmission
DAS AUTO
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3343 Location: Talos IV, Piedmont Arizona
Posted: Mon Nov 23, 2009 6:58 am Post subject: |
It's in the fan housing, deep in the dash. The top speed is direct wire to fan so the pack has nothing to do with that. Check the switch(they do go bad)and the fuse. _________________ LEARN TO SELF RESCUE
.....................All Current....................... |
Posted: Mon Nov 23, 2009 7:40 am Post subject: |
thanks I will swap and the rear blower switch out and see if I get it going
I think I'm going to have to pull the freakin dash
so if I do
should
I replace the heater core
blower motor
resistor pack
what else? _________________ 1984 Westy 2.0 Jetta ABA Motor/1.8 head converted to auto tranny, with 180,000 on body, 55K on engine and transmission
DAS AUTO
McVanagon Samba Member
Joined: February 19, 2007 Posts: 1684 Location: Northern part of the Virginia
Terry Kay Banned
Posted: Mon Nov 23, 2009 12:11 pm Post subject: |
The bummer here is that that 3 speed motor resistor is no longer available new--
You'll have to go through all that work and drop a used one back into the front heater box.
I sold the last new one available in north america last week--
Another Vanagon part gone NLA. _________________ T.K. |
Vanagon Nut Samba Member
Posted: Mon Nov 23, 2009 12:38 pm Post subject: |
kayakwesty wrote: |
so if I do
should
blower motor
resistor pack
what else? |
Pulling dash is not as hard as you think, but hopefully it's just the switch as KS points out.
FWIW, I moved my fan resistor pack outside the box up front. (I figured it was original, so it would go before the heater core or fan would. I really should cover those wires.... another thing to do!)
The heater core is also NLA. Thread about possible less expensive substitutes:
http://www.thesamba.com/vw/forum/viewtopic.php?t=385553&highlight=heater
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Terry Kay Banned
Posted: Mon Nov 23, 2009 12:43 pm Post subject: |
I was wondering how you got to the wire loom inside of the heater box without removing it or opening it up?
Heater cores are available from several different sources---
Check out the samba.com Vanagon parts section--to name one place of availability.
Van Cafe also has them to name another source. _________________ T.K. |
Posted: Mon Nov 23, 2009 12:55 pm Post subject: |
Terry Kay wrote: |
The 3 speed blower motor wires are not exposed externally.
This was done at time of heater box rebuild and mods (for switch to water cooled).
Not my idea. Read of it over on Vanagon.com.
I should check and make sure nothings corroding or what-not with it. It's been out there for about 2 years now. _________________ 1981 Westy DIY 15º ABA
VE7TBN |
Terry Kay Banned
Posted: Mon Nov 23, 2009 1:13 pm Post subject: |
I'd think of greasing up the connections at the resistor might be a good idea to keep them from corroding out in the open as they are -- _________________ T.K. |
Posted: Mon Nov 23, 2009 1:42 pm Post subject: |
Say hello to my little friend
Here is a quick way to test the fan/resistor pack. These photos show the test with the fan out but you can do this with the fan/dash installed. All you need to do is unplug the connector from the switch.
To test the windings for the fan.
Get an OHM meter connect one wire to a ground source and probe the Yellow wire
You want to see some ### here. This proves the fan isn't shorted.
Next test the low speed resistor winding. This time connect one line to the Yellow wire__the other to the White wire.
Again you want to see ###. No ## = fried resistor.
Medium speed: Yellow and yellow/black.
See how the resistance decreases as the speed increases.
Class dismissed _________________ LEARN TO SELF RESCUE
Posted: Mon Nov 23, 2009 1:43 pm Post subject: |
dealer wants $115 for the resistor pack
I think not...
I will make my own...
and thank you for posting that! _________________ 1984 Westy 2.0 Jetta ABA Motor/1.8 head converted to auto tranny, with 180,000 on body, 55K on engine and transmission
DAS AUTO
Posted: Mon Nov 23, 2009 1:49 pm Post subject: |
Terry Kay wrote: |
I'd think of greasing up the connections at the resistor might be a good idea to keep them from corroding out in the open as they are -- |
Yup. Thanks. I'll break out the dielectric stuff.
KW
there was a thread recently about resistor pack substitutes. _________________ 1981 Westy DIY 15º ABA
VE7TBN |
Posted: Mon Nov 23, 2009 1:51 pm Post subject: |
kayakwesty wrote: |
I will make my own... |
That's what I have been doing all day, playing with resistors. _________________ LEARN TO SELF RESCUE
Posted: Mon Nov 23, 2009 1:55 pm Post subject: |
Quote: |
there was a thread recently about resistor pack substitutes. Smile
anybody got a link I found nothing in the search ( i think its broke) _________________ 1984 Westy 2.0 Jetta ABA Motor/1.8 head converted to auto tranny, with 180,000 on body, 55K on engine and transmission
DAS AUTO
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Mon Nov 23, 2009 2:06 pm Post subject: |
You can use the resistor out of the rear A/C. It uses the same fan motor, x2, plus 2 resistors, one per motor. These are 3 speed resistors not 2 speed like the heater fan resistor, so only use 2 or go ahead and let high speed be a little slower and use all 3. You can use the A/C fan motor as well, slight connection difference.
heater fan- low, med done by resistor, high speed bypasses resistor, 3 speeds total
A/C fan- low, med, med hi, by resistor, high speed bypasses resistor, 4 speeds total
Mark
kayakwesty wrote: |
anybody got a link I found nothing in the search ( i think its broke) |
Posted: Mon Nov 23, 2009 5:32 pm Post subject: |
kayakwesty wrote: |
This is the one I was referring to:
http://www.thesamba.com/vw/forum/viewtopic.php?t=386613&highlight=resistor
Doesn't have as much, if any, relevant info as I thought. My bad.
If you can't find used, (or follow Marks suggestion) maybe one from a Jetta? Seems a Mk2 might do. (pic below)
It shows a similar looking product though you would need to find a way to connect it.
I would imagine the Jetta blower is similar electrically (draw). If it were me, I'd prefer that "pack" type over a coil type. (pic below. late 90's Mazda) Either one gets hot, but depending on where/how it's mounted, the coils look to be a fire hazard to me. But, they seem cheaper. i.e. one for a Jeep is less than $20 and has cage to protect coils.
Neil.
VE7TBN |
Posted: Mon Nov 23, 2009 5:58 pm Post subject: |
exactly I thinking MKII there are alot at my pull-a-part. I can mount the pack in a remote box too, so the next time its easier to get to
It's starting to pi$$ me off on all the NLA parts hitting us...my van has plenty of life left in it _________________ 1984 Westy 2.0 Jetta ABA Motor/1.8 head converted to auto tranny, with 180,000 on body, 55K on engine and transmission
DAS AUTO
