JeffL Samba Member
Posted: Fri Nov 30, 2007 10:19 pm Post subject: |
| 65ghia wrote: |
| my 58 ghia has that same front dimpled sway bar |
Yes even the parts manuals show the dimpled sway bar. I'm not sure when it changed to a straight bar? |
JeffL Samba Member
Posted: Sat Mar 01, 2008 5:03 pm Post subject: Removal of undercoat and paint |
Had a nice day in Kentucky here today so I did some sand blasting.
Earlier in the year I uses a torch to remove the undercoating from the fenders and bottom of luggage area. To remove the rest of the tar I use laquer thinner. I followed this with some paint remover and got about 80% of everything cleaned up.
I hate sand blasting but wanted to remove some of the rust and in particular the corrosion in the battery area. Certainly being able to turn the car upside down made this easier. I had the rest of the body wrapped in plastic but the sand still got through.
I thought I had all the thin spots cut out in the battery area but some tiny holes showed up. Not sure yet if I'll cut more out....
I use a metal etch to go over the bare metal and it will typically not rust for over a month. It gives it a gray appearance.
It would be nice to drop this off in a paint show in Cleveland when we move. Anybody know of a good restoration paint shop in Cleveland?
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Sun Mar 02, 2008 7:33 pm Post subject: |
| That battery tray looks really solid. |
SkrapMetal Samba Hornblaster
Joined: January 18, 2006 Posts: 2558 Location: Dallas, TX
Posted: Sun Mar 02, 2008 7:48 pm Post subject: |
Nice and unmolested. Por-15 it. _________________ oo9less since 2007
-72 Ghia- |
thom Samba Member
Joined: October 12, 2000 Posts: 6269 Location: Sacramento
Posted: Mon Mar 03, 2008 8:51 am Post subject: |
Hell - just clear it and drive it as-is! _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
JeffL Samba Member
Posted: Mon Mar 03, 2008 10:19 am Post subject: |
| thom wrote: |
| Hell - just clear it and drive it as-is! |
My son just loved your answer, I had to get the spray gun out of his hand
We used some DP40 and gave it a good coat on both sided. I decided to use my door jam gun, took a while but still went on pretty good.
If you look close at the battery side you can see where I welded in a patch already. Start at the battery ground bolt (they grounded to the body in early 56) an come towards you in the photo. It is a square patch that crosses the seam and goes under the battery. The hole was the size of a quarter. When I saw the other pins holes develop I was dissapointed. I guess I'll use a little filler like "all metal" to dress it out. |
70 140 Samba Member
Posted: Mon Mar 03, 2008 10:46 am Post subject: |
| Por15 - Silver, is good stuff. It is a metal strengthener good for pitted area such as this. You can prime it and top coat it also.... |
hugheseum Samba Member
Joined: February 11, 2004 Posts: 2690 Location: oregon
Posted: Mon Mar 03, 2008 3:00 pm Post subject: |
definately jealous of the sunroof,cant wait to see it after paint _________________ Have a great day! |
hpw Samba Member
JeffL Samba Member
Posted: Sun Nov 29, 2009 12:02 pm Post subject: |
| hpw wrote: |
| Old thread are there any updates? |
Well, the car is now in Hudson with us. My son is 17 and we took a little side track and got a 35K mile Sonett back on the road.
http://karmannghias.org/blog/
Then, there was the 53 Fire Truck that got in the way. It is now back on the road with 9500 miles on it.
http://karmannghias.org/share/1953GMCFireTruck/
I am linked up now with the local AACA group and hope to get a good lead on painting the car as it does not look like I will not have a separate shop here.
Jeff |
JeffL Samba Member
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14237 Location: Southampton U.K.
JeffL Samba Member
Posted: Tue Mar 08, 2011 2:54 pm Post subject: |
| John Moxon wrote: |
| JeffL wrote: |
Wow, my original post was over 3 years ago and I only moved the Ghia about 11 hours North East.
Hopefully with the new garage now built I will get a chance to work on the Ghia again.
Great to see things on the move again Jeff. Do you have a built-in intercom system to communicate with others on the far side of the garage?  |
No that's the jack for the flat screen TV and internet. I've found out that you never have enough space. The garage is about 1000 sq-ft with 10 ft ceilings. There is enough lighting to grow certain substances.......... _________________ http://karmannghias.org/
https://karmannghias.org/GAlken/index.html |
Rich's 50 Samba Member
Joined: February 18, 2004 Posts: 10794 Location: San Diego, CA
Posted: Tue Mar 08, 2011 4:17 pm Post subject: |
