1970 Convertible Top Replacement
Page: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Ghiaddict
Ghiaddict is offline
PostPosted: Sun Dec 06, 2009 10:06 am    Post subject: 1970 Convertible Top Replacement Reply with quote
We're installing a convertible top for a fellow Sambanista and
would like to illustrate some of the steps here in the Ghia Forum.
His 1970 Ghia arrived here with the convertible framework and wood bows already installed and in good shape.
Watch this space for updates as work progresses. Some select photos of
the fundamental steps will appear here as progress points are reached.
Scope of the work will include:
1. Adjust top frame with bows for proper fit to body.
2. Install headliner.
3. Install padding.
4. Install top cover.
What follows applies to all Karmann Ghia cabriolet tops
from late 1969 through 1974 with the glass rear window.
New header bow, corner plates, guide pins and boots.
New rear wood bow. Keep the glass window in place during the process.
Some adjustments needed here for better fit to body.
Karmann Ghia & Beetle parts available.
Convertible tops installed.
72Ghia
72Ghia is offline
PostPosted: Sun Dec 06, 2009 10:31 am    Post subject: Reply with quote
Great thread idea. Looking forward to any new postings.
Bill
WTB- Billet center caps with Wolfsburg logo
72 Ghia Vert project
Bodywork http://www.thesamba.com/vw/forum/viewtopic.php?t=303542&highlight=
Re-assembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=4762737#4762737
72 Beetle Weekend Driver, restored in the 90's
http://www.thesamba.com/vw/forum/viewtopic.php?t=353424
www.airsuckers.com
Lair
Lair is offline
PostPosted: Sun Dec 06, 2009 6:49 pm    Post subject: Reply with quote
Real wood header bows look cool. They're easy to work with, also.
'65 Deluxe bus long term project
gregmporter
gregmporter is offline
PostPosted: Sun Dec 06, 2009 8:22 pm    Post subject: Reply with quote
You are awesome!!! I am looking forward to this thread.
You Tube Channel w/vids of the car's progress
http://www.youtube.com/user/gregmporter
1974 Karmann Ghia Cabriolet
1964 356C Coupe (in progress)
Ghiaddict
PostPosted: Tue Dec 08, 2009 12:01 pm    Post subject: Reply with quote
Using shims to obtain the 6 mm (1/4") clearance between the
main bow and body support pillar. Loosen the 3 frame mounting bolts
on each side @ rear of door to shift the frame.
Also push the top frame outwards until the main bow projects
about 2 mm from the body sharp edge on top of the quarter panel.
Retighten the frame mounting bolts.
Properly fitted header bow will have space between the bare wood and
the windshield frame: Specs are 7 mm at center, 2 mm at the ends.
Loren
Loren is offline
PostPosted: Tue Dec 08, 2009 7:23 pm    Post subject: Reply with quote
Where were the wood bows purchased from and how well did they fit? Where did you buy the top, padding and headliner from? Did you go with a canvas or vinyl top material.
Ghiaddict
PostPosted: Tue Dec 08, 2009 8:08 pm    Post subject: Reply with quote
Everything was sourced from SewFine Products in Texas.
The wood bows were already installed when the Ghia arrived here
but judging from what I can see, they fit much better than
bows I've used from some other suppliers.
The top cover is canvas material.
Ghiaddict
PostPosted: Wed Dec 09, 2009 12:01 pm    Post subject: Reply with quote
Cover the rear edge of the header bow with matching fabric
strip supplied with the top cover.
Also cover the corner plates. Staple positions are marked so that
the next layer of fasteners for the headliner can be staggered on top.
Positioning of the glass window hinge to body mounting to the middle
of the range allows for future adjustment, if needed.
crocteau
crocteau is offline
PostPosted: Wed Dec 09, 2009 1:59 pm    Post subject: Reply with quote
Ghiaddict wrote:
Positioning of the glass window hinge to body mounting to the middle of the range allows for future adjustment, if needed.
You are good! I don't recall seeing anything about that adjustment in the top installation manuals I dug up. I think it's a reasonable and logical approach, but when I finished my top I found myself wishing that I had adjusted the hinges to their upper limit at that step in order to minimize gaps at the lower corners where the glass meets the sewn-in rubber seal. This may have been affected by my reusing the original "body to rear bow" straps, as there was no chance of them stretching to allow the hinges to move up after the fact, and the rear bow positioning seems to be the linchpin to a successful installation. I suppose those little corner gaps explain why VW put the rear window gutter and drain tubes in.
Charley
Ghiaddict
PostPosted: Wed Dec 09, 2009 3:11 pm    Post subject: Reply with quote
crocteau wrote:
You are good! I don't recall seeing anything about that adjustment in the top installation manuals I dug up. I think it's a reasonable and logical approach ...and the rear bow positioning seems to be the linchpin to a successful installation.
Charley
Thanks! This one being probably the 10th "late" top done, past experience is the main motivator of what's being posted and explained here. All of the reprints of VW manuals out there leave some details unclear, especially those that have obviously been translated from the German!
We adhere to the "factory" instructions as much as possible. By this
time I think every pitfall in the process has been faced.
And yes, the rear bow position with proper latching of the glass rear
window is critical for a successful top installation for late models.
The pre-1969 models seem somewhat easier, IMHO.
70ghiaconvt
70ghiaconvt is offline
PostPosted: Wed Dec 09, 2009 4:01 pm    Post subject: Reply with quote
Hi Loren,
Vince is working on my ghia.
The front bow came from Sewfine as Vince stated and just needed slight modifications to the right side to match the curve in the corner cover plate.
The rear bow came from KGPR and needed to be thinned about an 1/8 of an inch to fit.
Thanks,
Wally
Ghiaddict
PostPosted: Thu Dec 10, 2009 12:58 pm    Post subject: Reply with quote
Glue a foam strip to the underside of the header bow at
the front edge. DAP contact cement on both surfaces to secure it
to the wood.
Glue one end of the webbing straps at the recesses in the main bow.
Sew the straps in place with waxed, heavy duty thread.
danielsan
danielsan is offline
PostPosted: Thu Dec 10, 2009 1:10 pm    Post subject: Reply with quote
Fantastic thread! Hope it becomes a sticky or finds a place in the FAQ.
Did you sew this with a large needle or do you own a hand held sewing machine?
Ghiaddict
PostPosted: Thu Dec 10, 2009 1:15 pm    Post subject: Reply with quote
Big needle and thread for me.
I'm old school. Cool
Lots more sewing to come for headliner & padding.
Lair
Lair is offline
PostPosted: Thu Dec 10, 2009 8:33 pm    Post subject: Reply with quote
Jerry Burton would be proud.
VW-Variant-L
VW-Variant-L is offline
PostPosted: Fri Dec 11, 2009 3:11 am    Post subject: Reply with quote
great timing with the thread, I am in the process of looking for supplies to do my 70 KG Very Happy
I have seen parts online ( headliner, pad and canvas cover) from KGP&R and Sewfine and am trying to decide which one to go with.
Have you had any experience with KGP&R tops ? Is there a reason for you choosing Sewfine ? I'm ordering from overseas so wanting to get it right
Ghiaddict
PostPosted: Fri Dec 11, 2009 6:36 am    Post subject: Reply with quote
VW-Variant-L wrote:
great timing with the thread, ...
Wally, the Ghia's owner, made the choice to go with SewFine
for the top materials and most parts. Their products are excellent.
Yes, TMI, Chuck's Convertibles and others have been used to source
these parts in the past for other tops we have installed.
A few years back KGP&R stated that they actually source their
convertible tops/parts from others suppliers like TMI and SewFine.
Not sure if that is still the case, but it seems there are only a very
small number of companies actually making the tops.
Ghiaddict
PostPosted: Fri Dec 11, 2009 12:40 pm    Post subject: Reply with quote
Fold the top forward but do not engage the front latches.
Temporarily lower the rear bow and glass window.
Mark a length of 660 mm (26") on each webbing strap from
the rear edge of the main bow. This is the specified distance
to the rear body flange.
Using one inner anchoring strip, attach each strap to the body
using 2 Phillips countersunk screws. Note: the third, inner
screw is fitted in a later step. Also do not cut off any
surplus material.
Right side, same as above.
Close and latch the top. Pull up the rear bow to a dimension
of 300 +/- 5 mm (12") measured from the rear of the main bow to
the trailing edge of the rear bow. Attach the webbing straps with
tacks in the recesses of the wood. It will fit tight!
Bows are now set in position. Check the latching of the rear window.
Make adjustments now, if needed.
Fold the surplus ends of the webbing straps back and glue them in
position.
22manybugs
22manybugs is offline
PostPosted: Fri Dec 11, 2009 1:38 pm    Post subject: Reply with quote
I think the dimensions are backwards. They may be correct for earlier-model Ghias with the latch in the middle of the main header bow, but on later-model Ghias with two latches - one at each outside edge of the bow - you would want a thinner space in the middle and more space on the outside. The reason is that, for later-models, the top should contact the middle of the bow first, then closing the latches will pull-down the outside corners and you get a good tight seal all the way across the front.
I'm basing that on convertible Bugs. I haven't replaced a top on a Ghia, but I've done a couple Bug tops and that's how they are setup. The idea should be the same.
Ghiaddict, thank you for putting this post together. It has great information!
Lon
1969 Karmann Ghia convertible
1971 Westfalia camper
Ghiaddict
PostPosted: Fri Dec 11, 2009 4:07 pm    Post subject: Reply with quote
I think the dimensions are backwards...on later-model Ghias with two latches - one at each outside edge of the bow - you would want a thinner space in the middle and more space on the outside...the top should contact the middle of the bow first.
I'm basing that on convertible Bugs. I haven't replaced a top on a Ghia...
The dimensions I provided are correct.
Here is the appropriate page from the Ghia manual and you can see
it is a later model Type 14 with side latches:
I don't do Bugs and you may be right about the differences owing to
the shape of a Bug header and/or windshield frame. Don't know.
But this isn't my first rodeo when it comes to the Karmann Ghia top. Wink
Page 1 of 10
