Crughy Samba Member
Joined: July 12, 2004 Posts: 576 Location: Montreal, Qc
Posted: Sun Dec 13, 2009 11:43 am Post subject: Memory foam on top of the bed (westy/bottom). |
Hi all,
I don't sleep well in the westy. I sleep mostly in the bottom bed (stealth, gear on top, ease, etc.).
I am going to buy some memory foam. I looked a bit into it. There are tons of products/brands, etc.
You can get, 2, 4 , 6 or 8 inches of width, all kind of sandwiches...
I was thinking of getting something like 4' deep at the max. It seems like the best compromise for ease of storage. I read in the archives, a guy cut it in 3 so he could easily store it in different place of the van.
The mattress never comes in the right size (I think the westy bed is 48x75). So it would need to be cut a bit. Or I may go with a slightly smaller than original if it's close.
My question is the following. There are many brands and products. many prices. the quality of the stuff varies a lot.
Do you have any recommendation for a specific product/brand/shop/big retail chain?
Bad or good stories of the stuff?
I will be in Orlando, FL in a week or so.
JP |
VwMomofthree Samba Member
Joined: November 15, 2006 Posts: 195 Location: Colorado
Posted: Sun Dec 13, 2009 11:53 am Post subject: Mattress topper |
I did just that, I bought a queen size mattress topper-memory foam from Walmart. I had to cut the end off to make fit right, I used a serrated edge knife and this cut it really easy. I didn't cut very much, then I cut in thirds to fit in the back to carry along. It comes with a zip on/off cover that I thought about sewing a seam between the thirds but I haven't gotten there yet. I think I paid $120.00ish. Works great and I sleep like a baby. Oh yeh, I have a 88 wolfsburg weekender. |
kshbaja Samba Member
Joined: June 15, 2008 Posts: 476 Location: Portland, OR
Posted: Sun Dec 13, 2009 12:14 pm Post subject: |
I use a 2" foam pad and it makes quite a difference in how well I sleep. It is a bit bulky to transport though. _________________ 1986 Westfalia |
madspaniard Samba Member
Posted: Sun Dec 13, 2009 12:22 pm Post subject: |
2" memory foam from Bed Bad & Beyond. Stock size, I didn't cut anything, slightly wider than lower bed but it does not interfere with rear cabinet door or anything. It folds up easily in rear cargo area under everything else. I don't always carry it with me. It also doubles as memory foam on top of guest sofa bed at home. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
izzydog Samba Member
Posted: Sun Dec 13, 2009 12:39 pm Post subject: |
I got a 2" mattress topper from overstock.com and it works great. Be sure to get the 4 pound density or it'll be kinda squishy. 4 pound density is supportive but not super firm.
Check the sizes because I think they all cost the same. I think I ordered a queen and used the extra foam for other stuff. Free shipping, too. They compress the foam for shipping so be sure when you open the box to just let the foam uncompress by itself for an hour or you'll tweak it. I think I got the Serta 4 pound density version.
I removed the OEM foam from the upper bunk covers and put the memory foam in instead. Use the old foam for a pattern. Now I just leave it up in my top bunk and pull it down for sleeping when I need it. The upper bed and the lower bed are the same size, believe it or not. |
Julian13 Samba Member
Joined: September 15, 2009 Posts: 203 Location: Vancouver
Posted: Sun Dec 13, 2009 1:18 pm Post subject: |
Interesting timing on this question as I looked into the same thing last week. As I find the ergo moulding of the EV MV rear seat is not as comfortable as a flat surface. The GoWesty topper looks nice but the cost of shipping makes it uncompetative with something I can get locally.
The Foamshop does the same thing for RVs. I came down on the side of 4" and 4 lb foam but was unsure whether to order a single piece and fold it or cut across into 3 pieces with a seam in the cover between each to make folding easier (as GoWesty do).
The shop manager said it wouldn't be necessary at that weight as it would fold over ok and not cause any degrading of the memroy foam by doing so. I have to say that I am dubious about that and am still leaning toward the 3 piece. |
Belladonna30c Samba Member
Joined: April 23, 2008 Posts: 206 Location: San Diego, CA
Posted: Sun Dec 13, 2009 2:09 pm Post subject: |
izzydog wrote: |
Check the sizes because I think they all cost the same. I think I ordered a queen and used the extra foam for other stuff. Free shipping, too. They compress the foam for shipping so be sure when you open the box to just let the foam uncompress by itself for an hour or you'll tweak it. I think I got the Serta 4 pound density version. |
Hi. I did the same. Ordered from Overstock..the biggest size at the same price. cut to fit and used the extra foam for my dog's crates.
Also, check out this discussion here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...p;start=40
I quote myself from that discussion:
"I think I got mine for around $90...no need for any special covers for the foam, like GoWesty sells. You can just throw a light blanket or sheet over it before making up your bed...however you sleep! When the lower bed is not in use, I just fold it up and keep it in the rear cargo area. Yes, it takes up a bit of space, but it is worth it to me.
My neighbors bought one for their upper bunk hoping that it would replace the OG foam. That did not work out for them. You really need the density of the OG foam for support + the memory foam topper for comfort. I have no idea what size you could easily keep up top on a permanent basis. Worst case scenario, you could roll it up tightly and store below in a duffle bag until ready to use.
One more thing about memory foam...all brands are not created equally. There are different qualities/grades of foam. Do your research for a product that will last and suit your needs. Here are some sites that might be helpful to you!
http://www.healthyfoundations.com/memoryfoammattress.html
http://www.memoryfoam.com/v/memory_foam_toppers/memory_foam_density.htm" _________________ 1986 Weekender, automatic, 2nd owner
"A picture is worth a 1,000 words..."
"An ounce of prevention is worth a pound of cure." |
WW_Victoria Samba Member
Joined: October 03, 2008 Posts: 91 Location: Victoria
Posted: Sun Dec 13, 2009 4:43 pm Post subject: |
On Vancouver Island I bought one at Jysk -
http://www.jysk.ca/ProductDetails.aspx?id=10392&prodid=8006034
this one is similar I think - mine was maybe $20-30 cheaper on sale in the early fall. As mentioned - quick trim with a utility knife to make it fit upstairs - and the sleep is much improved.
WW _________________ ------------------------
Aoristspilia - 1985 Westfalia 1.9 lt AAZ td
past rides...
1972 Westfalia
1974 Bus - RIP
1969 auto stick beetle - The "Dolphin" bug |
Timwhy Samba Member
Posted: Sun Dec 13, 2009 5:01 pm Post subject: |
I bought the cheapest memory foam sold at walmart, I think it was two inches thick. Actually bought two of them as well as a padded matress cover to go over them. The cover keeps them in place while camping,and makes folding them up into the back easy. Also I bought a heated matress pad for between the foam and cover. The heated pad is a twin size, really toasty while it's cool outside.
The lady at the fabric store gave me a tip on cutting foam. Use an electric knife for perfectly cut sides, and it works! _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
sc-surfer Samba Member
Joined: May 16, 2005 Posts: 865 Location: Santa Cruz, CA
SSWesty Samba Member
Joined: August 20, 2008 Posts: 732 Location: Bellevue
Posted: Sun Dec 13, 2009 8:56 pm Post subject: |
I just switched over from a 1.5" premium memory foam from Walmart to a quality 2" egg crate foam from a foam shop.
After about 45+ nights on the memory foam I found it firmer than I liked. On those cooler nights below 45 it was cold and firm to lay on at first. Then after my body heat warmed it up I'd find myself in a hole and it didn't feel like I was sleeping on a flat mattress.
I think the egg crate that I got is in the low 20 pound density range. It's definitely has more of springy or cushy feel to it.
Both purchases were Full size toppers and I used an electric knife to get them to fit.
Steve |
HeftySmurf Samba Member
Joined: June 15, 2008 Posts: 879 Location: Washington, USA
Posted: Sun Dec 13, 2009 9:17 pm Post subject: |
Costco has nice ones for about a 100 bucks, much better quality and more comfy. I have ben just rolling mine up, but need to get arround to making a cover for it and cutting so it will fold up and fit in the back. _________________ -Lorenzo
90 GL w/ Bostig |
Posted: Sun Dec 13, 2009 11:37 pm Post subject: |
HeftySmurf wrote: |
Costco has nice ones for about a 100 bucks, much better quality and more comfy. I have ben just rolling mine up, but need to get arround to making a cover for it and cutting so it will fold up and fit in the back. |
Hmmm....headed to costco for some new BTG ATs....(best price I could find...$109 each plus $7.50 mount/balance for the 215 75 R15,,,FWIW)
Guess I'll look into the memory foam as well! Thanks for the info. _________________ '89 Syncro Westy
Catalog of Vans at SDM 2010
Westfalia, Syncro & Tristar Reproduction decals here.
* * * Coming Soon: Washable seat covers for westy bench seat...keep the pets off the upholstery! * * * |
Jon_slider Samba Member
Posted: Mon Dec 14, 2009 12:23 am Post subject: |
GoWesty is making a 2" topper with cover for $200, their ad says it folds easily, no seams.
For an extra 100, they make one with combined 1 inch foam and 2 inche memory for a total 3 inch thickness, in folding zippered sections.
and for the upper bunk they offer 1" memory foam, covered and foldable, no sections.
Im interested in the thickness of the various offerings.. it seems from reading, that one piece, foldable 2" is a good way to go. |
Posted: Mon Dec 14, 2009 12:42 am Post subject: |
mine is 2 inch memory foam - folded in thirds it fits in the upper bunk no problem with the top down. Nice place to store it as well - however, I also have a pillow catcher and that no longer fits on the upper bunk. _________________ ------------------------
past rides...
1972 Westfalia
1974 Bus - RIP
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
Posted: Mon Dec 14, 2009 7:17 am Post subject: |
WW_Victoria wrote: |
mine is 2 inch memory foam - folded in thirds it fits in the upper bunk no problem with the top down. Nice place to store it as well - however, I also have a pillow catcher and that no longer fits on the upper bunk. |
So if I understand this correctly you end up with a 6 inch thick stack of memory foam that is compressed by the top when you lower it? Thanks. _________________ Dave O
The Western Syncro build
Posted: Mon Dec 14, 2009 7:42 am Post subject: |
sc-surfer wrote: |
HeftySmurf wrote: |
Guess I'll look into the memory foam as well! Thanks for the info. |
I though COstco wouldnt mount tires that were not stock? _________________ -Lorenzo
90 GL w/ Bostig |
torocreek Samba Member
Joined: June 20, 2007 Posts: 95 Location: Long Beach, Ca.
Posted: Mon Dec 14, 2009 7:58 am Post subject: |
madspaniard wrote: |
2" memory foam from Bed Bad & Beyond. Stock size, I didn't cut anything, slightly wider than lower bed but it does not interfere with rear cabinet door or anything. It folds up easily in rear cargo area under everything else. I don't always carry it with me. It also doubles as memory foam on top of guest sofa bed at home. |
You can also buy a full size futon mattress cover to protect your memory foam.
They are the perfect size, have zippers, and are made out of a real durable fabric.
I then roll it up and stuff it into a draw string bag I bought at REI. |
Raynor Shine Samba Member
Posted: Mon Dec 14, 2009 8:22 am Post subject: |
Poke around at bed bath & beyond too, I scored high end upper and lower for less than 100 each. cut to size with covers. My wife has a nice 4" lower cushion. I got kicked to the upper this summer so only 1 1/2 inch up there folded in 3rds. Lid closes nice. |
Posted: Mon Dec 14, 2009 8:46 am Post subject: |
HeftySmurf wrote: |
sc-surfer wrote: |
HeftySmurf wrote: |
I though COstco wouldnt mount tires that were not stock? |
They won't mount wheels in your car but they will sell you tires and mount/balance them in the wheels. Then you can mount them in the car yourself. _________________ 1991 Westy auto w/ Peloquin TBD
