help identifying component ...
youremyboyblue
youremyboyblue is offline
PostPosted: Mon Dec 14, 2009 1:19 pm    Post subject: help identifying component ... Reply with quote
i found this disconnected under the driver side front of my 1986 vanagon syncro the other day. searched the bentley to no avail. anyone have an idea?
the connection is filthy but, when connected, the oxs light comes on.
thanks in advance!
iceracer
iceracer is offline
PostPosted: Mon Dec 14, 2009 1:44 pm    Post subject: Reply with quote
That is the OX box. See the little round hole at the top right? Take a pencil end, eraser and push it in there and you will hear it click. You will have reset the OX light. Plug the electrical plug back on and lo and behold , the light will be out.
If you want to get real fancy, go out and buy yourself a new cat and ox sensor and replace those at this time. That is what it is for.
86 Syncro Wolfsburg edition
63 Beetle (The Iceracer)
dobryan
dobryan is offline
PostPosted: Mon Dec 14, 2009 3:03 pm    Post subject: Reply with quote
Just to clarify. That box is just a mileage counter that sets off the OX light on the dash every 50,000 (or is it 60) miles. It does not monitor the state of the Cat or OX sensor. Unless you know that the cat and OX sensor are bad you don't need to replce them, unless you feel the desire to. YMMV.
Dave O
The Western Syncro build
iceracer
iceracer is offline
PostPosted: Mon Dec 14, 2009 8:41 pm    Post subject: Reply with quote
Exactly, I was just trying my hand at humor.
tencentlife
tencentlife is offline
PostPosted: Tue Dec 15, 2009 10:02 am    Post subject: Reply with quote
Yeah, it's 60k, it just counts the miles and turns on the light, as a service reminder. That was when O2 sensors were still a fairly new technology so that was the projected lifespan of the sensor; since then we've learned they typically last quite a bit longer than that.
Your OXS warning light and ALT light circuits are also joined at the counter box, so the OXS light will also light up when you key on for a bulb-check (didn't you know you're supposed to verify that all your warning lights are working every time you key on?). With the box unplugged the ALT light comes on all by itself.
Shop for unique Vanagon accessories at the Vanistan shop:
Experience is kryptonite to doctrine.
youremyboyblue
PostPosted: Tue Dec 15, 2009 10:08 am    Post subject: thanks! Reply with quote
thanks for clearing that up for me!
since i'm currently troubleshooting some engine issues, i guess i'll be taking a look @ the os sensor and the cat ... Very Happy
