Loren Samba Member
Posted: Sun Dec 20, 2009 10:38 pm Post subject: Removing crusty heads |
I searched the forums and couldn't find any posts on removing heads from crusty engines that didn't involve a sledge hammer and prybar so I though I would share this tool idea in hops that it might help some one else down the road.
A few weeks ago I picked up a crusty old 36hp engine that looked like a good rebuild candidate. I started tearing the engine down and all went fine until I tried to remove the heads, they wouldn't budge. The cylinder studs were corroded and the heads were not coming off with out a fight. I tried the usual prying and prodding, but I didn't want to booger up the head fins so I didn't get too far. After a few days of thinking it over I came up with this tool and it worked great at getting off both heads with out causing any damage to the heads or engine block.
be sure to remove all the head bolts, these two often get clogged with dirt and are hard to see. I had to remove all the packed in dirt before I could remove the bolts.
here are the tools I made. I used some 5/8" steel tubing from the hardware store, 5/8" all-thread, two nuts and two flanges from an old muffler. I had to extend one of the tools to clear the fuel pump stud. Make sure you weld the tubing horizontal to the head and try to center it on the cylinders, this will help keep the head from binding up. I only made this one set of tools and flipped them to remove the other head.
Here is one side of the head. I put a bolck of wood at the end of the bolt to protect the block
here is the other side, notice the block of wood protecting the block
All you have to do is bolt the tools onto the exhaust ports and turn the nuts. This will extend the bolt and push the head off the engine. Be sure to move back and forth from tool to tool, tightning each one a few turns. If you tighten too much the head will bind. I had to back the nuts off a few times and whack the head with a rubber mallet to keep the head from binding. Just take is slow and make sure the head is not binding.
For a first try these tools worked fine. Next time though, I will weld a nut to the end of the all-thread and use a wrench to keep it from spinning while I tighten the adjusting nut. |
Min ein er et stykke fole Samba Member
Posted: Mon Dec 21, 2009 1:00 am Post subject: |
Thats a great idea..If I can't get a head off using a rubber malet I will give it a shot.. _________________ 66
Don't mind the oil spots in your driveway...
That's just HP sweat..
I wanna be sedated |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Mon Dec 21, 2009 7:07 am Post subject: |
Good idea, better with the welded nut and bolt modification. I usually get the heads to come off, but some times the cylinders are stuck to the heads. Back to the hammer _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
anthracitedub Samba Member
Posted: Mon Dec 21, 2009 8:32 pm Post subject: |
Good job!!! Probably come off easier if you would remove the valve covers and get the other 4 head bolts.
Just kidding. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Tue Dec 22, 2009 4:52 am Post subject: |
Too bad that trick won't help out when you have the cylinders stuck to the heads, as I've seen a couple of times on stale-air 40HP, due to too much build-up between the primary seal at the combustion chamber and the secondary seal at the copper crush seal. I've had them stuck on so badly that I literally had to destroy the cylinder to get them apart.
-Andy |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Mon Dec 28, 2009 7:35 pm Post subject: |
looks like a good idea, but how will that work if you have broken exhaust studs? |
Posted: Mon Dec 28, 2009 7:59 pm Post subject: |
Like your idea Loren but a Small Rubber mallet is all thats needed.I would not mind having a set of those thou.....I removed these heads after 15 years of tree sap, water,snow,ice bla bla bla...There was actual ice inside when removed..tap back and forth on the exhaust studs and walla
ice inside..this thing was solid..
oh ya..the carbs were removed all that time also..the motor was full of frozen ice/water _________________ 66
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Tue Dec 29, 2009 1:08 pm Post subject: |
You should start a horror engine picture thread and see who can display the most unusual engine story...that's a good one...I myself had seen some bad VW motors but that one takes the cake
VWM |
rtroy Samba Member
Joined: June 03, 2009 Posts: 259 Location: California
Posted: Tue Dec 29, 2009 7:22 pm Post subject: |
Hi Loren,
Interesting solution. I have a spark plug that I use for this purpose. I took a bum spark plug some years ago and broke away the ceramic leaving the threads and the place for a wrench. To this I added a metal tube that had a grease nipple threaded in - I simply welded the tube to what remained of the spark plug, grease nipple out, of course.
When I want to use the tool, I thread it into a spark plug hole of interest, attach a grease gun and start pumping. This tool can be used both for moving stuck pistons from cylinders and for removing stuck heads - you must, of course, first put the piston at top dead center to remove heads using a minimum of grease, but bottom dead center would work, too. You can also pour a liquid into the hole first to fill up the volume if you like - engine oil is cheap enough and helps lubricate, if needed, and you can use used oil if you want...
My solution solves the problem of cylinders stuck to the heads, too, but what I like about your solution is that unlike mine, your can continue to push even after the seal is broken whereas my solution loses pressure and stops functioning.
Thanks for adding to our collective tool box,
Richard _________________ Richard
Karmann Ghia and Porsche 356 enthusiast
Founder, The Karmann Ghia Club of N. America |
billmetric Samba Member
Joined: March 16, 2006 Posts: 1061 Location: Columbus City USA
Posted: Wed Dec 30, 2009 10:58 am Post subject: |
NICE! a bit too late for me, I just recently distroyed a 36hp head with the same problem, I even tried sticking the VW jack in the exhaust port and tried to press the head off that way, I soaked it in PB blaster and Kroil for weeks ahead of time and it was not budging, the center upper head studs were rusted in there and one of the cylinders is still stuck in the head, ended up just beating the crap out of it for a few hours untill all the fins were mangled and the exhaust ports were all beat up, I still have a few more engines to tear down and will try this next time! Thanks _________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
