Bonnets / Hoods
Page: 1, 2, 3  Next
sneal1956
sneal1956 is offline
PostPosted: Tue Dec 22, 2009 4:28 am    Post subject: Bonnets / Hoods Reply with quote
Do the bonnets change between the oval and the first big windows? or are the big window bonnets the same as the 61 - 63?
Also if anyone could show me a correct bonnet handle for a 56 I would appreciate it.
Thanks in advance.
valentinesr
valentinesr is offline
PostPosted: Tue Dec 22, 2009 4:50 am    Post subject: Reply with quote
I believe there are more differences than just the ribs in the photo that I have posted..It does have:
4 Tab Slots
Hood Badge Slots
Ribs on each side of the lower corners of the hood..
I dont know about the third bolt for the hood prop..
1956 Hood Bonnet
1958 Hood Bonnet (Notice the changes again in the lower corner)
Early Hood Bonnet (Notice Difference)
Valentine, Ray J Sr.
Ontario, California
thebucket wrote:
I gave my oval a nasty look. Money hungry bitch....
(Delilah) http://www.thesamba.com/vw/forum/viewtopic.php?t=319235
1954 Parts Book (CD PDF) PM TO INQUIRE
splitjunkie
splitjunkie is offline
PostPosted: Tue Dec 22, 2009 5:48 am    Post subject: Reply with quote
valentinesr wrote:
1958 and later Hood Bonnet
1957 and earlier Hood Bonnet (Notice the changes again in the lower corner)
1957 and early Hood Bonnet (Notice Difference)
You had your descriptions wrong. I have corrected them.
Chris
sneal1956
PostPosted: Tue Dec 22, 2009 6:07 am    Post subject: Reply with quote
Thanks for the replies. So does this mean that the only difference between a 57 - 61 and a 61 - 63 bonnet is that the later has a 3 pin VW badge instead of the earlier 4 slot one?
Suboval
Suboval is offline
PostPosted: Tue Dec 22, 2009 9:01 am    Post subject: Reply with quote
58-60: 4 tab VW emblem and the single wide pressing for the hinges.
61- early 63: 3 pin badge and the single wide pressing for the hinges.
late 63 - 66: 3 pin VW emblem on a plinth (raised circle) and the single wide pressing for the hinges.
67 and later: I dunno Eh?
It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history.
FRK
FRK is offline
PostPosted: Tue Dec 22, 2009 9:15 am    Post subject: Reply with quote
Yes!
This is ’58-’60.
’56-57 Hood with only 4 bolts.
This is ’55 hood only (7 months between January-July). It’s just like ’56-’57 hood but with 5 bolts and no triangle.
Late ’53 to the end of ’54 Hood is just like the ’55 but with the triangle.
Mid ’53 and split Hood is just like the ’54 hood but with 7 bolts.
64 Ghia
55 Kab
50 11G
50 11A
49 11
48 11
RVA Car Club
sneal1956
PostPosted: Tue Dec 22, 2009 11:28 am    Post subject: Reply with quote
Fantastic. cheers.
So from this I have worked out that the bonnet I was thinking of buying isnt correct as its a 55 bonnet with the 4 tab and 5 bolt holes.
I need to find a 4 tab and 4 bolt for a 1956 Oval. (although doesnt the picture above labelled 56 - 57 4 bolts also show 5 bolts? er confused)
and that the bonnet currently on my car is definately a 61 - 63.
My search continues then....
(oh and I never knew about the triangle for the earlies!)
Suboval
Suboval is offline
PostPosted: Tue Dec 22, 2009 11:59 am    Post subject: Reply with quote
sneal1956 wrote:
Fantastic. cheers.
More about the triangles - http://www.thesamba.com/vw/forum/viewtopic.php?t=228606&highlight=split+hood+triangle
http://www.thesamba.com/vw/forum/viewtopic.php?t=177246&postdays=0&postorder=asc&start=0
FRK
FRK is offline
PostPosted: Tue Dec 22, 2009 12:36 pm    Post subject: Reply with quote
Well, that's why I typed 4 bolts. '56-'57 is definally 4 bolts.
64 Ghia
55 Kab
50 11G
50 11A
49 11
48 11
RVA Car Club
kidvintage
kidvintage is offline
PostPosted: Tue Dec 22, 2009 6:41 pm    Post subject: Reply with quote
Not to confuse an already confusing issue.......but 61's came with four tab hoods as well. Are they the same as the 58-60 configuration??
valentinesr
PostPosted: Tue Dec 22, 2009 7:31 pm    Post subject: Reply with quote
Frank,
I think he was talking about the hood that I have. You listed it as 56-57 4 Bolt, but theres 5 Bolts..
*Which I will be selling, cause I need a correct hood.
Ontario, California
sneal1956
PostPosted: Wed Dec 23, 2009 1:47 am    Post subject: Reply with quote
Ah thanks for all your help in clarifying (its good to know I wasnt going mad...)
FRK
FRK is offline
PostPosted: Wed Dec 23, 2009 6:58 am    Post subject: Reply with quote
valentinesr wrote:
Frank,
yeah, I know! That's why I make sure I type 4 bolts for '56-'57. Very Happy
When are you coming back to LA?
64 Ghia
55 Kab
50 11G
50 11A
49 11
48 11
RVA Car Club
ericktheelectrician
ericktheelectrician is offline
PostPosted: Tue Jan 11, 2011 9:08 am    Post subject: Reply with quote
61 had a 3 tab raised emblem as well as late 60 mid 1960 is when they discontinued using the 4 tab hood
53 3 fold rag O.G (sold)
54 vert restomod
56 vert O.G
63 Karmann Ghia
60 double door deluxe
49 standard
OvalinAz
Samba Mini Tech
OvalinAz is offline
PostPosted: Tue Jan 11, 2011 3:17 pm    Post subject: Reply with quote
nope. in 61 or late 60(i think) there was a 3 tab non-raised emblem, i got one on my oval.
Dad's 4/55 Oval
8/56 Oval
5/64 French Notchback
12/62 French 11 Window Bus
Wedge VW
Pandraggers C.C.
OvalinAz
Samba Mini Tech
OvalinAz is offline
PostPosted: Tue Jan 11, 2011 3:36 pm    Post subject: Reply with quote
Dad's 4/55 Oval
8/56 Oval
Wedge VW
Pandraggers C.C.
ericktheelectrician
PostPosted: Tue Jan 11, 2011 3:55 pm    Post subject: Reply with quote
either way 4 tabs stopped in early 60 also splits had 3 tab ,7 bolt , hood crest bonnets not to be confused with the later 3 tab hoods with only 4 bolts and no hood crest slits
54 vert restomod
56 vert O.G
63 Karmann Ghia
49 standard
ConcreteAce
ConcreteAce is offline
PostPosted: Wed Jan 12, 2011 10:25 pm    Post subject: Reply with quote
No they did not stop in early 60. my 61 has the original hood and it is a 4 tab hood.
FYI
check this thread out it gives the chassis number that they stopped the 4 tab hood.
http://www.thesamba.com/vw/forum/viewtopic.php?t=250199&postdays=0&postorder=asc&start=0
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build
ericktheelectrician
PostPosted: Thu Jan 13, 2011 10:34 am    Post subject: Reply with quote
FYI
I stand corrected the first 3 months of the 61 production year (end of 1960) did use the 4 tab hood I was confusing the change in the front apron early 60's were a 4 finger front apron and mid 60 started the use of the 3 finger front apron
54 vert restomod
56 vert O.G
63 Karmann Ghia
49 standard
Birdman69
Birdman69 is offline
PostPosted: Wed Nov 23, 2011 5:05 am    Post subject: Reply with quote
I have a 4 tab which has been dented in the top corner.
A friend has told me these bonnents have a shallower pressing than later bonnets???
I only need to replace the top corner of the skin (not the braces where the hinges mount) but i dont want to source and destroy another 4 tab if I dont need to???
Page: 1, 2, 3  Next
