Thornton EMPI Guru
Joined: August 27, 2001 Posts: 2107 Location: Portland to AZ back to Portland
Posted: Tue Dec 01, 2009 9:03 am Post subject: |
what tires are these cars running on these wheels?
205/40/17's? _________________ Thornton |
Iozzio Samba Member
Joined: March 10, 2005 Posts: 354 Location: Molalla Oregon
Posted: Tue Dec 01, 2009 10:15 pm Post subject: |
yes _________________ Paul Iozzio
www.iozziowheels.com |
WVbugman Samba Member
Joined: February 03, 2005 Posts: 68 Location: Petersburg, WV
Posted: Wed Dec 02, 2009 8:48 am Post subject: New "early style" 17" Forged Fuchs-style prot |
How do think 195/45r17 tires would work? They are .25" more narrow and .4 " taller than 205/40r17's. I could use the extra height to avoid bottoming out and the taller sidewall should ride better. I am worried the extra height may cause rubbing issues but being more narrow could help to offset any rubbing. |
Iozzio Samba Member
Posted: Wed Dec 02, 2009 10:39 pm Post subject: |
I need more info, what model vw, year, suspension setup, etc. Thanks _________________ Paul Iozzio
71-BEETLE-SEDAN Samba Member
Posted: Thu Dec 03, 2009 3:16 am Post subject: |
Okay they olok sick as.
Is anyone in australia selling them?
And would they fit a 71 beetle with discs up front and drums up back. No widened fenders and no narrowed beam?
Chers Josh |
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3150 Location: Goodyear, AZ USA
Posted: Thu Dec 03, 2009 3:31 pm Post subject: |
okay, how much i spostage to the east coast of aus roughly. |
vweddie Samba Member
Joined: September 22, 2005 Posts: 172 Location: Ky....via El Monte, Ca.
Posted: Sun Dec 06, 2009 8:02 pm Post subject: |
scottz wrote: |
66fasty wrote: |
Is that Ghia on an IRS pan?Doesn't look to have much camber. I'm interested in a set for my 64 ghia on a 74 IRS pan. |
I would also like to know the specs on that Ghia if you have them.
Narrowed beam, how much? Short axels, adapters, etc...
Thanks!
I'd also like to know the info. on this set up. _________________ T.B.D.
79 El Camino
12 Scion Tc |
kostya.lyt Samba Member
Joined: December 20, 2007 Posts: 71 Location: Pearland, TX
Posted: Thu Dec 10, 2009 9:38 pm Post subject: |
Hmm, I wonder what these would look like on a Split Window Bus. |
Iozzio Samba Member
Posted: Thu Dec 17, 2009 10:47 pm Post subject: |
With the right suspension they should look killer. _________________ Paul Iozzio
63 rag and a 914 Samba Member
Joined: January 16, 2009 Posts: 13 Location: Penn Valley
Posted: Mon Dec 21, 2009 1:05 pm Post subject: |
It sucks that I am just a broke college student. If I could I would order two sets one set foe the 63 bug and one set for the 914. For now I will be rockin 15 inch fuchs! |
Iozzio Samba Member
Posted: Tue Dec 22, 2009 9:45 pm Post subject: |
Save your pennies, maybe ask Santa for a set! _________________ Paul Iozzio
Beetspeed Samba Member
Joined: July 30, 2004 Posts: 429 Location: The Netherlands
Posted: Sat Jan 02, 2010 3:46 am Post subject: |
What are the final weights of the 3 wheel width sizes?
Tnx,
Walter _________________ '75 SB 1303 2,4ltr T4 turbo: 10.58 @ 129.9mph
'65 Ruska buggy 1192cc EFI 80hp N/A |
Crankey Samba Member
Posted: Sat Jan 02, 2010 9:37 pm Post subject: |
any chance of a 5x112 bolt pattern ? for vanagon ?
what's the ET on them...best go back through the thread
nice work they look sweet. |
Iozzio Samba Member
Posted: Sun Jan 03, 2010 12:45 pm Post subject: |
Beetspeed wrote: |
Tnx,
Walter |
I know for sure that the 17X7 comes in at 20.5lbs so the 8 will not be much more. _________________ Paul Iozzio
Iozzio Samba Member
Posted: Sun Jan 03, 2010 12:47 pm Post subject: |
[quote="Crankey"]any chance of a 5x112 bolt pattern ? for vanagon ?
nice work they look sweet.[/quote
I believe the smallest I can do is 5X114, I can check. The ET is adjustable from 12mm to 80mm on these wheels.
So I found out that a 5X112 pattern is available. _________________ Paul Iozzio
Iozzio Samba Member
Posted: Sun Jan 24, 2010 2:07 am Post subject: |
Petes bug with my detailed 17's
Iozzio Samba Member
Posted: Sun Jan 24, 2010 2:09 am Post subject: |
Blakes bug with a set of polished 17's
buggyboyshane Samba Member
Joined: December 08, 2004 Posts: 72 Location: newcastle northern ireland/ Valley Springs California
Posted: Wed Feb 03, 2010 11:40 am Post subject: |
Iozzio wrote: |
hi buddy, would love a set of these wheels and just want to check set up.
the picture above- could you tell me wheel specifics and suspension specifics- eg, et, narrowed, wider wings etc etc
cheers
shane |
Iozzio Samba Member
