j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Thu Jan 14, 2010 9:17 pm Post subject: |
ftp2leta wrote: |
Nothing... like always. |
I drove mine about 16 miles round trip, today..
listening to the 'thump, thump' of the big Addco sway bar bouncing around in the crappy Addco hardware mounts..
thinking, "I really need to get down there and shim those out" _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
hippiepilot Samba Member
Joined: June 18, 2008 Posts: 455 Location: Sarasota, FL
Posted: Thu Jan 14, 2010 9:19 pm Post subject: |
dreamed about having the funds to fix all of her issues someday. _________________ 83 air-cooled Westy
91 Carat (daily driver)
http://www.changeisland.com |
Kopasz Samba Member
Joined: August 15, 2008 Posts: 241 Location: Portland, OR
Posted: Thu Jan 14, 2010 10:01 pm Post subject: close-up pictures of LATCH install |
I got a PM asking how I made this work so I figured I would post pictures here for others to see as well. LATCH is a safetly restraint system used with some children's car seats (Lower Anchors and Tethers for Children). The system I am showing here is actually only Lower Anchors.
adam |
morymob Samba Member
Posted: Fri Jan 15, 2010 5:40 am Post subject: |
After a couple weeks in deep freeze it was actually above freezing so went out and it ('86syncro) started up like usual and went for a couple drives about 60 mi to checkout before going on a 500+ mi trip this weekend. Ready to roll! Seems like every time we take a trip the gas spikes about 50+ cts gal, 2.70 now. I sure like the Hankooks on dry /wet roads but they SUCK in the snow. |
H.B. Samba Member
Joined: September 09, 2009 Posts: 13 Location: Vancouver, BC
Posted: Fri Jan 15, 2010 11:04 am Post subject: |
My first repair of my first car...
I managed to replace my clutch slave cylinder after it was leaking for weeks already and it just poured out of it after I cleaned it.
As of recommendation from my local shop I also replaced my ox-sensor, as it was getting a bit lazy.
Now the lady is up and running again, better than ever - at least for the time I owned it... _________________ '85 Vanagon L
- Kombi
- 1.9l Wasserboxer
- sunroof |
type47 Samba Member
Joined: April 19, 2007 Posts: 31 Location: Vienna, VA
Posted: Sat Jan 16, 2010 7:47 am Post subject: |
After a long cold spell, I moved my Vanagon a couple of days ago and later came out to a stream of liquid on the driveway. Deduced it was brake fluid coming out of the passenger side drum; could "only" be a wheel cylinder, so yesterday with the temps going up to the 50's, I spent the day (took most of 2 hrs getting the lugs nuts and bolts loose) replacing the cylinder. This morning I hope to adjust the shoes and should be good for a year as that's the warranty on the Made-in-China part |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sat Jan 16, 2010 9:10 am Post subject: |
Washed the '91 today, since it was almost 40 degrees out !!
The Vanagon was pressed into service when my daughter came home for the Holidays, she drove my Jetti Wagon, I drove the Bus in the SALT
_________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
TroySmith80 Samba Member
Joined: October 09, 2008 Posts: 272 Location: Bend, OR
Posted: Sat Jan 16, 2010 10:10 am Post subject: |
Yesterday i mated the transaxle to the smallcar bellhousing and 2004 subaru 2.5L. Found out that my subaru starter is from an automatic and i need to get one from a MT subaru.
Tonight i work on wiring in the smallcar modified subaru harness. Shouldn't be too big of a job since SC already did the hard part. _________________ 1984 Westfalia Wolfsburg - 2.5L Subaru - Sold - Preparing to move to the dark side (4x4 Ford van) |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Sat Jan 16, 2010 10:21 am Post subject: what I did |
Re and Re axles and packed bearings. _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
buildyourown Samba Member
Posted: Sat Jan 16, 2010 10:30 am Post subject: Re: close-up pictures of LATCH install |
agpushkas wrote: |
adam |
Got any bigger pictures?
It's kind of hard to tell what you got going on there without a bigger context.
I need to do this before the summer road trip season starts. |
SyncroChrick Samba Member
Joined: January 10, 2005 Posts: 1010 Location: San Francisco, CA
Posted: Sat Jan 16, 2010 10:36 am Post subject: |
Fix the hand brake cable. |
surfcitylocal Samba Member
Joined: September 27, 2009 Posts: 22 Location: Huntington Beach CA
Posted: Sat Jan 16, 2010 10:46 pm Post subject: |
Replaced the front disk brake pads.
Installed new battery. _________________ Live to Surf, Surf to Live |
JunkYarDog Samba Member
Joined: March 11, 2007 Posts: 676 Location: New Mexico
Posted: Sat Jan 16, 2010 10:53 pm Post subject: |
I removed my instrument cluster and tore it apart to clean. Got it all back together and everything still works . Now however I discovered there were some lights not working and after a little research in this forum I am waiting on some LED's to install in place of the excisting lights. _________________ I have never owned a VW I didn't like, but there have been a few Fords and Chevy's.
85' GL Sunroof
68' Beetle sedan
72' Chevy C10 (LWB Step)
(67' Volvo 122S pending) |
jacob. Samba Member
Posted: Sat Jan 16, 2010 11:15 pm Post subject: |
hippiepilot wrote: |
dreamed about having the funds to fix all of her issues someday. |
Same here. I go outside, look at my van, and imagine how great my van would be If I won the lottery (or got approved for a loan at least.)
Some day... _________________
RCB wrote: |
jacob gets razzed a lot cause he has the only GEX engine thats lasted longer than half an oil change. |
Bruskyvw Samba Member
Joined: May 30, 2009 Posts: 682 Location: Poulsbo, Washington
Posted: Sat Jan 16, 2010 11:22 pm Post subject: |
jacob. wrote: |
Some day... |
Ditto to that ditto. The van would have a new paint job and all the body work would be done the carpet would be fixed I have to hit the instrument cluster sometimes to get the speedo to work what is that all about by the way? the e-break would work. oh yeah and it would fly _________________ Current VWs: 2001 2.0 New Beetle 250k
1974 Super Beetle
Past vws: 1977 Champagne Edition I Bus (Cedar)1991 Capri Green Wolfsburg Jetta 1978 Sage Green(Taiga) Transporter 2.0 FI (Paddy) 1980 Inca Brown Rabbit Diesel LS 1969 Karmann (funky weird blue that wasn't original) Ghia Autostick 1991 Bordeaux Red Vanagon GL 1992 Tornado Red GTI 8V |
jacob. Samba Member
Posted: Sun Jan 17, 2010 12:50 am Post subject: |
Bruskyvw wrote: |
jacob. wrote: |
Some day... |
Ditto to that ditto. The van would have a new paint job and all the body work would be done the carpet would be fixed I have to hit the instrument cluster sometimes to get the speedo to work what is that all about by the way? the e-break would work. oh yeah and it would fly |
I'd have a 1.8t, big brakes, disc's on all four wheels, adventurewagen top, 16" wheels, fender flares, no rust, really nice interior, 5 speed transmission, and a completely yellow paint job. If only, if only... _________________
RCB wrote: |
snowsyncro Samba Member
Joined: January 11, 2009 Posts: 1557 Location: East Preston, Nova Scotia, Canada
Posted: Sun Jan 17, 2010 5:10 am Post subject: |
jacob. wrote: |
I'd have a 1.8t, big brakes, disc's on all four wheels, adventurewagen top, 16" wheels, fender flares, no rust, really nice interior, 5 speed transmission, and a completely yellow paint job. If only, if only... |
Aw, what the heck...
You know, jacob takes quite a bit of heat on this forum, much of it well-deserved. But I have to say that I can't help but admire the passion of the young guys that get into these vans. He wasn't even born when they were making these things. Nice list, jacob.
Today, I am going to my daughter's place to dig out my 90 Multivan from the snow. It has been waiting patiently to be rescued since the summer after a clutch line failure. I had to abort the last rescue attempt partway home. Discretion became the better part of valour. I started with no clutch -- I can handle that. Power became OK after the mouse nest blew out of the exhaust. When the brakes went (rusted lines) I had to think about it a bit. The last straw was a severe cramp in my right calf, from trying to hold the accelerator pedal to the floor with my heel, while pressing it with my toe, after it broke off from rust after a few miles.
RonC |
paddyh Samba Member
Joined: October 28, 2008 Posts: 110 Location: East Kootenays
Posted: Sun Jan 17, 2010 9:07 am Post subject: |
(yesterday)
Took my 12 yr old Blue Healer/Sheltie for (what was to be) his last ride in the Westy.
Today sucks. _________________ 81 A/C Westy
02 Impreza Wgn |
Posted: Sun Jan 17, 2010 9:10 am Post subject: |
Us young guys will have our stuff in due time hopefully. Growing up the van was my dream car while every other kid was dreaming about their first car being something fast and Asain. Then I'd say "yup I'm gonna be driving a vanagon" I said it with a huge dorky grin and they'd reply "A what?" _________________ Current VWs: 2001 2.0 New Beetle 250k
1974 Super Beetle
Mundopacheco Samba Member
Joined: November 14, 2006 Posts: 439 Location: Durango, Colorado
Posted: Sun Jan 17, 2010 9:18 am Post subject: |
Sorry Paddyh, that's got to hurt. Love the pooches!
Good luck,
Miguel |
