Notablecarrot3 Samba Member
Joined: January 22, 2008 Posts: 461 Location: Sunny South Of France
Posted: Sat Jan 16, 2010 1:16 am Post subject: Vacuum advance distributors... |
Hi guys
I'm looking to change my 009 distributor (that has a Compu Fire Electronic Ignition replacement module) I'm looking to get a vacuum advance distributor, and I'm having trouble deciding whether to go for the bosch one ( http://www.machine7.com/product.php?xProd=11945 ) or this chinese one ( http://www.machine7.com/product.php?xProd=11946 )
I guess these 2 distributors have points, is it possible to swap my compu fire electronic module into one of these 2 distributors, then put the points part back in my old distributor to sell it on?
Also I'd like some opinions on different distributors, which you guys recommend ,I can't really afford a pertronix but if you guys say it's really worth the extra cash I would consider it quite seriously...
Thanks
Tom _________________
EverettB wrote: |
Your Donkey has a large head. I like your donkey. |
EverettB wrote: |
Is it wrong to be jealous of their facial hair abilities? |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sat Jan 16, 2010 5:54 am Post subject: |
Get the Bosch one.
Your Compu Fire Electronic Ignition won't fit though. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sat Jan 16, 2010 5:58 am Post subject: |
Dont do anything until you figure out exactly what you need. Distributor and carbs MUST be compatible. Different vacuum signals from carbs, different advance curves, different vacuum canisters - Post your carb info and you will get better info.
The one you showed looks like the standard SVDA, which is fine for a 34 PICT3 and many other carbs, BUT it wont work with an H30/31 and certain other carbs. If you used it on a 30/31, it would not perform any differently than your 009. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Hammarlund Samba Member
Joined: June 15, 2009 Posts: 1539 Location: Central Texas
Posted: Sat Jan 16, 2010 9:56 am Post subject: |
Excellent advice on both counts.
Whenever there is a choice between German parts and Chinese parts, the German part is the correct choice at least ninety-five percent of the time.
Chinese parts are almost always reverse engineered and rarely if ever tested adequately during development. This is true for all kinds of parts, not just ones for Volkswagens.
Don't rule out using points. I have driven many hundreds of thousands of miles and thousands of hours in cars and farm equipment that used points, and they have never left me stranded.
Of course, this is probably because I replace them (and the condensors) as part of routine maintainance instead of waiting for them to fail... _________________ Trying to diagnose electrical problems without paying attention to what the red light is telling you is like trying to play the piano without using your hands. |
Posted: Sat Jan 16, 2010 11:33 am Post subject: |
I have a h30-31 pict solex carb _________________
EverettB wrote: |
EverettB wrote: |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76912 Location: Sneaking up behind you
Posted: Sat Jan 16, 2010 11:34 am Post subject: |
Notablecarrot3 wrote: |
I have a h30-31 pict solex carb |
Neither of those will work correctly with the H30/31PICT. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jan 16, 2010 12:19 pm Post subject: |
AS usual, Glenn has it nailed, The only SVDA that I am aware of that works with a H30/31 is sold by aircooled.net. They have an option for a different vacuum can because the 30/31 has a very low vacuum signal. As I had said, if you install the distributors that you had posted, you wil only be using the centrifigal advance, which essentially is the same as your 009. No benefit to speak of making the change. _________________ D-Dubya Manx clone - 63 Short pan,1914.
