Billyzack Samba Member
Joined: March 12, 2007 Posts: 40 Location: Phoenix, Az
Posted: Sun Jan 24, 2010 8:24 am Post subject: 66 Bug 6 to 12 Volt starter question |
I just purchased a 66 Bug and the previous owner coverted it to 12 Volts but it still has the 6 Volt starter. It starts bit is quite noisy and he told me there is a starter or bushig or something that is made for a VW Thing that will make it work better. Is it correct to keep the 6Volt starter or should I change it? If I change it, what do I change it to since the 66's were 6 volt? Will newer years work? Thanks in advance, Billyzack in Phoenix |
Jody '71 Samba Member
Joined: July 16, 2005 Posts: 2842 Location: Manassas VA
Posted: Sun Jan 24, 2010 8:42 am Post subject: |
I may not be correct here, but with the 6V starter used with a 12V system, the starter gears chews up the flywheel teeth. Thats probably the noise you're hearing, the gearing on the 6V starter gear doesn't match the 200m flywheel and spins much faster than with 12V. Take the 6V starter out and remove the bushing in the trans bellhousing. Put you an autostick starter in there, they don't need bushings. I think, but not sure. The PO was probably refering to that, not sure if a Thing starter will work. I also believe there's a 12V starter available now in 6V configuration, but that wouldn't be usable if you have a 200mm flywheel. It all depends on how the 6 to 12V change was made on your '66. Stock '66's had 180mm flywheels. _________________ '66 Beetle
2011 Hyundai Elantra Touring
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sun Jan 24, 2010 8:46 am Post subject: |
What size engine? He prolly left the 6 volt flywheel on it also. You need to pull off the starter and check the teeth on the flywheel to see if they are chewed up |
Posted: Sun Jan 24, 2010 9:11 am Post subject: engine size |
The previous owner said the original engie is in the car, a 1300cc. Where would I go to find a correct starter before I destroy the flywheel? Thanks, BZ |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Sun Jan 24, 2010 9:18 am Post subject: |
I had a 65 Beetle that was converted to 12 volts but still had the 6 volt starter. As long as the engine was in tune it started up fine. It's when you have to crank the engine a lot to start that the 6 volt starter will get damaged by having 12 volts going through it. I think the reason people leave the 6 volt starter in place when converting to 12 volts is so they can continue to use the old flywheel and avoid taking the engine out to change the flywheel. If the flywheel had been changed I don't think the 6 volt starter could be used any more because of the difference in gear teeth. _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
Stretch32 Samba Member
Posted: Sun Jan 24, 2010 9:28 am Post subject: |
I have a '66 bug converted to 12V's using a 6V starter. The only mod I have was the installation of a 12V starter solenoid to the 6V starter motor to keep it from engaging so hard. It's been on the car 5 yrs or so and works great. As long as the 180mm 6V flywheel is still on the engine like mentioned above I think you shouldn't have problems.
Stretch |
Posted: Sun Jan 24, 2010 9:34 am Post subject: Starter bushing |
I see a starter bushing on some of the VW parts sites that say "bushing will allow 12 Volt starter to work on 6 volt transmission. The bushing is around $4.00. What is that for and will that fix my problem? Thanks, Billyzack |
Posted: Sun Jan 24, 2010 9:53 am Post subject: |
No you prolly need more than the bushing. If it is a 6 volt starter still you need to pull it and look at the teeth on the flywheel, if they are good, check out the starter Glenn linked to.
The 6 volt and 12 volt flywheels ring gear and starter bendix have a different # of teeth and are not compatible. |
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Sun Jan 24, 2010 10:45 am Post subject: |
I'm using the Hybrid Starter that Glenn referred to above and love it! |
Posted: Sun Jan 24, 2010 11:36 am Post subject: |
Well, if indeed you still have a 180mm flywheel on there and a 6V starter, and that it was re-wired for 12V without making any of the modifications, your flywheel may still be ok. Only way to tell is to pull the starter, look at the gear teeth, and get in there with a good flashlight and have someone roll the engine around while you're looking at the flywheel teeth. You could always pull the engine for a more closer look at the flywheel. _________________ '66 Beetle
2011 Hyundai Elantra Touring |
Posted: Sun Jan 24, 2010 1:26 pm Post subject: Fuel gauge and wipers |
Thanks for all the help everyone. I have a related question. The lights work in this car but the wipers don't work and the fuel gauge is missing. Questions: Will the wipers run on 12 volts or do I eed to get another motor and as far as the fuel gauge, same question, I assume there must me some kind of voltsge reducer or something but again I am lost. I am happy to see there are not a lot of accessories on these cars but I would like to get the ones it has working. Thanks, Billyzack |
Posted: Sun Jan 24, 2010 3:00 pm Post subject: |
66 should have mechanical gas gauge. And you need to see if the wiper has been switched to 12 V, prolly not. |
Posted: Mon Jan 25, 2010 8:07 am Post subject: |
Go up above and click on the sticky FAQ's, then click on 6V to 12V. A wealth of information regarding what is required for the conversion. See if you can find a suitable gas gauge assembly in the classifieds. _________________ '66 Beetle
puttin slow Samba Member
Joined: March 28, 2007 Posts: 67 Location: garden grove
Posted: Mon Jan 25, 2010 9:51 am Post subject: |
same thing for me. I bought a 66 about 10 years back. It had been sitting for 17 years. It had a 1776 with a 180mm flywheel and a 6 volt starter. The car was 12 volt. Starter went out and I had no idea that the flywheel was still small and tried to install a 12 volt starter. Didn't work. Pulled the motor, grinded the bellhousing down and the grease caught on fire and had to grab the extinguisher...... anyway... put a 200mm flywheel and was satisfied. good times |
Rcooper Samba Member
Posted: Sun Aug 05, 2018 9:36 am Post subject: Re: 66 Bug 6 to 12 Volt starter question |
I have a 66vw converted to 12v. It still has 6v starter and tranny. My question is. There is a small box next to the starter that has red power cable's running to it then run back out to engine area to the distributor box. Along with a small black wire running from starter to ignition coil. With a small round thing solderd in the middle of it. |
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
Posted: Sun Aug 05, 2018 11:49 am Post subject: Re: 66 Bug 6 to 12 Volt starter question |
Installing a 12V solenoid on a 6V starter does not fix the problem. The gear is engaged before the motor is energized. Look inside the solenoid, the contacts are at the bottom, which means the motor is not connected to the battery until the gear is all the way out. Grinding is due to a damaged flywheel, which is caused by running a 6V starter in a 12V system.
The people who say "I RAN A 6V STARTER ON 12V FOR YEARS WITH NO PROBLEMS" don't post a pic of the damaged flywheel, however, you can see what happens in the pic below.
Look at this slow motion video showing the inner action between a starter gear and the flywheel.
This could be your problem after running a 6V starter in a 12V system. Pic sent to me by a customer after buying a Hybrid 6/12 starter.
_________________ Additional products https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231 |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Sun Aug 05, 2018 12:17 pm Post subject: Re: 66 Bug 6 to 12 Volt starter question |
Rcooper wrote: |
. . . My question is. There is a small box next to the starter that has red power cable's running to it then run back out to engine area to the distributor box. Along with a small black wire running from starter to ignition coil. With a small round thing solderd in the middle of it. |
Hey Rcooper . . . welcome to TheSamba Forum!
What is your question?
Tip . . . a picture is worth a thousand words!
Have a look at a "Hard-Start-Relay" . . .
(photo from TheSamba Gallery)
FWIW . . . I RAN A 6V STARTER ON 12V FOR YEARS WITH NO PROBLEMS. I don't have a photo of the damage I caused.
The car kept workin' for 99,000 miles before I sold it, so I had no need to remove the engine! _________________ Jesucristo es mi Seņor y Salvador! |
Posted: Sun Aug 05, 2018 12:37 pm Post subject: Re: 66 Bug 6 to 12 Volt starter question |
Thank you. Nice to be here. Kinda new to vw stuff. That hard start relay is that normal or a after product when going to 12v. I'll post pics asap. |
