SRP1 Samba Member
Posted: Thu Jul 10, 2008 7:56 pm Post subject: |
vdub wrote: |
I totally get what your saying but even though all that would do is lower the .050 duration which would make the cam closer to the specs of the cheater cam. |
Very true. |
1432 Samba Member
Posted: Thu Jul 10, 2008 9:07 pm Post subject: |
based on numbers given, of your three choices the FK-41 still looks the best to me with either 1.1 or up to 1.3 rockers. that cheater cam looks pretty soggy with relatively high advertised and nothing @ .050" |
vdub Samba Member
Joined: September 07, 2003 Posts: 442 Location: Valley Springs, Ca.
Posted: Thu Jul 10, 2008 10:27 pm Post subject: |
1432 wrote: |
Yeah but the choice is harder because I am tying to go economy.
If I wanted to go fast i would just go all out but I am shooting for 30MPG.
I think the displacement will give me tons of power its harder though picking a cam when you want to save gas.
Its funny I was talking with a buddy today about how much easier it would be if I was building a small block Chevy because if I didn't like the cam I could just change it but with a VW I have to break the whole motor apart to change the cam. It makes for a much harder choice. |
grimace007 Samba Member
Joined: August 30, 2006 Posts: 2673 Location: swampville, florida
Posted: Thu Jul 10, 2008 10:35 pm Post subject: |
i honestly think your making a mountain out of a mole hill with this cam descision. your state of tune on the engine will affect your MPG more than the difference between the few cams you have listed.
if your engine isnt tuned properly it doesnt matter what cam you run youll get shitty results. bottom line.
heck if mid 20s can be seen form a 200hp motor w/ idas 30 should be a cakewalk with small displacement and kadrons or 36 dells
just measure your deck, set the compression to what your cam likes and tune the timing/carbs properly and youll see 30mpg unless you drive like and asshat _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. |
cr@M wrote: |
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory. |
1432 Samba Member
Posted: Fri Jul 11, 2008 6:51 am Post subject: |
the comments Grimace made are about all that needs to be said, beyond that I would just add that smaller cams require more conservative thinking when considering compression ratios. |
vdub Samba Member
Posted: Fri Jul 11, 2008 7:06 am Post subject: |
Your probably right but this car has been in dry dock for 4 years and I am just trying to do everything right before its on the road again.
It has all brand new brakes with dot 5 fluid suspension and shocks are new. everything that I could fix I have and I am almost ready to drive it so I want to make sure everything goes right. |
vdub Samba Member
Posted: Sat Jul 12, 2008 12:45 am Post subject: |
I had a funny reply.
The reason i am building this engine is so I can drive like an asshat and still get good gas mileage.
jg405i Samba Member
Joined: January 01, 2007 Posts: 40 Location: Oceanside, Ca
Posted: Sat Jul 12, 2008 3:41 am Post subject: cb cam |
1300cc and 28 pic getting 28 mpg all day |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Tue Jan 26, 2010 5:18 am Post subject: Re: cb cam |
jg405i wrote: |
But you can't drive like an asshat with a 28PICT. My 1915 turbo gets mid 20's, and it's fast enough to kill me. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
