allihjelm Samba Member
Joined: April 29, 2009 Posts: 231 Location: Akureyri, Iceland
Posted: Mon Jan 25, 2010 5:35 am Post subject: Renovating roof rack |
Hi there,
As some of you might know I am renovating an old roof rack for my 67 Beetle.
I have a few questions for the ones of you who have renovated your roof rack:
- What kind of substance should I use on the wooden slats? What color is closest to the original, reddish, clear or ?
- I have a repro sticker to be put on one slat. Where should the sticker go? Front or back / left or right, near the Made in Germany marking on the rack itself?
- Also, I would be glad if you could give me the exact measurements between the legs of the roof rack in front, middle and rear. The roof rack I have has been bent a little, enough to not fit on the roof.
Thanks, Al _________________ 1967 European 6V Volkswagen 1300 Beetle |
the-jerm Samba Member
Joined: March 14, 2007 Posts: 1169 Location: Sarasota, Fl
Posted: Mon Jan 25, 2010 6:04 am Post subject: |
I purchased an empi rack and, of course, the wood is junk. I've been debating what to replace it with as well. Teak has been suggested to me a couple of times but I would prefer something lighter. |
Posted: Mon Jan 25, 2010 3:14 pm Post subject: |
I forgot to mention that I have had the wooden slats made for me as close to the original as possible, out of oak. _________________ 1967 European 6V Volkswagen 1300 Beetle |
Steve Herndon Samba Member
Joined: November 26, 2009 Posts: 146 Location: Walnut Creek CA
Posted: Mon Jan 25, 2010 4:39 pm Post subject: |
Over the holidays I broke mine down, drilled out the rivets; pulled the wood. Sanded and refinished the wood with clear varnish (6-8 coats) and painted the steel with rattle-can gloss grey. I put surgical tube on the feet and put it back together with stainless machine screws and nuts in place of the rivets. Definitely not museum quality restoration, but I like it. As well, did volkswagon ever make these or are they all aftermarket and knock offs? Mine wasn’t particularly well made, and I looked for a manufacturer stamp and found none.
Steve
'63 HT 6v Ruby Red |
Posted: Tue Jan 26, 2010 11:00 am Post subject: |
How about the slats themselves. Do the all lie on the center tube?
On my rack they are about inch away in each and but in the middle the slats rest on the tube. Should the surface be flat from the front end to the back or should the surface sway as the roof rack itself?
Sorry, a lot of questions but I'm trying to make the rack as original as possible.
Thanks, Al. _________________ 1967 European 6V Volkswagen 1300 Beetle |
scottvw Samba Member
Joined: November 17, 2004 Posts: 2821 Location: Centennial, CO
Posted: Tue Jan 26, 2010 2:34 pm Post subject: |
You might want to a search on roof racks in the Accessory section. There are some threads in there that talk about redoing a rack.
As for the measurements, I would just worry about making it fit your roof correctly. The are easy to bend into shape. |
