DannoT Samba Member
Joined: September 15, 2007 Posts: 249 Location: Up where the air is thin
Posted: Tue Jan 26, 2010 8:30 pm Post subject: Broken Clock repair |
Ok so after much procrastination i have gotten around to fixing my bus's clock after taking it apart and adding machine quality clock oil every thing runs smoothly but when hooked to electricity it doesnt run. T clarify when i pull back the winding spring and reliece it all the cogs and springs work and even turns the hands of the clock but fails to rewind the spring on its own i have thouroly cleaned it but still no success. I do not know what the problem is and i do not know how the electic motor rewinds the clock. any suggestions on how to procede?
the fuse of the clock is intact
I think this arm has something to do with the winding of the clock |
DannoT Samba Member
Posted: Tue Jan 26, 2010 8:35 pm Post subject: |
Ok I hooked the clock up but could not get any ohm readings and cold not get a voltage past where the wires connect after further inspection I noticed the part of the negative terminal is spring loaded so I think there might be a fuse or something that goes in there but i dont know.
The negative terminal and the quick connect that is spring loaded
This is the inside of where the wires connect to the clock it is spring loaded and it looks like something was once soldered in there |
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Tue Jan 26, 2010 8:37 pm Post subject: |
Don't know anything about clocks, but that's a bulb holder. Same as in the speedo. _________________ Tim |
DannoT Samba Member
Posted: Tue Jan 26, 2010 8:45 pm Post subject: |
I feel really stupid that makes complete sense thank you for the help ill give it a try. |
VolksFire Samba Member
Posted: Tue Jan 26, 2010 8:57 pm Post subject: |
if you were trying to ground the clock by the light socket, thats why its not working. lol. you need to connect a ground to one of the threaded posts or the body of the clock. IIRC, i dont remember there being a ground tab on these clocks. i bet it works.
also, you should stick to your original thread to minimize repetitive posting. thanks.
http://www.thesamba.com/vw/forum/viewtopic.php?t=357329 _________________ Jahnai Pearson - VW Restoration Technician
60 Double Door Panel
63 Double Cab
63 Single Cab
67 SO42 Westfalia
73 Thing
76 Kombi
82 Westfalia Deluxe
82 Quantum Coupe
85 Quantum Sedan
85 Quantum Syncro Wagon
96 Golf GL |
