BUGTHUG Samba's Rented Mule
Joined: April 22, 2007 Posts: 833 Location: KANSAS toto's fire hydrant
Posted: Mon Sep 28, 2009 3:36 pm Post subject: |
What is the size of bolt for a 66 type 1 steering stop . This bolts to the welded area on the beam that is adjustable for the steering arm to stop against when you turn the steering to the max. Best I can explain. _________________ I know you would understand what I'm saying if you could just see my HANDS
Even the middle of the week says W T F
1963 15 window bus
1966 VW bug
1966 21 window micro bus
1969 Dune Buggy
1965 VW bug
1974 VW bug
1972 Kelmark, VW drive line
1948 Chevrolet Hearse |
glandnut 40 horses of Fury
Joined: February 26, 2003 Posts: 1432 Location: J-ville, FL
Posted: Thu Jan 14, 2010 9:20 pm Post subject: |
Maybe not technically appropriate, but I get constantly asked. Hurst shifter knob/shaft thread size= 3/8 X 24. _________________ Looking for aluminum single port Kadron manifolds. |
tirekicker Samba Member
Joined: October 16, 2007 Posts: 826 Location: Orange, CA
Posted: Wed Feb 03, 2010 6:34 pm Post subject: |
_________________ DhK
Phuckancer
(16:45:42) Russ_Wolfe: TK, you are like a Maytag washer
(16:46:44) tirekicker: and what's a maytag washer?
(16:47:35) Russ_Wolfe: If you are not agitating, you are not working right |
FritzCP Samba Member
Joined: October 23, 2005 Posts: 463 Location: Wisconsin
Posted: Tue Feb 23, 2010 2:54 pm Post subject: |
Wide Five early Lugnuts/ Lug bolts are M12 x 1.50
I needed this because the torque meister wont allow for lug nuts to attach it to drums (too short) |
tstracy39 Samba Member
Joined: May 14, 2008 Posts: 3294 Location: Seattle, WA
Posted: Thu Mar 04, 2010 3:34 am Post subject: |
1967-71 VW Beetle/Ghia gear shifter knob: 7mmX1.0
68-79 Beetle/Bus/Ghia/Thing shift knob: 12mmX1.5
Outside diameter of 8mm case savers: 12mmX1.5 _________________ Check my classifieds for kewl gauges:
http://www.thesamba.com/vw/classifieds/search.php?username=tstracy39
EverettB wrote: |
I like your fork. |
dsmetanick Samba Member
Posted: Fri Oct 08, 2010 9:15 am Post subject: |
Please advise: What is the drill bit size needed to change my 12mm break drum lug bolt threads to 14 mm threads? Note I do not want to install press in studs (which is a bigger drill bit, I want to install either lug bolts or screw in studs). What is the pitch of the tap? Is the tap a 14 mm? I appreciate your advice. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri Oct 08, 2010 10:19 am Post subject: |
The late model lug bolt thread pitch is 14x1.5mm. (considered fine thread) The tap drill is 12.5mm _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Ea$y Money Samba Member
Joined: August 26, 2006 Posts: 139 Location: Fallon, NV
Posted: Sat Apr 30, 2011 3:21 pm Post subject: |
can anyone help find what size bolts/screws i might need. it's the hardware for the steering column support that attaches underneath the dash for a '66 bus. it requires 4 bolts/screws. i think there are 2 different sizes. just to clarify, its the piece you always hit you knee on when getting into your bus. thanks! _________________ 1966 Microbus Deluxe |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
banditwolf Samba Member
Posted: Tue Nov 08, 2011 4:17 pm Post subject: |
From my 73 Super Beetle
Door hinges: 8 x 1.25 mm (threads approx 10mm), tapered head screw
Door latch: 6 x 1.00 mm (threads approx 8mm), tapered head screw _________________ 1973 Super Beetle l 1981 Trans Am |
vacajar Samba Member
Posted: Wed Mar 07, 2012 6:31 pm Post subject: Engine mount bolt size |
Im looking for the engine mount stud size for the back of the case and also the the top bolt on the drivers side. If it changes anything it is a Mexico Block From 73. Thanks |
Empicollector Samba Member
Joined: March 02, 2002 Posts: 316 Location: Seattle, WA
Posted: Sat Apr 28, 2012 2:26 pm Post subject: |
How about the size of the bolts in the end of the steering box? The ones that will scrape if you are lowered----lol. On a 67 type 2 |
Tucky Samba Member
Joined: April 24, 2012 Posts: 16 Location: Puerto Rico
Posted: Wed May 02, 2012 7:39 pm Post subject: |
Hello.
I'm looking for the size of the bolts that attach the bumper brackets to the body
Thanks. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76912 Location: Sneaking up behind you
Posted: Wed May 02, 2012 7:41 pm Post subject: |
Tucky wrote: |
Hello.
Thanks. |
What vehicle?
M8x1.25 would be the most common. _________________ Glenn
Member #1009
#BlueSquare |
19super73 Hardcore Stock Nazi
Joined: October 18, 2007 Posts: 4351 Location: Cité Soleil
Tucky Samba Member
Posted: Fri May 04, 2012 4:03 pm Post subject: |
Thanks a lot. Im going to the hardware store tomorrow to buy them |
Pepo Samba Member
Joined: December 22, 2009 Posts: 21 Location: Ketucky and Florida
Posted: Fri May 18, 2012 5:17 am Post subject: Only metric sizes on the origianl VW? |
Well, I just came back from Europe, had a great time and some interesting discussions. Among them was a statement from a friend wo is a long-time mechanic, mostly Mercedes. He maintains that all items on the original VW, i. e. Beetle were always metric. I challenged that by quoting the wheel sizes as 14 inch or 15 inch. He denied it and claimed that they are in metric conversions. I also quoted my experience with the oil pressure sensor connection to the block that I always found to be 1/8" NPT (National Pipe Thread). Can anyone verify my opinions and give me a source to copy?
Thanks, _________________ Take care and have fun..... |
jehugarcia Samba Member
Joined: October 15, 2012 Posts: 315 Location: Rancho cucamonga
Posted: Fri Nov 16, 2012 2:36 am Post subject: Cargo door hinge screws |
Type 2 bus Cargo door hinge screws size is 8 X 1.25mm
you can find the tap at McMastercar part # 8305A19 Metric High-speed Steel Hand Tap, Taper, 8 X 1.25mm, D5 Pitch Dia, 4 Flute
and the Drill bit for the tap is item # 2958A113 Metric Black Oxide Hss Jobbers' Drill Bit, 6.7mm, 101mm Oal, 49.6mm Drill Depth,118 Deg Point
Now does anyone know what size the Engine lid hinge screw thread size is? I need to clean the threads on mine.
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Fri Nov 23, 2012 11:30 am Post subject: Re: Cargo door hinge screws |
jehugarcia wrote: |
6mm X 1.0 |
germansupplyscott Samba Member
Posted: Wed Dec 12, 2012 9:34 pm Post subject: Re: Only metric sizes on the origianl VW? |
Pepo wrote: |
Thanks, |
oil pressure switch threads are m10 x 1.0 straight, not NPT.
the only inch fasteners on a VW are the seat belt hardware which are all 7/16" -20. _________________ SL |
