type 3 motor options
Page: Previous  1, 2, 3  Next
cschuck14
cschuck14 is offline
PostPosted: Fri Feb 05, 2010 8:10 pm    Post subject: Reply with quote
ok. as of now these are my options
1. buy used fi motor for 650 shipped
2. buy fi off of that motor and harness
3. buy a 914 with 4 extra motors for 290 plus trailer rental and gas
4. buy donor square with fi for around 1k
Notched
Notched is offline
PostPosted: Fri Feb 12, 2010 6:08 pm    Post subject: Reply with quote
Russ Wolfe wrote:
The VW engine case is magnesium. It burns, instead of welding.
You cannot weld something on.
I thought you could weld the mag cases? Isn't the space behind number 3 cylinder welded on mag cases sometimes?
This isn't the pic I was looking for, but this case was welded.
[/img]
Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org
Russ Wolfe
Russ Wolfe is offline
PostPosted: Fri Feb 12, 2010 6:21 pm    Post subject: Reply with quote
You can tig it. but with special very expensive tig rod.
My guy that does my heads can do them, but he has not done one for years, and does not like to do them.
It would be hard to find some one that is set up to do them.
Gary: OK. Ima poop.
Notched
Notched is offline
PostPosted: Sat Feb 13, 2010 12:51 am    Post subject: Reply with quote
I get ya. Definitely not something someone could MIG weld.
Phillip Bradfield
JSMskater
Samba Grease Gorilla
JSMskater is offline
PostPosted: Sat Feb 13, 2010 1:58 am    Post subject: Reply with quote
some of the expensive MIG welders might be able to do it with special wire and stuff, but I don't know for sure. When I took my welding class, we did go over the different rods available (for TIG) so you can do more exotic metals. I asked my teacher specifically about doing Magnesium cases (he used to be a dubber himself) and the look of horror was enough to crush any ideas I had about fixing up old cases Laughing
you'd have thought he was flashing back to a traumatic war story or something...
71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI Harnesses!
Notched
Notched is offline
PostPosted: Tue Feb 16, 2010 10:31 am    Post subject: Reply with quote
Laughing That's funny.
Phillip Bradfield
cschuck14
PostPosted: Tue Mar 23, 2010 1:55 pm    Post subject: Reply with quote
so what do i need to convert my 72 engine to a carb so i can just get on the friggin road?
i bought fuel injection parts from a guy in nc, john berrier or something and he didnt send them to me soo im getin my money back from paypal and now i just want to DRIVE so ive been searchin about how to convert to carbs... can anyone help?
squaretobehip
squaretobehip is offline
PostPosted: Tue Mar 23, 2010 2:35 pm    Post subject: Reply with quote
...just take it to a reputable vw shop already. that way it can be done by someone who knows what they are doing.
1965 Baltic Blue S Model Squareback
1963 Ruby Red Notchback
The 2021 Type 3 Rally is moving to SoCal! October 1st-3rd! Be there!
[email protected] - Questions/Comments
Bobnotch
Bobnotch is offline
PostPosted: Tue Mar 23, 2010 2:37 pm    Post subject: Reply with quote
I'm going to make an assumption that the FI has been removed, and you're basically looking at a long block in the engine bay. If I'm wrong, then you'll have to remove the FI runners and IAD (Intake Air Distributor), along with the AAR unless you're using a low pressure electric fuel pump, then it can stay where it is.
However since you have a 72, you're going to need to change the breather box, and do something with the ports (short tubes) in the cylinder heads.
Anyway, you'll need a set of carbs, dual port intake manifolds, a fuel pump (mechanical or low pressure electrical), and carb linkage. If you decide to go with a mechanical fuel pump, you'll also need the bakelite spacer, and a fuel pump push rod that matches the pump you buy (try and get it for a generator, as that was what the 67 and earlier cars used).
The choice of carbs will also be yours, as some here prefer the Solex carbs (unfortunately they'll probably need rebuilding), or weber 34 ICT carbs. If you go with the webers, get them as a kit from CB Performance, as they'll be jetted pretty close for your engine, and have a balance tube (it's actually a hose) which our engine like. They'll also come with everything you need to install them, except the fuel pump.
You'll have to remove the stock t-3 electric fuel pump that's located under the fuel tank (usually on the right side of the beam), and route a new fuel line from the tank to the left fuel tube in the pan. Then you can add a fuel filter in the rear along side the trans (or put it under the tank like it was), as I prefer to filter the fuel after it goes thru the tunnel with carb motors. It also makes it easier to change, as you have more room to work. The next thing will be to remove the power wire that goes to the FI relay from the battery. This kills the power to the rest of the FI system that can be left in place, or removed if you want. If the car still has the FI wiring harness still in the car, you'll want to remove it and the ECU, and unplug the 3 or 4 wires that connect it to the car's wiring harness. The rest of the car's wiring can remain just as it is. I hope this helps.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Max Welton
Max Welton is offline
PostPosted: Tue Mar 23, 2010 4:57 pm    Post subject: Reply with quote
Sil Modesti in Phoenix. But you have to bring your own magnesium rod.
Max
cschuck14
PostPosted: Tue Mar 23, 2010 8:53 pm    Post subject: Reply with quote
thanks bobnotch!!!!
Rome
Rome is offline
PostPosted: Mon Mar 29, 2010 3:50 pm    Post subject: Reply with quote
Bob- doesn't he have to also replace the two studs on his case with longer ones so he can mount a mechanical fuel pump?
Also- make sure you change ALL fuel hose on the entire car with new stuff, and use "fuel injection" type hose clamps. Whatever hose is on there is likely to be cracked, or soon to be.
cschuck14
PostPosted: Tue Apr 13, 2010 1:42 pm    Post subject: Reply with quote
the previous fuel lines are toasted becasue the mechanic who replaced them last, instead of using clamps with screws to tighten them on the fittings, used wire and wraped it around the line and twisted it tight like a twist tie hah then it caught on fire.
anyways, i got my wiring harness and now im looking for the 2 fuel injectors on the left side, and im pretty sure thats it, these are the new parts im buying
alt
fuel pump
dist-wires
hoses
belt
thinking about replaxcing the oil pump while i got the motor out
also any suggestions on dropping the motor? i have the haynes
how do the wires that controll the tail lights get back to the tail? where exactly do they run through the car?
Mike Fisher
Mike Fisher is offline
PostPosted: Tue Apr 13, 2010 2:05 pm    Post subject: Reply with quote
You have to remove both rear fenders to access the tail light wiring. Don't miss the tiny screw under the hatch rubber.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
cschuck14
PostPosted: Wed Apr 14, 2010 6:48 pm    Post subject: Reply with quote
so all my wires burned up, this wiring loom, http://www.jbugs.com/product/WM-311-62-67.html?Category_Code=1290 is this all i need since i already have the engine wiring harness? this loom will work the tail lights?
also i dont really know what its supposed to look like and where things are supposed to go ? i think the coil burned to ash cause i couldnt find it
also- about droping the engine, any tips for removing the engine and keeping the trans held in place?
there are a bunch of little things around the left side of the engine bay what are they? i need them whatever they are
thanks for any help its greatley appriceated, i hope to be on the road soon in this sweet little thing
Tram Premium Member
Samba Socialist
Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Tram is offline
PostPosted: Wed Apr 14, 2010 7:06 pm    Post subject: Reply with quote
Welding a VW case is kind of like trying to weld a Molotov cocktail. You'd better have the right equipment, excellent skills, and brass balls.
May 4, 1970- 50 years- NEVER FORGET!! Sad
vwfye wrote:
Oh the joy of custom things...
RIPRW
"I'm very fond of long walks, especially when taken by those who annoy me."- Fred Allen
cschuck14
PostPosted: Mon Apr 19, 2010 10:07 am    Post subject: Reply with quote
heres what i need. i need the wires off of a running engine or i need a diagram to show me what to buy or what wires to make length to cut and where they go
i need the plastic parts mounted on the cars left side of the engine bay or i need to know what they are to order them, i cannot find pics or diagrams to tell me what parts these are can you help?
Mike Fisher
PostPosted: Mon Apr 19, 2010 10:25 am    Post subject: Reply with quote
PAY JSMskater to build you a New wiring harness and sell you the injectors etc. that you need. Idea
cschuck14
PostPosted: Wed Apr 21, 2010 11:05 am    Post subject: Reply with quote
what is all that junk on the left side of the engine?
Mike Fisher
PostPosted: Wed Apr 21, 2010 11:09 am    Post subject: Reply with quote
Buy the Bentley Manual! Rolling Eyes
Page 2 of 3
