speedygeorge Samba Member
Joined: November 28, 2009 Posts: 235 Location: Victoria, BC
Posted: Sun Feb 14, 2010 11:33 am Post subject: Bled Brakes, How Far Should Pedal Go Down When Completed |
I just bled my 91 brakes for the first time (my first try not the brakes first time), had to do 2x due to air when spotter didn't tell me fluid was low.
Took it out for a spin after and pedal goes down about 1/3 way to floor (a few inches) before totally firm, what would be ideal after bleeding brakes for stock set up? |
mike boland Samba Member
Posted: Sun Feb 14, 2010 11:43 am Post subject: Re: Bled Brakes, How Far Should Pedal Go Down When Completed |
speedygeorge wrote: |
First thing you should do is adjust the rear shoes. its kind of a pain in ass as its hard to see in the adjuster hole. its up there on upper middle of the backside of the backing plate, adjust them till there is slight drag on the wheels,(you don't need any special tools a screw driver will work but I find 90 degree brake spoon to work well.) then do the emergency brake cable adjustment. after finish that do bleeding again.. pedal should be much better. How much depends on thickness of your shoes / pads and if the rear drums or front rotors are worn.
My 1991 has good solid pedal. but I have new shoes / drums / pads & rotors as well as drums adjusted / emergency brake cable adjust.
another thing to consider id age of the rubber brake hoses. when they get old they "expand" inside like a balloon, but you don't see it outside the hose... I have a new stainless steel braided brake lines, but haven't gotten around to installing them yet. |
