Swing Axle VS. IRS !! Beat this to death..
Page: 1, 2, 3, 4  Next
63 vwnotch
63 vwnotch is offline
PostPosted: Tue Aug 17, 2004 9:58 pm    Post subject: Swing Axle VS. IRS !! Beat this to death.. Reply with quote
just curious as to preferances , pro and cons.. as i havent owned a IRS for years and forget the difference..
rob
BUS WANTED: 13 window BUS any year considered..
ice baller61
ice baller61 is offline
PostPosted: Tue Aug 17, 2004 10:19 pm    Post subject: Reply with quote
IRS suspension is a softer ride than swing axel..IRS has a long 4th gear like a freeway flyer,,saves gas, less stress on engine.,,But for racing, IRS sucks! Swing axel is 10 times better and stronger...o yeah IRS is easier to replace than swing axel.
bumping sounds and boosting pounds
ScrapJunkie
(O\U|U/O)
ScrapJunkie is offline
PostPosted: Tue Aug 17, 2004 11:24 pm    Post subject: Reply with quote
swing axle cars look badass when slammed
(O\U|U/O) Top Vw (o\UU/o)
Fowvay
Fowvay is offline
PostPosted: Wed Aug 18, 2004 12:24 am    Post subject: Reply with quote
I'm not picking on you or anything but are you saying you actually like the acute angles created by slamming a swinger?
I personally much prefer the straight up and down of an IRS rear end for slamming as it gives a much better contact patch and doesnt make it look like the rear wheels are broken.
Tom aka Fowvay
My 13.98@104mph New Beetle "Pomelo" | My 1970 Bug "Oscar"
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
vdubrida70
vdubrida70 is offline
PostPosted: Wed Aug 18, 2004 1:11 am    Post subject: Reply with quote
irs has better handling because the wheels can spin at different speeds
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
CPRcubed
CPRcubed is offline
PostPosted: Wed Aug 18, 2004 6:15 am    Post subject: Reply with quote
Depends on the type of racing! Drag racing: Yes, Road Courses: No way!
Cheers!
1970 Bug, Mostly Stock & Rusted for now, 1984 VW Rabbit Convertible, 1994 Ford F350 CrewCab DRW 7.3L PSD
Bruce
Bruce is offline
PostPosted: Wed Aug 18, 2004 12:30 pm    Post subject: Reply with quote
The final drive in 4th in a 3.88 R&P IRS gearbox is the same as that of a 4.12 swing axle, so there's no difference in mileage or anything else.
For all forms of racing, IRS is superior. Swing axle isn't "10 times better" and it isn't stronger. The only advantage swing axle has in drag racing is that its cheaper to make strong enough to survive. An IRS can be made to survive by using 930 Turbo CV joints, type 2 output stubs, SAW axles.
IRS is superior to swing in drag use because the rear tires do not camber in when the weight transfers like swing axle does. The tires remain firmly planted regardless of the weight transfer effects.
79SuperVert
79SuperVert is offline
PostPosted: Wed Aug 18, 2004 1:23 pm    Post subject: Reply with quote
I don't get that. The swing axle tranny has a differential too. So those wheels can also rotate at different speeds. Right?
turboblue
turboblue is offline
PostPosted: Wed Aug 18, 2004 1:36 pm    Post subject: Reply with quote
Take a poll and see if the faster asphalt drag cars are IRS. The results might suprise you.
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
NorCalLowLife209
Mr. Saran Wrap
NorCalLowLife209 is offline
PostPosted: Wed Aug 18, 2004 2:38 pm    Post subject: Reply with quote
I gotta agree with GP swing is way better looking then irs slammed.
SWING Very Happy
IRS Confused
1967 VW type 1 (sold)
1963 VW type 1 (sold)
2011 VW GTI
1979westie
1979westie is offline
PostPosted: Wed Aug 18, 2004 2:59 pm    Post subject: Reply with quote
I love the swingaxles (had me a 67 once) but for safe handling, IRS is the way to go. Cornering too hard in a swinger can cause the outer rear half axle to tuck under and cause the car to roll...(unless you have a good camber compensator). Remember...it was a swingaxle that killed the Chevy Corvair. That and Ralph Nader, of course.
Eric
Your car may do 0-60 in under 5 seconds, but can it sleep 4 and cook a meal?
1979 Deluxe Campmobile (quickly rusting away)
33K miles when bought, now at 61K
Proud Member #2 SBS (Stock Bus Society)
Randy in Maine
Randy in Maine is offline
PostPosted: Wed Aug 18, 2004 3:12 pm    Post subject: Reply with quote
I have had both. Many of both actually.
IRS is better, no question.
60sunroof
60sunroof is offline
PostPosted: Wed Aug 18, 2004 4:05 pm    Post subject: Reply with quote
I.R.S for off road and all around driving.
Swing for drag racing.
ktwizza
ktwizza is offline
PostPosted: Wed Aug 18, 2004 5:40 pm    Post subject: Reply with quote
I like the look of a swing when it's drop as well. I have one so maybe I am kind of biased. Anyway about the saftey its not really an issue unless you are doing some serious manuvering. If you read Ralph Nader's book Unsafe at any Speed it even indirectly references VW's use of a swing axel. It says something like another automakers use of the swing axle suspension not a serious problem like the Corvair because the suspension is not overloaded in the rear like the Corvair. The weight distribution and amount of weight over the rear wheels of a Corvair was the main problem. Not a quote but that's the general idea, I read it a while ago.
"There was only one road back to L.A. US Interstate 15, just a flat-out high speed burn through Baker and Barstow and Berdoo. Then on to the Hollywood Freeway straight into frantic oblivion: safety, obscurity. Just another freak in the Freak Kingdom."
1979westie
PostPosted: Wed Aug 18, 2004 9:56 pm    Post subject: Reply with quote
Thanks for that. I never read "unsafe at any Speed", and I always found it funny that Nader picked on the Corvair and not the Volkswagens of the day (which were far more numerous). The extra weight makes sense. I know my father spun out more than once in his 62 Corvair. I guess they too went to an IRS setup after Nader's book, but apparently the court of public opinion had already cast a ruling. Very Happy Smile Sad Shocked
Eric
down and dirty
down and dirty is offline
PostPosted: Thu Aug 19, 2004 7:43 pm    Post subject: Reply with quote
I like swing, but I am biased too. out of 15 vws all but one was a swing. I even had a 70 bug with a swing. The only IRS was a bus irs in a baja bug. It cost a lot and didnt impress me. If I ever get into racing and I got a little money I would go IRS
but nothing looks better than a slammed bug with a swing axle!!!!!
MOVED
Big Luni
Big Luni is offline
PostPosted: Fri Aug 20, 2004 6:41 am    Post subject: Reply with quote
In 1972, Ralph Nader wrote "Small-On Safety: The Designed-in Dangers of the Volkswagen," attacking the Beetle, and in 1974 he sucessfully lobbied the federal government to reclassify The Thing from utility to passenger vehicle, causing imports to stop. Nader is no friend to the "Aircooled community."
corvette6698512
corvette6698512 is offline
PostPosted: Thu Aug 20, 2009 1:04 am    Post subject: Reply with quote
I like driving my swing axle bug. iv driven a lot of IRS bugs and busses, and they handle good, but they are just not the same to me. Now if only i can only find a way to raise the gearing a bit on my swing. The short tires really ruined cruising speed.
garage:
'67 euro bug
'65 riviera bus
scott s
scott s is offline
PostPosted: Thu Aug 20, 2009 3:35 am    Post subject: Reply with quote
SWING Very Happy
IRS Confused
That's a matter of opinion. In my opinion, they both look like something's broken in the ass end.
Nothing screams "poor workmanship" like wrinkles in the duct tape.
turboblue
PostPosted: Thu Aug 20, 2009 9:11 am    Post subject: Reply with quote
5 years to the day this post gets resurrected......... Laughing
Gary
Page 1 of 4
