Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Sun Feb 21, 2010 10:53 am Post subject: Front shock sleeve stuck/frozen on spindle |
So... trying to put some new-to-me shocks on the front of my Notch. The old shocks, when pulled off, left the metal sleeve on the bottom on both sides. It's frozen to the spindle.
I've tried everything I can think of to get the sleeve off. I've sprayed tons of PB Blaster on it. Used some big Vice-Grips. No luck. The only thing I haven't done is heat it up. Any advice getting this sleeve off so that I can put a new shock on? _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Feb 21, 2010 11:00 am Post subject: |
A pipe wrench would work better than vice grips? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Split it lengthwise with a cold chisel.
You usually do not have to split it completely through. It will come loose before that. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
sharkskinman Lateral Lunatic
Joined: April 26, 2006 Posts: 4030 Location: Deep In My Own Psyche
Posted: Sun Feb 21, 2010 5:41 pm Post subject: |
heat hammer and a pipe wrench _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote: |
Extremity is relative to how far your willing to jump |
Ward Cleaver wrote: |
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards |
PS4 "NKOGNEATO" |
Posted: Sun Feb 21, 2010 6:02 pm Post subject: |
Just f*king split it. No need for a torch.
Been doing this for 45 years. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sun Feb 21, 2010 11:38 pm Post subject: |
That's a good idea. Never thought about splitting it. _________________ Phillip Bradfield
Posted: Sun Feb 21, 2010 11:39 pm Post subject: |
Heating it can take the temper out of that stud. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
