Rear bumper, splash pan and plates.
Ollie W
Ollie W is offline
PostPosted: Tue Apr 08, 2008 8:09 am    Post subject: Rear bumper, splash pan and plates. Reply with quote
Hey,
So I've got my bumper repainted. I bought some splash pans off the Samba and then I bought the install kit.
But I'm confused on where the backing plates go. Does anyone have a sketch or pic, even my Bentley manual didn't seem to help.
Thanks,
Chris
Clara Premium Member
Clara is offline
PostPosted: Tue Apr 08, 2008 8:14 am    Post subject: Reply with quote
Here's the diagram from the 64 ed parts list, courtesy of the OACDP:
http://oacdp.freeweb7.com/5867part/349.png
#49 in diagram
PostPosted: Tue Apr 08, 2008 8:20 am    Post subject: Reply with quote
They go on the inside of the corner.
The link works now.
dreadnotmusic
dreadnotmusic is offline
PostPosted: Fri Feb 26, 2010 5:25 pm    Post subject: Reply with quote
The link above doesn't seem to work anymore.
I bought the splash pan install kit from WW and I can't figure out how in the world this "bracket" is supposed to go. Anyone have good pics of it?
66 Riviera
///Mink
///Mink is offline
PostPosted: Fri Feb 26, 2010 5:36 pm    Post subject: Reply with quote
It goes inside the corner.
Emeritusx
Emeritusx is offline
PostPosted: Fri Feb 26, 2010 5:38 pm    Post subject: Reply with quote
Like this?
82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠
dreadnotmusic
PostPosted: Fri Feb 26, 2010 5:48 pm    Post subject: Reply with quote
I got that far, and it's actually installed already. I have these two small brackets from the WW kit left over. The are angled as if they go in the corner in between the splash pan and body.
Also, is there supposed to be a bit of weight on the corner body bolts? I had to pull the corners of the bumper up a bit to get the bolts started. I don't want to stress the holes in the body.
Edit.....Mink, if I read you correctly you mean it goes on the inside of the body, effectively strengthening the mounting area?
66 Riviera
///Mink
///Mink is offline
PostPosted: Fri Feb 26, 2010 5:54 pm    Post subject: Reply with quote
Yep, from the M8 bolt down to the smaller one at the very bottom of the corner. Kind of hard to explain, but pretty obvious if you look inside the corner.
dreadnotmusic
PostPosted: Fri Feb 26, 2010 5:56 pm    Post subject: Reply with quote
I get it now...and you're right. It's pretty obvious Shocked
Thanks much.
66 Riviera
PostPosted: Fri Feb 26, 2010 11:16 pm    Post subject: Reply with quote
#49 in diagram
New link
http://oacdp.com/5867part/349.png
Yes, you may have to push up on the bumper to get it to line up.
mstephens28
mstephens28 is offline
PostPosted: Sat Feb 21, 2015 3:49 pm    Post subject: Reply with quote
Does anyone know what the small, round seals that come in the WW splas pan kit are for? They look like the could fit in the smaller, bottom hole in the reinforcement bracket, but of course there is a bolt that goes there. I'm stumped.
PostPosted: Sat Feb 21, 2015 6:06 pm    Post subject: Reply with quote
From this guy EverettB in another thread:
busmike wrote:
I put splash pans on my bumper using a WW bolt kit .Where do these rubber bumpers go.
Bottom of the rear corners:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=753781
mstephens28
PostPosted: Sat Feb 21, 2015 10:29 pm    Post subject: Reply with quote
Got it, thanks!
Ollie W
Ollie W is offline
PostPosted: Fri Sep 13, 2024 5:58 pm    Post subject: Re: Rear bumper, splash pan and plates. Reply with quote
This is funny, I was just searching for a topic on how the whole rear bumper goes together as I'm putting my new 67 DC back together and I find that it's a thread I started the last time I didn't know what I was doing!
