My big brake upgrade
Page: 1, 2, 3  Next
buildyourown
buildyourown is offline
PostPosted: Sun Mar 07, 2010 9:28 am    Post subject: My big brake upgrade Reply with quote
Well, after 6 months of toiling on this 2 hrs at a time after work, in the dark, I'm just about done. Sorry for the pic quality, again, taken in the dark.
I've received an incredible amount of help from this forum, especially those that have gone before me. Thanks to all who helped.
The rears:
94-04 Ford Mustang Cobra caliper
94-04 Ford Mustang Cobra 296mm vented rotor.
Custom brake lines.
Home made adapter.
I chose these for a couple reasons. I liked the idea of a big enough rotor that I wouldn't have to turn the hubs. I'm not sure why since it isn't that hard. I wanted vented rears. I wanted a turnkey e-brake install.
Adapters for the calipers are nothing special. 1/2" cold roll steel machined to the right shape. I ended up with around .275" of total offset.
Fitting the rotors was easy. Open up the holes by 1/32" and they slip right on. They have a lot of offset to them though. I had to run my 16mm spacer behind the rotor to give some room for an adapter. Not an issue, as I already had spacers. I you were trying to fit ET30 wheels, you would have a problem. One advantage to that much offset, is the caliper is far enough outboard the access to the lower shock bolt is not an issue.
The brake lines I had done for me at a local hydraulic shop for $60/set. I was told that the lines off of a ~2000 Cadillac Eldorado would bolt right up. The picture looks right. I went to my NAPA and the guy said, why bother searching for lines when you can just have them made? Fair enough. They are a perfect fit and I'm pleased. Pacific Rubber for anybody in Seattle.
E-brake was the same as Loogy's. Turn the end of a piece of 4" long plumbing pipe to lengthen the cable housing. The cable itself is perfect.
Only thing left is to make a bracket to secure the brake line. It would probably be fine, but it won't hurt either.
Christopher Schimke
PostPosted: Sun Mar 07, 2010 9:38 am    Post subject: Reply with quote
Nice job, man! Curious to know how you like them/how they perform for you..
r39o
Samba Polizei
r39o is offline
PostPosted: Sun Mar 07, 2010 10:43 am    Post subject: Re: My big brake upgrade Reply with quote
Because it is easy to do. Easy later to replicate. It is simple. It follows certain rules for retrofitting and updating. One of the main rules being change as little as possible.
I sort of put this rear brake thing on the back burner myself. I used Mercedes rotors in the front which slipped over the old hubs and want the same brand for the rear. No luck yet, but I have not looked in quite some time.
It is a nice job you did. Please let us know haw it works and any other details you need to adjust to make them work well. Thanks for sharing.
240Gordy
240Gordy is offline
PostPosted: Sun Mar 07, 2010 10:57 am    Post subject: Reply with quote
nice. love the way this works without machining, and Ford Mustang parts must be the most common aftermarket and performance parts now and in the future. a great future proof conversion.
Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR
jeremysmithatshawdotca
jeremysmithatshawdotca is offline
PostPosted: Sun Mar 07, 2010 4:30 pm    Post subject: Re: My big brake upgrade Reply with quote
Any chance of posting a drawing?
ZimZam
ZimZam is offline
PostPosted: Sun Mar 07, 2010 4:52 pm    Post subject: Reply with quote
Bravo! Thanks for the beta. If you get a chance could you throw up a pic of the adapter.
'85 Cabriolet (Margo)
'87 Westy (Heidi)
'75 Porsche 911S Targa
"Nobody trusts anyone, or why did they put tilt on a pinball machine.”
- Steve McQueen
"It's just metal, when rusted and dented , anything you will do will be better. Stop being afraid. What they (VW) did many year ago is not better then what you will do now." -Ben
buildyourown
PostPosted: Sun Mar 07, 2010 5:32 pm    Post subject: Reply with quote
The adapter looks just like every other one posted on here so I didn't see a picture as being that informative.
But yes, I can throw some dimensions on it and post a screen shot.
r39o
Samba Polizei
r39o is offline
PostPosted: Sun Mar 07, 2010 5:47 pm    Post subject: Reply with quote
Is it the same one you can by from Burley?
buildyourown
PostPosted: Sun Mar 07, 2010 6:34 pm    Post subject: Reply with quote
No. I believe the Burley one uses Audi calipers and much smaller rotors.
I meant the same as in every other machined, homebuilt adapter is visually the same.
240Gordy
240Gordy is offline
PostPosted: Sun Mar 07, 2010 6:50 pm    Post subject: Reply with quote
don't be so modest. some of us are not quite so handy matching VW with Ford.
Tencentlife said,
r39o
Samba Polizei
r39o is offline
PostPosted: Sun Mar 07, 2010 8:57 pm    Post subject: Reply with quote
I was leaning towards the Mercedes 140 423 06 12 rotor as from an S420, but those Ford rotors are like $21. Hard to resist. Wonder if I can play games with the Burley brackets and get strictly buy and bolt on solution? Emmm......
240Gordy
240Gordy is offline
PostPosted: Sun Mar 07, 2010 9:00 pm    Post subject: Reply with quote
what holds the rotor in place? just the wheel nuts?
Tencentlife said,
buildyourown
PostPosted: Sun Mar 07, 2010 9:33 pm    Post subject: Reply with quote
Yeah, that's how most setups work. Once the bolts are to proper torque, the wheel / rotor/ hub /spacer will act as one piece.
buildyourown
PostPosted: Sun Mar 07, 2010 9:36 pm    Post subject: Reply with quote
I don't think the Burley adapters would work at all with this big of a rotor. Your caliper position is going to be fixed and it won't fit over the rotor.
Don't make design decisions based on relatively cheap parts. If you save $100 and it takes 8 hrs of dicking around, how far ahead are you really?
240Gordy
240Gordy is offline
PostPosted: Sun Mar 07, 2010 9:38 pm    Post subject: Reply with quote
I thought so. The bolt pattern is a tad off, just making the holes a little bigger works okay, what is it a tenth of an inch?
I guess if someone was real picky one could have a shop machine a 5X112 pattern?
Tencentlife said,
buildyourown
PostPosted: Sun Mar 07, 2010 9:49 pm    Post subject: Reply with quote
1/32" = .03125
I was planning on redrilling them when Loogy suggested opening up the holes. I figured I had nothing to loose. I could always still redrill them.
The are not scary at all.
240Gordy
240Gordy is offline
PostPosted: Sun Mar 07, 2010 9:53 pm    Post subject: Reply with quote
ah, Loogy. He's the little devil that sits on your shoulder and says "just do it!"
I mean that in a good way.
Tencentlife said,
Alaric.H
Alaric.H is offline
PostPosted: Mon Mar 08, 2010 1:58 am    Post subject: Reply with quote
How is the E brake clamping force I wonder if it is better with lager rotors.
mordeaux
mordeaux is offline
PostPosted: Mon Mar 08, 2010 7:13 am    Post subject: Reply with quote
Is this fitment based on larger diameter wheels or would it work with stock 14" alloys?
240Gordy
240Gordy is offline
PostPosted: Mon Mar 08, 2010 8:35 am    Post subject: Reply with quote
the rotor in this conversion is 11.45667"
Tencentlife said,
Page: 1, 2, 3  Next
