Zero419 Samba Member
Posted: Tue Mar 16, 2010 12:04 pm Post subject: Van out of storage! |
Ready for another summer, well almost.
The battery was on a trickle charger all winter as it was last winter.
measured 12 volts, when I got the van and installed it, it was dead.
2 years old
Napa.
maybe it's time for a new charger.
I hope they pro-rate.
My rebuilt started right up once it was jumped.
there was some oil drips on the cardboard and some coolant.
the oil is from the pump.
Hopefully the coolant was from a loose clamp.
Soon I will install my Tencent oil cooler, change the oil, order and install the new wheels, on and on...
oh yeah, and enjoy it. _________________ 1987 Westy Auto Bostig 2.0 Ztec |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5076 Location: denver
Posted: Tue Mar 16, 2010 12:09 pm Post subject: |
Congrats!
Pictures. We'll need lots of pictures. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Tue Mar 16, 2010 3:08 pm Post subject: Re: Van out of storage! |
hero419 wrote: |
2 years old
Napa.
I hope they pro-rate. |
A stored battery can read 12 v but have little cranking amps left. Better to store battery in a warm place over winter. And they should pro-rate. |
Posted: Wed Mar 17, 2010 3:26 am Post subject: |
Thanks, I'm going to take it back at lunch and find out more...
It was in my basement on a shelf attached to a trickle charger at about 65-70deg all winter.
I wonder if it went dry. _________________ 1987 Westy Auto Bostig 2.0 Ztec |
Posted: Wed Mar 17, 2010 9:38 am Post subject: |
I stopped in at NAPA durring my lunch and they tested it. 0 volts.
So they wanted to charge it and load test it.
I couldn't wait, and can't go after work so they said they would meet me in the parking lot at work with the battery in question (not likely) or a replacement.
That's service. _________________ 1987 Westy Auto Bostig 2.0 Ztec |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Wed Mar 17, 2010 11:18 am Post subject: |
I'd like to suggest that it is probably better not to leave a trickle charger on that long as I believe that can work against you. Better to store it fully charged and then check it and recharge fully if needed. Batteries don't do well otherwise. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
Posted: Wed Mar 17, 2010 12:28 pm Post subject: |
Simba'sWestyWings wrote: |
I'd like to suggest that it is probably better not to leave a trickle charger on that long as I believe that can work against you. Better to store it fully charged and then check it and recharge fully if needed. Batteries don't do well otherwise. |
True enough. I've overcharged before and it simply begins to boil out the fluids and destroy the volts/amps. For those rigs stored in winter, I simply disconnect the batteries and store them in a warm location. They've always started the rig in the spring, sometimes with a little struggle, but then just drive it out on the highway for about 30 minutes at above 40 mph and you're back in business. |
Posted: Wed Mar 17, 2010 3:25 pm Post subject: |
Thanks, no trickle charger this winter.
New battery, delivered to work parking lot, pro rated, 22 bucks.
Not bad.
2 year old helped me install it _________________ 1987 Westy Auto Bostig 2.0 Ztec |
JPrato Samba Member
Joined: December 15, 2006 Posts: 791 Location: Livonia, NY
Posted: Wed Mar 17, 2010 6:39 pm Post subject: |
what kind of trickle charger? This is what you want
http://www.batteryminders.com/batterycharger/catal...16134.html
It will condition and maintain your batter perfectly over the winter. I used a normal trickle charger one winter and it totally overcharged and killed the battery. _________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
Posted: Thu Mar 18, 2010 3:23 am Post subject: |
One of unknown quality, probably 15+ years old.
May have been my problem. oy, I have 3 of them. _________________ 1987 Westy Auto Bostig 2.0 Ztec |
