Honuak Samba Member
Posted: Tue Mar 16, 2010 3:10 am Post subject: High Output Alternator Subagon. External Voltage regulator |
I'm all over Samba like a rash....
Ok all you electrical gurus, I am putting my electircal system together on my westy and I'm in way over my head as usual. I am using a battery isolator (Yandina 160) and a high output (140 AMP) alternator on my Subie 2.5. I'm fairly sure the alternator has a built in voltage regulator but a boat guy I know thinks an external voltage regulator is a good idea. I am going to be running an inverter, isotherm 12 fridge, amplifier, stereo, powered sub, coffee grinder...etc. My plan is to get separate house and starting batteries. A decent marine grade voltage regulator is big bucks. Anyone have thougths on this one?
Cheers
Honuak |
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Tue Mar 16, 2010 7:29 am Post subject: |
I shoehorned a CS144 large case Delco alternator onto my EJ22. It has a 200A stator and an overdrive pulley. I'm just using the stock Delco (internal) regulator, it works fine. As long as you have a large wire going to the aux batt (I have 1/0 AWG) there won't be a significant voltage drop so the internal regulator is fine. _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
Honuak Samba Member
Posted: Tue Mar 16, 2010 8:11 am Post subject: |
Thanks. Great news.... |
r39o Samba Polizei
Posted: Tue Mar 16, 2010 9:42 am Post subject: |
presslab wrote: |
I shoehorned a CS144 large case Delco alternator onto my EJ22. It has a 200A stator and an overdrive pulley. I'm just using the stock Delco (internal) regulator, it works fine. As long as you have a large wire going to the aux batt (I have 1/0 AWG) there won't be a significant voltage drop so the internal regulator is fine. |
What is the magic to make that fine piece of hardware fit?
(Somewhere I recall seeing something to the effect: A post with out pictures is not worth a ....... I normally think content is the best, but in this case a picture or two would really help to see just how shoe horned in it is. PLEASE?)
TIA,
Walt... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Tue Mar 16, 2010 2:44 pm Post subject: |
r39o wrote: |
presslab wrote: |
TIA,
Walt... |
Sorry for the hijack Honuak.
Honuak Samba Member
Posted: Tue Mar 16, 2010 7:22 pm Post subject: Hijack away |
Thats frikkin sweet! Do you need to put a little extra tension on the belt for the higher output? |
Posted: Tue Mar 16, 2010 7:32 pm Post subject: Re: Hijack away |
Honuak wrote: |
Thanks! Oh yes, the tension is pretty tight! Or else, squeeeeeeal...
I read on alternatorparts.com (where I bought the stator, diodes, etc.) that having too loose of a belt will cause it to slip and heat things up. Eventually the heat will burn up the front bearing in the alternator. So I keep it tight - no problems so far, I'd had this alternator on there for a couple years. _________________ 1986 Vanagon Westfalia EJ25
r39o Samba Polizei
Posted: Tue Mar 16, 2010 7:49 pm Post subject: |
OK this is going to get "sticky." Can you illuminate all the stuff that has to happen to put one in, please? Are those brackets modified stock or a kit? It is just too sweet. I want my house golf cart batteries to be kept happy! _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
VisPacem Samba Member
Joined: July 15, 2007 Posts: 1143 Location: Las Vegas
Posted: Tue Mar 16, 2010 9:33 pm Post subject: |
presslab wrote: |
Hi , could you indicate *which* CS144 you used. I found this site with a dozen or so CS144 for various applications.
http://www.alternatorparts.com/category_cs144.html
Just in case, that, was my solution
http://www.maniacelectricmotors.com/hiou135ampal.html _________________ LG aka VisPacemPB, *The* party Pooper
No Regrets (Nothing to do with Vanagons) |
Rhinoculips Samba Member
Joined: August 08, 2005 Posts: 918 Location: Keystone, Colorado
Posted: Tue Mar 16, 2010 10:33 pm Post subject: |
Did you run a second (4 gauge) wire from alternator to battery, as they suggested? _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image |
targis58 Samba Member
Joined: July 11, 2006 Posts: 529 Location: sunnyvale,ca
Posted: Tue Mar 16, 2010 11:47 pm Post subject: |
Rhinoculips wrote: |
Did you run a second (4 gauge) wire from alternator to battery, as they suggested? |
Is this going to be a solution to the battery indicating light coming on on dash in a westy with freezer? _________________ 90 westy 2wd w/ TBD |
Posted: Wed Mar 17, 2010 1:53 am Post subject: |
I did not and everything so far so good. However I will do just that. I am not certain I am getting full benefit of this alternator and I am also concerned with overloading my present wiring.
Yes I should  _________________ LG aka VisPacemPB, *The* party Pooper
Posted: Wed Mar 17, 2010 1:54 am Post subject: |
targis58 wrote: |
Is this going to be a solution to the battery indicating light coming on on dash in a westy with freezer? |
I would not know I sold my Westy long long time ago... _________________ LG aka VisPacemPB, *The* party Pooper
Posted: Wed Mar 17, 2010 6:53 am Post subject: |
targis58 wrote: |
No. The solution to fix the light problem is behind the fuse panel and the relay. Visit the subaruvanagon yahoo group. There is a write up on how to do it there. _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Posted: Wed Mar 17, 2010 8:31 am Post subject: |
My alternator was from a Camero, and is the "six-twelve mount" style. I got that on eBay. Here are the parts I purchased from alternatorparts.com:
241257 5-groove pulley.
41010782 200 amp heavy duty stator.
DR5180PF Transpo rectifier.
D1C120 Wiring repair harness.
I measured 111A at idle and 190A at speed. Goodyear 4050340 belt.
The brackets are custom made. The aluminum bracket for the PS pump and stock alternator was modified by cutting off the stock alternator mount. The pics show the parts I made - the slotted adjuster bracket and the two adapter brackets on the AC compressor side. The slotted part has a little offset in it at the bottom.
This mod could be reversed with a new PS pump aluminum bracket.
For the wiring I basically hooked the L (lamp) lead through a 470 ohm 1/2W resistor to switched 12V from the stock alternator wiring. This resistor is located in the harness. I also hooked the L lead to the alternator lamp so the dash lamp works. The reason I needed the resistor is because the Vanagon alternator lamp does not draw enough current to get the alternator going. _________________ 1986 Vanagon Westfalia EJ25
