Sigurd Samba Member
Joined: April 18, 2006 Posts: 2639 Location: Rockford, IL
Posted: Thu Mar 25, 2010 3:12 pm Post subject: |
Yeah, it is on the side. I'm familiar with drilling to stop a crack; I've done that to cymbals before. Jimmy has spare new ones, so he'll send me one, but I'm still waiting to hear back from him. |
morymob Samba Member
Posted: Thu Mar 25, 2010 3:17 pm Post subject: |
jamestwo wrote: |
Run it!!!I have a cylinder that had the exact same crack. I cut the crack out with a die grinder. The motor turned 7200 rpm, ran 13's, and i drove it about 5k. never a problem.
If you cut the crack out, there is nothing to go wrong. drilling is another option, but you still have to try and straighten the area around the crack.
Just cut it out, Drill the bottom of the crack before you cut would be a good idea to keep it from spreading while you cut.
You will be ok as long as you have some of machined area left to seal the case. Also, check to make sure the skirt of the piston is supported all during the stroke, but your crack looks to be on the side of the cylinder, so that shouldn't be a problem. Why cut out a big ugly section?? not needed if drilled to stop crack,metal around crack area not going anywhere, waste of time.
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Thu Mar 25, 2010 4:27 pm Post subject: |
I have a 103mm cylinder for my T4 engine with a crack in exactly the same spot, the machine shop drilled a small hole to arrest it's propogation. I have to doubt it will work just fine. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
jamestwo Samba Member
Posted: Thu Mar 25, 2010 8:08 pm Post subject: |
Because the area is bent. You can straighten it, but how you going to make perfectly round.....not that it matters because the piston in most cases will not even travel down that far, butif it's bent it will make it hard to assemble.
As far as being ugly, no one see's it.
morymob wrote: |
jamestwo wrote: |
_________________ hEY, lOOK, i'M WRONG HALF THE TIME, AND THE OTHER HALF i'M NOT SURE WHAT THE HECK i'M TALKING ABOUT. MY POST ARE FOR MY OWN ENTERTAINMENT VALUE ONLY. |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3284 Location: Rapid City, SD
Posted: Thu Mar 25, 2010 8:47 pm Post subject: |
You mentioned they were machined. Did the machinist clamp the lathe jaws a little to tight on the ID spreading the spigot and cracking it?? Just a thought.
Brian |
Sigurd Samba Member
Posted: Thu Mar 25, 2010 9:13 pm Post subject: |
No, they weren't cracked when I got them back. |
jeff denham Samba Member
Posted: Thu Mar 25, 2010 10:09 pm Post subject: |
i agree with jamestwo. grind it out and run it. just champher cartrige roll the edge. and repower hone that cly. JD . _________________ www.dprmachine.com |
nsracing Samba Member
Posted: Fri Mar 26, 2010 5:29 am Post subject: |
YOu don't need to gouge it out that big to clear the crack.
A small fine wheel from your Dremel will be enough and save more material. Just run the wheel right in the crack. You will end up w/ a smal slit. The cut is so small that it will get rid of the burr and keep all the material in place. This will make more sense than taking out that much. |
Sigurd Samba Member
Posted: Fri Mar 26, 2010 5:35 am Post subject: |
Thanks for all the suggestions, guys. I talked to Jimmy last night and he is sending out one of his spares on Monday. I don't argue that grinding the area doesn't work; I'm just not sure I trust myself to do it, or do it effectively. I get free machine work from our local guy, so I can't argue with that either.
vwracerdave wrote: |
Replace it. Don't jeopardize a $5000 engine... |
Staple a few more bills onto that and then we'll talk. |
Posted: Fri Mar 26, 2010 7:46 pm Post subject: |
I actually screwed mine up while fixing it.
Your right, just remove the damage.
BTW, if i could gotten a new one cheap, i would have done that...plus I didn't want to wait.
nsracing wrote: |
Posted: Fri Mar 26, 2010 10:30 pm Post subject: |
the pictures shows an obvies crack straite down AND BUCKELD but i bet if you got the magnifying glass out there will be the crack alot smaller making a turn and i dont think just the slice would help that. if your on a shoe string bugget you know what to do. but if you wipe your a?? with hundreds well i would hope you would know what to do as well. JD . _________________ www.dprmachine.com |
