NAES Samba Member
Joined: September 10, 2003 Posts: 2120 Location: AREA-52 Southern Killafornia
Posted: Thu Apr 01, 2010 6:48 pm Post subject: Wheel cylinder seal fit |
Just about finished putting my rebuilt front end together and brakes are next on the list.
I found 4 NOS wheel cylinders and 2 of the inner seals were questionable. I bought Brazilian rebuild kits for them and they seem awfully easy to slide into the bores. All I can think is that either Brazilian seals aren't as thick or repop wheel cylinders have a slightly smaller bore.
I tried to do a leak test with some brake cleaner and brake fluids and they passed but I'm still a little concerned.
Anybody care to chime in? _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
&Dan Samba Member
Posted: Fri Apr 02, 2010 12:18 am Post subject: |
I'm curious about this subject, too- I don't have NOS cylinders to rebuild but they are old German units. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14259 Location: Casa de Oro, California
Posted: Fri Apr 02, 2010 6:42 pm Post subject: |
I've used lots of Brazilian kits in og ones. If they don't leak then that's the test. When you tromp on the brakes the lip on the cup spreads even tighter. Pull off a drum someday and peek inside a boot and tell us what you see. |
Rick Samba Member
Joined: December 17, 2003 Posts: 1539 Location: Soquel, California
Posted: Fri Apr 02, 2010 9:47 pm Post subject: |
I just rebuilt my original ATE front wheel cylinders. The seals were decent, but the original ones seemed just a bit loose. After sourcing new seals from two different manufactures I was happy to find that one of the two manufacturers seals was just a bit larger, so after honing I felt these would provide a better seal. Bottom line: check your OG seals, and if you buy new ones check them all. Some might fit better than others. |
