Barracudabrendon Samba Member
Joined: October 26, 2008 Posts: 298 Location: Kahuna Metal Works SoCal
Posted: Sat Apr 10, 2010 6:10 pm Post subject: Damaged axle tubes |
Hi guys, tried searching but couldn't find a definite answer . Are all long swing axle tubes the same T1/T3 besides the sway bar bracket? I read through all the threads about changing axle tube lengths and what not but couldn't find an answer to my question. I have a damaged axle tube and would just like to buy a new set, I'm not using the brackets so would T1 long axle tubes work or is the bearing housing different. I found these CB ones with boots and side plates already mounted, will they fit my 64? http://www.vwparts.net/mm5/merchant.mvc?Screen=PRO...ange_high= Thanks in advance _________________ Building quality HWE style racks for your Type 2 Kahuna Metal Works.
1957 Bus
Turbo Mini Single Cab
1964 N Model Squareback
Ruthless Fastback Drag car |
Adriel Rowley Samba Member
Joined: October 12, 2006 Posts: 4748 Location: Mesa, Arizona
Posted: Sat Apr 10, 2010 6:58 pm Post subject: Re: Damaged axle tubes |
Barracudabrendon wrote: |
Hi guys, tried searching but couldn't find a definite answer . Are all long swing axle tubes the same T1/T3 besides the sway bar bracket? I read through all the threads about changing axle tube lengths and what not but couldn't find an answer to my question. I have a damaged axle tube and would just like to buy a new set, I'm not using the brackets so would T1 long axle tubes work or is the bearing housing different. I found these CB ones with boots and side plates already mounted, will they fit my 64? http://www.vwparts.net/mm5/merchant.mvc?Screen=PRO...ange_high= Thanks in advance |
111 501 105 Tube -Rear axle to Ch. No. 316500 000
(to Ch. No. 168497 see Workshop Manual H-S)
361 501 105 A Tube -Rear axle, left (marked with a white dot)
to Ch. No.366 500 000 M 267
from Ch. No. 317 000 001 to 318500 000
from Ch. No. 369 000001 M 263
use:
to Ch. No. 317 170 143
111 501 139 361 501 106 A Tube -Rear axle, right
to Ch. No. 366500 000 M 267
from Ch. No. 369 000 001 M 263
use:
111 501 139
So, depending on your chassis number, could be a type one part. Hope this helps. _________________ Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Dad's 1964 Beetle purchased September 1968.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9252810#9252810
1971 Sunroof Squareback with Fuel Injection
http://www.thesamba.com/vw/forum/viewtopic.php?t=219811&highlight=squareback+rejuvenation |
