allsierra123 Samba Member
Joined: August 19, 2006 Posts: 1462 Location: Tecate, Baja California MX
Posted: Sat Apr 10, 2010 3:41 pm Post subject: Broke one of the studs off the AT trans mount. |
The stud that is in the top of the mount where it bolts to the AT tranny. Broke off there is a piece of it hanging out but Im trying to figure if it attaches from the inside or does it just turn out? I think I can get a replacement locally but need to know the easiest way to get them out. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold |
motelvw Samba Member
Posted: Sat Apr 10, 2010 5:00 pm Post subject: |
That should just be a stud threaded in. Don't use an easy-out, it'll break off and cause more problems. BTDT.
Soak it in Kroil, heat it, cool it, repeat. Try to turn it out. If you can cut a slot in what's left, you can use a flat screwdriver and vice grips to spin it out.
If that fails, drill it out. You can always tap it out to the next size up. |
Posted: Sat Apr 10, 2010 9:52 pm Post subject: |
I think it may have enough on it to get two nuts right on top of each other on there. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
r39o Samba Polizei
Posted: Sun Apr 11, 2010 9:55 am Post subject: |
Sure double nut it, but first do the soaking.
Also, just tighten it a tad before you attempt to unscrew it.
This relieves some tension. (Don't ask, my German master mechanic dad always did this. You will hear a pop and you know it is ready to come out.)
HEAT helps.
Don't chance breaking it off more! _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Sun Apr 11, 2010 10:58 am Post subject: |
I will give it a shot. I have a junk tranny here with some studs on it So I will try to pull those out. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
