Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
Posted: Fri Apr 23, 2010 8:46 pm Post subject: Luxury Tools |
I am a bit of a tool collector I hit flea markets pawn shops craigslist where ever I can buy tools cheap and some time I have to buy new ones hey it can not be helped.I look for new stuff all the time so if you have or seen a special tool to work on the van post them up and do not forget the one you make your self for short cuts. Here is one I like.
http://www.theinductor.com/index.php?m=41 |
Posted: Fri Apr 23, 2010 8:53 pm Post subject: |
Brake bleeder I got on eBay 250$ The DrainTwin is a versatile brake bleeder for all brake service jobs and hydraulic applications. It features a pulsating heavy-duty double chamber
diaphragm pump, a sturdy enlargeable construction, non-drip connections, designed accessories and a large range of adapters. It operates on normal shop air with a pump that generates a pulsating pressure so stable it surpasses most electrical pumps. The pulsating pressure purges the brake system to a higher degree then a constant pressure. The pump is completely maintenance free and its heavy-duty design provides an extended service life.
Tool spaces on the sides of the unit provides room for all necessary tools and accessories, and in the back there’s room for two 5-litre cans, one for new brake fluid and one for waste.
The unit comes in three sizes, portable, caddy and cart, and is delivered with all necessary accessories; hose, filter, suction hose for vacuum bleeding, suction/fill gun, inlet suction hose, and E20 standard adapter. All accessories are designed for optimal efficiency in connection with the DrainTwin unit.
Williamtaylor33 Samba Member
Joined: September 07, 2007 Posts: 1545 Location: Arkansas
Posted: Fri Apr 23, 2010 8:55 pm Post subject: |
One of my most used tools is my coordless rachet from Ingersoll Rand.[/url] _________________ 89 Bostig powered syncro westy |
danno Samba Member
Joined: November 07, 2005 Posts: 184 Location: Comox BC
Posted: Fri Apr 23, 2010 10:13 pm Post subject: |
My ratchet's don't have a cord's either. _________________ Dan
Comox BC
86 Wolfsburg Weekender
92 Golf 4dr
93 Beta Synt Trials Bike. |
Posted: Sat Apr 24, 2010 7:07 am Post subject: |
Williamtaylor33 wrote: |
One of my most used tools is my coordless rachet from Ingersoll Rand.[/url] |
No info came up I would like to see it. |
240Gordy Samba Member
Joined: May 15, 2008 Posts: 2348 Location: Vancouver, BC
Posted: Sat Apr 24, 2010 7:24 am Post subject: |
_________________ Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Sat Apr 24, 2010 10:24 am Post subject: |
A two handed cordless hammer......thats what Im talkin 'bout  |
Zero419 Samba Member
Posted: Sat Apr 24, 2010 10:32 am Post subject: |
dust cap remover.
I'd love to get a set of ratcheting wrenches.
Cordless, of coarse.  _________________ 1987 Westy Auto Bostig 2.0 Ztec |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 2962 Location: The Topless Bar On Mustafar
Posted: Sat Apr 24, 2010 10:40 am Post subject: |
I like this one
Why was the photo deleted? Moderator?WTF? _________________ Whisper__"If You Build It_______It Will Run"
1959 panel van, 1966 single cab. 73' 181. 91' H6 Vanagon(Under construction). 3 Xterras, 2 08 Subaru Foresters.
Posted: Sat Apr 24, 2010 12:32 pm Post subject: |
Alaric.H wrote: |
Quote: |
Cordless, of coarse. |
Quote: |
My ratchet's don't have a cord's either. |
Quote: |
A two handed cordless hammer |
Posted: Wed Sep 15, 2010 7:05 am Post subject: |
I have a new tool that works great it applies heat to a area and no where else as I kept starting small fires with the the torch plus melting wires and plastic.
Volksaholic Samba Member
Joined: December 26, 2005 Posts: 1771 Location: Salt Lake City, Utah, USA
Posted: Wed Sep 15, 2010 7:41 am Post subject: |
Alaric.H wrote: |
I have a new tool that works great it applies heat to a area and no where else as I kept starting small fires with the the torch plus melting wires and plastic. |
I'm not big on battery operated gizmos, but I like that. I wouldn't be opposed to it in a corded version either.... it's not like it's something I would likely need in (or take with me to) the wilderness.
Most of my favorite tools are cordless and operate on simple muscle and leverage... preferably with the power source lubricated by a little beer. I use antique Yankee screwdrivers and push drills for quite a few car and home maintenance tasks. I don't have to replace batteries and my bigger ones can generate more torque than any battery operated screw driver I've used. I was making good use of my antique Yankee ratcheting tap handle when doing the Subie conversion too.
Another thing that I found really handy with the Subie conversion that will get a lot more use on the Vanagon is a stubby 3/8" drive ratchet. It's actually the head off a broken click type Craftsman torque wrench. I can't just throw things out... I end up taking them apart to see what's useful. The only thing I kept was the ratchet head which has about a 2" or so handle. It makes a good palm ratchet or I can use it in places that I just can get a good throw with a standard ratchet.
I also like a big block & tackle I found at a yard sale. My ex and her boyfriend stole my Come-along, but then I found this block and tackle at a yard sale for $5. The pulley wheels are about 4.5" in diameter and it's got something like a 5 to 1 ratio. I used it extensively to hoist my engines onto carts and my engine stand during the conversion using a folding ladder as a derrick. With the help of my boys we pulled the Vanagon up the driveway (uphill) with it to put it in front of the garage when the engine was dead. I've used it to hoist the body off two Bugs... one that I was scrapping and the other that was getting a body-off restoration. It's found lots of remodeling and landscaping uses too.
Paul _________________ 1988 Wolfsburg Edition, 2001 Subaru EJ251 |
Posted: Wed Sep 15, 2010 3:59 pm Post subject: |
It plugs in and heats up in seconds. |
Rocky Mountain Westy Samba Member
Joined: April 17, 2008 Posts: 970 Location: Fort Collins Colorado
Posted: Wed Sep 15, 2010 5:27 pm Post subject: |
I don't have any pictures and it doesn't have much luxury but it has really helped me out.
So when your allen CV bolts are striped, I take a Snap On 12 point 12 mm socket and pound it over the head of the bolt. It is a tigh enough fit that it works every time. Depending on the job, I sometimes go right to this method. If a couple are stripped and filled with grease this is sometimes faster.
I don't know if other 12mm 12pts work but my snap on is fantasitic.
Try it, way better than vise grips. _________________ Rocky Mountain Westy Inc.
www.rockymountainwesty.com
970-310-3441
[email protected]
The Splitzgauer build (when I have time to work on it and update the thread)
http://www.thesamba.com/vw/forum/viewtopic.php?t=497133 |
Posted: Wed Sep 15, 2010 5:32 pm Post subject: |
Rocky Mountain Westy wrote: |
Try it, way better than vise grips. |
I wonderd what I was going to use that 12 point 12mm socket for. |
Posted: Wed Sep 15, 2010 5:42 pm Post subject: |
Alaric.H wrote: |
My Toyota buddy tried to steal it. I about cut his hand off. _________________ Rocky Mountain Westy Inc.
970-310-3441
[email protected]
mordeaux Samba Member
Posted: Wed Sep 15, 2010 5:50 pm Post subject: |
That Mini-Ductor is excellent. I can see where that would be very desirable in a professional shop. Much safer, I should think. |
edgood1 Samba Member
Joined: September 30, 2004 Posts: 1926 Location: Plymouth, MA
iltis74 Samba Member
Joined: November 20, 2003 Posts: 816 Location: Anchorage, AK
Posted: Thu Sep 16, 2010 2:33 pm Post subject: |
I got a set of these off the Snap-on truck a few years ago, and for the money they are hard to beat. I have two separate sets and there may be more, I don't know. They allow you to run a tap with a ratchet. There is an o-ring inside to stabilize the tap. Very handy.
http://buy1.snapon.com/catalog/item.asp?P65=&t...ir=catalog |
Wolfram Samba Member
Joined: June 23, 2005 Posts: 174 Location: Waiheke Island/On The Road USA
Posted: Fri Sep 17, 2010 9:19 am Post subject: |
Alaric has the BEST tools. You just have to see the collection.
Geoff
McLean
VA |
